Rheem Criterion II Furane would not ignite
Hello - my Rheem Criterion II (old model) would not ignite the flame.It worked until a couple of days ago. When I open the cover and startthe furnace, the green LED is blinking twice then pause. According tolabel, the pressure switch is open. How can I fix this? Do I need toinstall a new pressure switch? Please advise.
  • sapsecure Dec 25, 2008
    the subject should read Rheem Criterion II Furnace -
    Merry Christmas - I really appreciate giving me assistance over the holidays. The hose is still in great conditions. What I did is to remove the hose and blow & **** into the switch, closed the burner door and it ignited. I am not sure if this will come up again, but at least during my test, the furnace ignited. I will see again tonight if it comes on again.
    Thanks again!
  • 700 Answers
What you need to do is take and inspect the hose that goes to the pressure switch and make sure that it is not dry rotted. if it is and the combustion blower is running then firsat try to cut the hose down and slip on a better piece of rubber. If not then replace the hose,
Posted on Dec 25, 2008
LX2000 gas furnace. It starts and runs for about 5 seconds, then why does it shut off?
Fix Furnace Flame Sensor (Flame That Goes Off) - YouTube
? 1:22
https://www.youtube.com/watch?v=fBJ3r9MUa-U
Nov 29, 2011 - Uploaded by RochNoure
A Furnace Flame Sensor is a safety device that reads the temperature and ... easy fix, but the furnace is ...
Troubleshoot the ignitor of the Rheem RGDA model gas ...
? 5:53
https://www.youtube.com/watch?v=Bx1pXONg2Oc
Dec 12, 2012 - Uploaded by grayfurnaceman
Troubleshoot the ignitor of the Rheem RGDA model gas furnace.... Jun Sim 5 months ago ... My lennox ...Missing: lx2000
Rheem Criterion II No Heat - YouTube
? 0:47
https://www.youtube.com/watch?v=yOSk6qvpWbA
Jan 7, 2010 - Uploaded by Work12Progress
Rheem Criterion II gas furnace model # RGPH-07EAMGR. When a call for heat is made t wo green led's ...Missing: lx2000
Heater will not kick on unless... [Archive] - Self Help Forums
www.selfhelpforums.com/archive/index.php/t-2153.html
Oct 19, 2004 - 25 posts - ‎9 authors
After a certain amount of time of not running, the heater will refuse to kick back on. ... 2 flashes, then a 2 second pause = pressure switch is open. What do .... On LP gas furnaces, the spark starts and the gas valve opens. ... Buffing them up with a little steel wool (5 minute job) is a good annual PM thing to do.
Dec 16, 2015 | Heating & Cooling
I have a Rheem Criterion Furnace that won't stay on! Starts and stops 3 times then shuts off!
Check air filter is clean , jump out pressure switch see if it lights
Jan 08, 2013 | Heating & Cooling
I have a Rheem Criterion II Gas Furnace that has been acting up the last couple of days. It is model #RGPH-12EARJR. It will cycle on, ignite the pilot, 4 burners light and stay lit from 5-10 seconds then...
Turn off the power to furnace.
on the last burner to light there is a small metal rod in front of the burner. This is a safety called the flame sensor. It is dirty. Unscrew it from the bar ( 1 Screw) unplug the connector wire from it and clean it with steel wool. it will be kind of burnt. Plut back in place and turn on the furnace to cycle.
Apr 04, 2010 | Heating & Cooling
Have a rheem criterion II. Model
The way it lights is that the gas is spread from one burner to the next by either a flame tray or small holes drilled in the burner tubes. If the flame does not get all the way across the burner tubes within a few seconds, the unit goes out on failure. Clean and inspect each burner tube, not just the orifice. Clean any tray that connects the burners. You can use a small wire brush or tooth brush but be careful near the glow igniter as it is very fragile.
Dec 12, 2009 | Heating & Cooling
RHEEM CRITERION II FLAME LIGHT DOES NOT COME ON
1/ overheat stat 2/ fan 3/ diaphrapm valve 4/micro switch when checking fan be sure to check the very small rubberor nylon hose for pinhole best of luck
Oct 29, 2009 | Rheem Paloma PH-20R IFSN / RTG-53PVN...
Rheem criterion II flame stays lit for a few seconds then only cold air blows through the house
Your furnace needs a tune-up. MODERN FURNACES REQUIRE REGULAR MAINTENANCE!
Mar 10, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
607 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
