Question about M-Audio Pro Tools M-Powered
Installed protools 7.4 no sound coming out
Meters read that it is playing but no sound coming out. computer sound works but protools tracks have no sound. using a power book g4
  • 6 more comments
  • Anonymous Jan 04, 2009
    m powered 7.4 installed in vista 32 bit but there is no sound
  • Anonymous Jan 22, 2009
    same as above???
  • Anonymous Feb 02, 2009
    yep, same exact prob here. no ideas though.
  • permanewb Mar 11, 2009
    Yup...meters read the input. I looked through tutorials and I am doing everything the same so I thought, but when I record there is no audio file that is created. It just stays blank.
  • Anonymous Mar 19, 2009
    My tracks are being recorded in protools, but there isn't any sound when I try streaming through the recording.
  • g belton Mar 20, 2009
    same problem here!!! im so fustrated!!!
  • funkymunky11 Mar 27, 2009
    same!! help!!
  • JJ sax Apr 17, 2009
    Just bought M-Powered 8. Installed. Can see everything, add tracks, etc. When I hit playback I see that there is sound registering next to my sliders but no sound. Checked all my connections, mad sure wasn't muting anything, checked volume....nothing.
    help....
Try putting in a new sound card
Posted on Apr 18, 2009
What i/o do i need to hear my tracks through protools
It depends on what version of Protools you are using. And also on what it is running on, PC or MAC. Starting with v9 Protools is hardware independent. Which means and audio interface (I/O) should work just fine for listenning to tracks from protools. Depending on your computer it will support direct audio or core audio. make sure the interface supports ASIO as that is the standard and default way to go
Dec 26, 2011 | M-Audio Fast Track USB (FASTTRACK) Audio...
Hello There, I just bought the Rode NT1-A, and I am trying to record in protools, but i'm not getting any levels whatsoever. I'm plugged in to an MBOX, in the XLR, I have Phantom Power turned on,...
It sounds like you have done everything right. It would be a good idea to check both the mic and Protools system separately. If you can, verify that the mic works using another device such as a mixer. Also try getting a level into Protools using another mic, preferably a dynamic which doesn't require phantom power. If you are trying to use an original MBOX under Windows 7 or the latest version of OSX then it may not work at all.
Sep 19, 2011 | Rode NT1A Professional Microphone
I can record voice, but no guitar. Just as many people on this forum, but i didn't saw a proper answer for my problem. I can hear my guitar im using pro tools SE. The light on my fast track lights up,...
In Protools go into hardware setup and make sure that your interface is being read properly. It may be set to something other then your fast track. Then, in the MIX window make sure that your input is set correctly. If your microphone is plugged into input 1, your input on your protools track should correspond to that.
Sep 06, 2011 | M-Audio Fast Track USB (FASTTRACK) Audio...
I am not able to install protools in my Mac. My os is 10.4.11. I have downloaded the drivers needed for the OS but it gives me a pop box stating fatal OS.
Pro-Tools 8 and above requires an Intel-based Mac running OS 10.5.5 or later. The newest version you can use with Mac OS 10.4.x is ProTools 7.4, and the oldest version that will work with your hardware is 7.1. The complete system compatibility list is on the Avid site.
If you meet compatibility requirements, but get an installer error, you may have a corrupted download - try downloading again with no other network traffic from that computer during the download. If I read the download page correctly, most of the downloads are upgrade patches for previously installed versions rather than full installation packages. Attempting to run these without the older version in place will generate some sort of error. - how gracefully it is handled depends on the style, skill and diligence of the programmer.
You may also want to do a file system and permissions check on your computer with Disk Utility to make sure there are none of those problems causing hangups.
Dec 22, 2010 | M-Audio Fast Track USB (FASTTRACK) Audio...
Running digi 001 on windows 7
i got digi 001 running on windows 7...
i left my xp on hard disk while installing win 7. it kept xp on folder windows.old folder. in control panel i saw digi as multimedia adapter wich system couldn't recognice. hit "change settings" -> driver -> update driver
used my old windows to search for driver. it found "Dalvin.sys" driver for adapter. installed that. after that windows recogniced digi 001.
downloaded "digidesign asio 6.11" driver installer for win-xp and ran it.
and bingo - it works!
in every step windows was complaining and asking do i want to do this. just yeah'd everything. as i just had a clean install of win 7 i just thought whatta heck i can install everything again if it would not work, but it did.
so in a nut shell:
1: install Dalvin.sys in control panel for digi 001
2: run digidesign asio 6.11 driver installer for win-xp
for me it worked but i absolutely take no responsibility if you mess your system with this! at least reaper got a sound out of it. i haven't tried to record anything yet. but asio settings seemed to work as they used to do in xp.
- veikko-antero
Mar 17, 2009 | Digidesign Mbox 2 Barebone
Mbox cannot start new session or load in old sessions.
Digidesign website had the answer....go to windows,show workspace and change the settings for your relevant disc from transfer T to R...record in the A..audio column.
Thanks  Bobcat8
Oct 07, 2008 | Digidesign Mbox External Sound System
Mbox problem (no input,output)
i'm running os 10.5.6 w/ protools 8.0 and the original mbox. i had the same problem. protools opened and seemed to work except there was no sound from either analog outputs or headphones. this worked for me:
1. shut down computer
2. unplugged all usb cables except keyboard/mouse
3. restarted computer
4. re-plugged usb cable from computer to mbox
5. opened protools session
6. hit play and now i'm hearing sound and everything seems normal.
i hope this helps everyone else
Oct 03, 2008 | Digidesign Mbox External Sound System
Setup
plz give solution how to driver install
May 31, 2008 | Digidesign Mbox External Sound System
2488 to pro tools
There is no way to 'sync' with protools from the 2488. In order to use your 2488 tracks in protools you have to first export your tracks as wav files and move them to your computer via usb and then import them into protools.
To get Protools files into your Tascam 2488 you'll have to export your Protools files into mono wav files first. They must also have a sampling rate of 44.1KHz and can be either 16 or 24 bit. Then load these files into your 2488 via usb and import them into tracks on the 2488.
Nov 21, 2007 | Tascam 2488 Portastudio Multitrack...
Computers & Internet Logo
2,199 people viewed this question
Top M-Audio Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
