Question about Nakamichi AV-7 Receiver
No Video Output from Video, VCR1 & VCR2 Program Sources
There is no video output from any of the above sources, though the audio output is present. Both audio & video outputs are present from the DVD output.
  • 8546 Answers
SOURCE: No problems for serval years. Right sound output
I presume you have proven the channel is dead by trying multiple sources, swapping a different speaker onto it and that the balance control is NOT all the way to one side; headphones don't work either and we're down to proving it's dead before you take it in to a tech, right?
There is the slighest chance that a common control may have developed a high-resistance or 'dead' spot and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
If it still doesn't work you might want to prove if its a low-level signal loss or a high level amp failure. One way would be to run an RCA cable pair from the Tape Out to any other device (even a TV with speakers) you might have that accepts an audio input. If IT can't detect receive the DEAD Channel you
Posted on Feb 21, 2011
0 characters
1 Points
How do i connect sonos " control " to denon avr 300. Where are audio output on this denon?
The AVR-E300 doesn't have an audio output. It's a very basic AV receiver built down to a price.
Even if you has a better quality receiver, you still would only be able to port sound from analogue sources (ones connected via red & white RCA/phono) to the Sonos Connect for distribution around the rest of your home. AV receivers don't decode audio from HDMI sources to analogue stereo.
If you want to port sound, hook up a source direct to the Sonos Connect's audio input. Don't try going via the receiver.
Sep 14, 2014 | Denon Audio & Video Receivers
My tx-nr905 recievers output audio goes out when connected to my projector and a dvd player, but its ok with any other output combo; proj/sat or tv/dvd or tv/sat etc..... bought new about 4 yrs ago, has...
Semantics maybe, but sources are INputs. OUTputs are speakers, audio to other devices.
A DVD is always an INPUT.
So what's different? IOW, how are the DVD and Projector (Really? It uses a video OUTput) connected for audio? Have you looked at the manuals? Digital sources must be assigned, for example.
Aug 25, 2011 | Onkyo TX-NR905 Receiver
How to install a audiosouse equalizer (eq 100) onto denon 3805 receiver, without a tape monitor thanks henry
Actually, you have several tape loops: CDR/Tape, VCR1 and VCR2. The bottom right part of Page 7 in the manual shows how to connect a Tape Deck (or any in/out processor).
Be advised that the engagement of any device in a Tape Monitor loop on a late-model Audio/Video Receiver will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Monitor as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? They would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up: Receiver Tape- or VCR Out to the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-In; Receiver Tape- or VCR In from the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-Out.
I have a whole array of 2-channel analog processing electronics looped out of one Tape Loop on my AVR - via a dbx 400x Program Route Selector - for making tapes or CD-R Audio recordings and otherwise modifying the analog sound for various purposes.
Aug 12, 2010 | Denon AVR-3805 Receiver
I have a SA 8300HD cable box connected to Yamaha RX-V2500 receiver using Digital Audio Out from cable box to DVR/VCR2 on the receiver. It had been working for 2 years. Then this past weekend it stopped...
Pretty good problem description.
Make sure the DVR/VCR2 digital input is assigned to the Cable box.
When the DVR/VCR2 input is selected do you get any front panel indicators on the Yamaha that indicate a good digital bitstream?
Try swapping the cable box output to the working DVD In connection to isolate it to either the source or the receiver's ability to decode it.
Check the audio output settings for the Cable Box, too. Sometimes their outputs are adjustable. It may be muted or set too low.
Mar 31, 2010 | Audio & Video Receivers
Setting up DVR, Receiver & VCR w/out cable box
For TV audio thru the receiver, you will need to run an optical cable or RCA analog audio cable from the "Audio Output" or "Monitor Output" on the back of the TV to the CBL/Sat input on the Yamaha. The VCR goes to Video 1 on the receiver and the DVDR will go to DVR/VCR2 on the receiver. If you want to pass Video thru the Yamaha to the TV, use the "Monitor Output" on the Yamaha if it's at least "Component Video" if not, connect your video sources directly to the TV and audio to the Yamaha. Hope this helps. If you need further assistance with this, post a comment and I will help you further.
Sep 26, 2009 | Yamaha HTR-6030 Receiver
Yamaha RX-V757 No Left Channel Output - Video Sources Only
First - make sure it is not a defective cable by reversing the leads/colors on the inputs if problem then goes to the right channel then you know it is a bad cable/RCA, etc., connector. I would try that first.
Feb 07, 2009 | Yamaha RX-V757 Receiver
Listen to TV through my vsx-454
  2. GO buy RCA Cables(red,white,yellow)
  3. If your Tv Has An RCA Output Connect the RCA Cables @ one End of the TV.
  4. Connect the Other End to THE VCR2 Input.
Jan 16, 2009 | Pioneer VSX-454 Receiver
No S-Video nor RCA Video output to monitor
First, you've checked and the monitor will display other sources plugged into the same monitor input?  And you've tried plugging the receiver into another TV?  Otherwise all I can tell you is that the receiver does not convert.  So if you want to see S-Video on your monitor, you have to input S-video.  If you want to see RCA output, you have to input RCA.  Best of luck.
Mar 24, 2008 | Sony STR-DE975 Receiver
Help fixing a sound problem with our receiver
You should be able to find all the instructions for these connections in your products owners manuals. The procedure should be straight forward. all the connections to the receiver should be input and output connections. The Receiver is basically just a switch box and amplifier with extras.You must make sure you know which input and output you are using for each of the components. You must have all the remote controls set-up to work with each other. The receiver is the master switch. From it you will control all input sources to the various output sources. Here is a possible set-up . Television output sound and video to the first input/ output section of the receiver. from here you can use the first audio/video output to your dvd/vcr input. This will allow you to record the television programs video and audio to your recording media.The audio/video output of the dvd/vcr will be connected to the second input /output of the receiver.With the second input you can view all the dvd/vcr materials on the television while listening to the sound through your receiver.The master output of the receiver's audio/video output is connected to the television input circuit. This will allow viewing and sound from all the units connected to the receiver. The receiver sound system will receive sound from all the input units as long as the connection are right and the input/out selections from the remotes controls are correct. That is the reason the owners manuals are so important for this purpose. They give these instructions and diagrams to show you the correct procedures for setting them up.They also give you information about customer support either with website help or a call in line for technical assistance.I hope this helps you with your problem.
Feb 09, 2008 | Audio & Video Receivers
RX-V902 TV/DBS source coming through all other sources...
This could be as simple as having input and output line audio reversed. Please check all sources for proper connection. You can do this at the receiver too, but not both receiver and sources.....accordianman
Oct 31, 2007 | Yamaha R-V902 Receiver
Nakamichi AV-7 Receiver Logo
23 people viewed this question
Top Nakamichi Audio & Video Receivers Experts
Are you a Nakamichi Audio and Video Receiver Expert? Answer questions, earn points and help others
