Question about Take 2 Interactive Outdoor Life: Sportsman's Challenge for Windows
Outdoor challenge mat instucions
We have recieved the WII outdoor challenge mat system and cannot figure how to hook it up please help
I have a yamaha htr 6130 receiver. Hooked up to it are a dvd player, cable box, and the t.v. Where (which inputs) do I put in the wii connections? I know it's the yellow, white, red ... but there are so...
Your problem is not the Yamaha reciever. You need to figure out how to switch your tv remote to the inputs you have tried to plug the Wii into, Your TV remote should have some sort of "source" or "input" selection button, or it may have a row of buttons that are labled. Without knowing the brand of your TV or seeing the remote, I can't be more specific, but clearly this is a tv issue. You could also use the video out on your 5.1 reciever, but first solve the tv remote issue. Keith
Feb 21, 2011 | Yamaha HTR-6130 Receiver
DDR3 for Wii - song ends before arrows start
From Konami's website. It fixed the problem for me.
Why does my DDR game fail as soon as it starts?
If you are playing on the Wii, this indicates the sensor underneath the plus button on your mat is stuck in the down position. To fix this, please unplug the dance mat from your system and then try shaking your mat out a few times as you would a rug. This helps move the sensors back into place and may fix your issue. If you are playing on the PlayStation®2 or the XBOX®360, this indicates the sensor underneath the start button on your mat is stuck in the down position. To fix this, please unplug the dance mat from your system and then try shaking your mat out a few times as you would a rug. This helps move the sensors back into place and may fix your issue.
http://konami.parature.com/ics/support/default.asp?deptID=15044
Dec 25, 2009 | Konami Dance Dance Revolution Hottest...
Dance mat does not work
I had the same problem. I got the solution from a friend. Plug the mat into a different console on the Wii. I plugged it into the last one and now it works perfectly. Good luck!
Aug 20, 2009 | Konami Dance Dance Revolution Hottest...
DDR wii mat!
There are 2 places to open on the top. One is a memory card slot the flap infront of that one is where the mat plugs in
Jul 25, 2009 | Konami Dance Dance Revolution Hottest...
How to hook up the dance pad to the wii? Where do you plug the mat in? Ther is no plug to match the mat.
If it is a wii dance pad the hook ups are on the top. They are round with one flat side. If you have a dance pad that is supposed to go to the wii or xbox you are going to have to conact them and get an adapter. There should be a 1-800 number on the box.
Mar 12, 2009 | Nintendo Wii Dance Dance Revolution DDR...
Wii Dance Mat Instructions
On the top of the Wii there is a hatch. Underneath it there are 4 slots to plug in Gamecube controllers. Try plugging the dance mat into there.
Feb 28, 2009 | Nintendo Gamecube / Wii Deluxe Foam Dance...
Hooking a Wii to Dish Network reciever(not a hd tv)
It sounds like you have a pretty new TV. This means that there should be multiple AV jacks in the back for setting up your many components. Plug in the receiver into #1, the Wii into #2, and any other equipment you may have (DVD, VCR etc.) in the same way. You should then use the original TV remote to switch between Video 1, 2, 3 and so one for each compnent you want to use. The button on the remote will be labeled video, tv/video, input select, or input, something like that.
Hope this helps!!
Dec 29, 2008 | RCA HD52W59 HDTV Projection Television
I can't seem to turn on a mat i bought on amazon..HELP!
I'd like to help you but i have the same problème with mine bought on amazon for christmas.
I haven't figured out the problème. Still working on it!!!!!
Dec 23, 2008 | Konami Dance Dance Revolution Hottest...
Take 2 Interactive Outdoor Life: Sportsman's Challenge for Windows Logo
79 people viewed this question
Top Take 2 Interactive Video Game Consoles & Games Experts
shaun
shaun
Bill Boyd
Technical Bulls
Technical Bulls
Are you a Take 2 Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
