Question about Hitachi 53UDX10B 53" Rear Projection Television
My hitachi 53udx10b tv is out of focus.
When i do the magic focus, the #4 appears on the screen during the green portion of the magic focus?
  • Robert Katman Dec 25, 2008
    I have the same problem. I have red and green ghosting that is worse on
    the right side of the screen. Magic focus has no effect and ends with
    #4. I tried service mode but cannot move the red grid lines. Now I'm
    stuck with the 9 cross-hair screen. Does anyone know where to find the
    "little blue" reset button inside the 53UDX10? There doesn't appear to
    be any screws to remove the front panel as suggested for other models
    of Hitachi rear projection TVs.
    Problem Solver:
  • 7 Answers
Rojamon,
That #4 error is listed as "overflow," and I got a"ROM overflow" errorwhen I tried to save my adjusted convergence data.I don't know whatthat all means yet, but if I figure out my problem,I'll post backhere. I've read here and elsewhere that the out-of-focusproblem comesfrom bad resistors or amps on the convergence board. Youcan tryservice mode to adjust convergence. Press the Magic Focusbutton, andthen press it again to stop it, and then press the Statusbutton onyour remote. Here's a link to the manual convergence procedure (scroll down).
Posted on Dec 27, 2008
The green projection tube is mis aligned. it was
maybe convergence problem. Contact tech support with this #4 display
Jun 03, 2010 | Hitachi 57SWX20B 57" Rear Projection...
Adjust the color in a hitachi 43F300
The below convergence procedure was copied from: http://www.espnhd.com/voice/showthread.php?t=3736
Manual Convergence for the Hitachi
1) Receive an NTSC signal.
2) Press Magic Focus to begin magic focus
3) Press magic focus again during the magic focus process to get the ?stop? screen
4) While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and
the service grid (64 point grid)
5) When you first get in here? I believe red is the selected color by default (it is flashing).
6) To choose other colors to converge, use the following buttons on the R/C:
a) ?STATUS? - Green
b) ?0? - Red
c) ?ANT? - Blue
7) Start from the center of the screen and work your way out on one color at a time. I adjusted red across the
whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
may want to go back and adjust some red again? etc. until the convergence looks good.
(a) Use 4, 6, 2, and 5 on the R/C to move the cursor position(dotted lines).
(b) Use thumb stick to move the convergence point color.
** There have been other posts in here to tape together the color filters found in the Avia DVD to help converge
lines more easily. I have used this method, and it works well for adjusting to a greater detail. Basically, you put the
red filter next to the green and adjust your red to the green line both horizontally, and then vertically. Then you do
the same with the blue next to the green. Some people recommended you should be at normal viewing distance. I
did mine from just a few feet back from the set. Maybe my eyes aren?t as good? maybe I just felt like it worked
better this way. There are some other posts also recommending using binoculars. I think it?s great that people
suggest things to make the process easier? but my girlfriend would think I was insane if she saw me with
binoculars on the couch adjusting the convergence. I don?t know? whatever works best I guess.
8) I did not adjust the green at all. I use the green as the guide and did not adjust the location of any green point.
This is highly suggested unless you have geometry problems.
9) When going along the lines and adjusting, you may run into the problem of getting an ?S? curve on the line.
You?ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the
line between the points will not straighten out (it bends between the points). To fix this, the manual recommends
going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is
also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in
(13x9) mode (64 point). If you have serious problems, the grids work as:
3x3 - ?coarse?
7x5 - ?medium?
13x9 - ?fine?
10) To get to each of these patterns use the following on the R/C: (only if you need to)
1. (3x3) Press ?STATUS? 5 times (only works when DCU is in uncorrected state)
2. (7x5) Press ?0? 5 times
3. (13x9) Press ?ANT? 5 times
11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point? depending on where
you start, work your way up, and always finish on the 13x9
12) When finishing up the 13x9 mode, to get additional ?grids? on the edges of the screen, press the PIP CH button
on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence
as necessary. To exit, press PIP CH again.
13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed
to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write
displayed data to ROM.
