Question about Gateway 7320GZ Notebook
Gateway 7320GZ restore problem
I have the restore DVD and it FREEZES I read somewhere I need to reset the BIOS and disable the hyperthreading.. can you walk me thru the steps to do this???
It is not the HD .. if I try to load a differnt XP CD (from Dell) it will load all the way thru and allow me to use windows ..temporarily ..just wont let me authorize the license.. so I think its the CD from GATEWAY.. BUT they have sent me 2 separate CDs or DVDs and same issue..
you can reach me direct at sender911@aol.com Thanks and Merry Christmas :)
  • tman1362 Dec 30, 2008
    I have the exact same problem with my restore disc. It would be great if there is a solution.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 327 Answers
Are you able to do a system restore back before the upgrade which I am almost sure you did right, take the computer back in time to the upgrade you were able to do with it, like if you had xp upgrade to vista, you don't need the 16 digit number, if this is windows that is, if this is a gateway computer this of course wont work.
Posted on Apr 28, 2017
  • 82 Answers
SOURCE: DVD Rom Drive Won't Play Some CDs...
Couple of possiblilities. Hardware or software.
You can go here to get the latest drivers for your system , just put in the serial.
http://support.gateway.com/support/drivers/dlcenter.asp
Or here
http://support.gateway.com/support/drivers/ddaStep.asp?platform=10022&model=10651&os=&type=&st=browse
If it is listed correctly in the system , it is probably starting to fail. You can try cleaning the laser lens GENTLY with a cotton swab and alcohol.
Also you can try and flash the firmware of the drive. The format of DVDs change slightly over time sometimes making newer ones unreadable. Here is a site with flash utilitys for your drive.
http://tdb.rpc1.org/#GSA4082N
If you still have issues , you may need to replace the drive. Cheapest one I could find was $179
http://www.notebookparts.com/products/description.php?II=11272
Might be cheaper to go with an external one if you can get one cheap.
Posted on Mar 04, 2009
  • 134 Answers
SOURCE: gateway driver issue
you should try getting the driver again but this time dont rename it pls.maybe that would work.
Posted on Jul 13, 2009
SOURCE: When I unr on my laptop Gateway NV7802 th system
its sounds like your memory card remove them and re-install that should work
Posted on Nov 28, 2009
  • 37 Answers
SOURCE: Gateway 7320Gz has lost its way. I try to
Go into bios and disable speedstep. Your system is overheating.
Posted on Nov 30, 2009
  • 1752 Answers
SOURCE: I need the bios and flash program for a gateway
There is no such thing as a BIOS virus. However, there are such things are boot sector viruses. Before you reinstall XP again, wipe the hard drive completely by deleting and recreating the primary partition.
Posted on Dec 17, 2009
Bsod have a Asus notebook laptop K50I, need to disable bios. don't know. need a step by step walk through instructions. help thanks
Hiya
Do you have a manual for your Asus notebook If not
www.Asussupport.com type in your make model and operating system and look for the manual
download it and save it to desktop documents or a pendrive or burn to cd very usefull for future reference
and you will prob need adobe reader installed ( Its a free download ) to be able to read the manual
Dec 18, 2010 | Computers & Internet
RECOVERING GATEWAY LAPTOP WITH RESTORE DISC WE BOUGHT BUT IT FREEZES WHEN IT GETS TO THE WINDOWS XP HOME EDITION SECTION
I grabbed this from another site. It worked fantastic, give it a try and it might fix your problem, I know it helped me tones after spending nearly 2 days playing with a similar sounding problem as yours.
URL: http://forums.techguy.org/hardware/582490-freezing-during-full-system-restore.html
Gateway Laptop Freezes during System Restore
Had the same problem, turns out it's a well known issue to Gateway and Microsoft it's due to "SpeedStep" and it must be disabled. Here's the chat log with Gateway tech support:
do these steps to disable SpeedStep in the BIOS Setup Utility and then run System Restore again on your computer.
1. Turn on the computer and begin pressing the F2 key in one-second intervals. If you perform this step correctly, you see the BIOS Setup Utility menu. If Windows loads normally, repeat this step.
2. In the BIOS Setup Utility, press the RIGHT ARROW key to select the Advanced menu.
3. On the Advanced menu, change the Intel SpeedStep setting from Enabled to Disabled.
4. Press the RIGHT ARROW key to select the Exit menu.
5. On the Exit menu, select Save Changes and Exit
6. Restart the computer and run System Restore.
7. After completing the restore, download and install the Critical Update for Windows XP (KB885626) package from the Microsoft Web site.
8. Once the KB885626 package is installed, re-enable Intel SpeedStep in the BIOS Setup Utility.
Myself...I am not going to turn SpeedStep back on it caused me enough time and hassle that I don't want to take a chance that it will screw something else up.
Hope that helps anybody that finds this issue too. I got here by Googling but didn't find a fix anywhere on the net until I chatted w/ Gateway. And if the Laptop was not under warranty, they wouldn't have talked to me. Sad that it's a well know issues and one cannot even search their site for "a known issue"
Good Luck!
Mike
Jan 23, 2010 | Gateway 7330GZ Notebook
P4MAM-L with CPU P2.4GHz runs at 1.2GHz only
Reset your motherboard BIOS. Open your computer casing where the motherboard lies in and then find the bios setting jumper, it should be located near the battery. To reset your bios, refer to the motherboard manual. :-)
Nov 13, 2009 | MSI P4MAM-L (MS-6787) 400/533 MHZ FSB...
Intel(R) Pentium(R) 4 CPU 2.80GHz
The processor you are talking about is a single core processor capable of Hyper Threading. (HT).
When you allow hyperthreading in the BIOS, Windows will show 2 ghost processors in the device manager.
If you are authorized to acces the BIOS setup,,enter the setup and look for HT or hyperthreading. If you disable hyperthtreading in BIOS, you will only see one processor in device manager.
Besides, if it is a dual core the BIOS must know.
Look on the case of the computwr where the Windows logo apperas, you may find mentioned :With HT technology. It used to be a boasting/selling mantra.
Hope it helps.
Sep 08, 2009 | Computers & Internet
How do you turn on HyperThreading on a GX260?
hyperthreading must be supported by the processor. If you don't have that capability, it won't work.
Jun 09, 2009 | Dell OptiPlex GX260 PC Desktop
How do I disable hyperthreading?
Hyperthreading is good. Why would you want to turn it off?
You can read about it here...Intel
Mar 20, 2009 | Gateway 508GE PC Desktop
Gateway GT5412 Hard Drive Restore
hmmm..bios is not an issue..should install cleanly, assuming the disk is 'washed' well, dried, and folded properly(partitioned)..
he.he
Feb 25, 2008 | Gateway GT5412 (232587) PC Desktop
Trying to turn off hyperthreading
You need to get into your BIOS. Go to CPU information. Highlight hyper-threading and enable or disable. Save and restart.
Dec 04, 2007 | E-Machines T3504 PC Desktop
Gateway 7320GZ Notebook Logo
198 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