14) DATA WRITE TO ROM will take approximately 4 seconds and no picture will be displayed.
15) Green dots will be displayed when operation is completed.
WARNING: YOU MUST DO THE FOLLOWING STEPS TO COMPLETE MAGIC FOCUS
INITIALIZATION!!! THERE HAVE BEEN MANY POSTS THAT PEOPLE HAVE HAD PROBLEMS
WITHOUT DOING THIS STEP BECAUSE THEY LOOSE MAGIC FOCUS!
16) Press MUTE to return to convergence pattern, then confirm again convergence is acceptable.
17) Press PIP MODE and then PIP CH to initialize Magic Focus. The initialize operation starts and several
windows appear during this operation. It takes about 30 seconds or less.
18) When green dots appear, initialize operation is finished.
19) Turn power OFF.
21) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just
to make sure the magic focus still works (and that you did the last few steps properly)
Hope this helps
Dec 15, 2007 | Hitachi 43F300 43" Rear Projection...
Magic focus error Hitachi 52
The model number you have selected here does not have magic focus--if you really want a answer post the correct model number.
SD TECH
Dec 12, 2009 | Hitachi 52LDX99B 52" Rear Projection...
DOUBLE IMAGE HITACHI ULTRAVISION TV
Ok, I would suggest before you buy anything from anybody is to try to do a manual convergence.
a) ?STATUS? - Green
b) ?0? - Red
c) ?ANT? - Blue
3x3 - ?coarse?
7x5 - ?medium?
13x9 - ?fine?
19) Turn power OFF.
Oct 27, 2008 | Televison & Video
Convergence ICs
Well if you are not a repairman you should not do this kind of job yourself.
If you decide to service your TV, remember to keep it unplugged for one hour before working on it.
Check this link here to find sellers for the kit and illustrated procedures.
Here I am reporting convergence procedure from website above.:
" Manual Convergence for the Hitachi
a) ?STATUS? - Green
b) ?0? - Red
c) ?ANT? - Blue
3x3 - ?coarse?
7x5 - ?medium?
13x9 - ?fine?
19) Turn power OFF.
to make sure the magic focus still works (and that you did the last few steps properly)"
Perform full convergence procedure before replacing ICs.
To know if an IC has blown you should test the small fuse at the base of the IC.
Jul 13, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Hitachi 53uwx10b Convergence
You must have the original remote to do complete convergence adjustments. Remote method: Press MAGIC FOCUS button on front panel to start the magic focus. When magic focus is running, press MAGIC FOCUS again. STOP should appear onscreen. Immediately press RECALL or STATUS on the remote (must be pressed before STOP vanishes). The set is now in DCAM (Digital Convergence Adjustment Mode). Manual method: Remove the front grill and access panel or reach around from the back and press the little pushbutton located in the front left corner of the PC board, next to the Digital Convergence Module.
Once in DCAM, the remote buttons STATUS selects green, 0 selects red and ANT selects blue. 2,4,5 and 6 move the cursor and the thumbstick makes the corrections.Make all necessary corrections and then press PIP MODE. The words ROM WRITE? appear onscreen. Press PIP MODE again to store settings. When green dots appear, press MUTE to return to convergence pattern. Press PIP MODE (ROM WRITE? appears again) and then press PIP CH. This will Initialize the internal sensor data positions. When INIT finishes, press POWER on the TV and convergence is complete.
Mar 26, 2008 | Televison & Video
Blurred picture
try the focus adjustment knob on the back of the flyback transformer....if that does not work...order a focus block
Feb 03, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Blue and Green Bar
run magic focus, If you get a error 4 during the magic focus, that is often an issue with the convergence
Feb 01, 2008 | Hitachi 51F500 51" Rear Projection...
Out of focus
Rach, if it doesn`t move from green to red to blue in Magic Focus then there is a problem with the convergence IC`s and probably one or more support resisters. These components will have to be replaced, questions? ask away, BMW Rider
Dec 14, 2007 | Hitachi 57F500 57" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
285 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
