Question about Fuji FinePix A205 Digital Camera
No display, will not take photos
The camera will come on but it does not have a display and will not take pictures. while trying to take pictures the camera did take video. Did not know that the video was taken until I put my pictures on my computer and saw that the video was there. the camera is a fujifilm finepix A210. without the display you also do not have a menu reading which makes it almost impossible to trouble shoot. The only thing you can do is push the buttons which does not seam to respond.
SOURCE:
t00nz
  • 4738 Answers
SOURCE: fujifilm finepix a303
This sounds like it might be a defective CCD imager. If so, Fuji should fix this for you for free. This is regardless of your camera's warranty status. However, this advisory repair is currently limited to the US. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/12/fuji-digital-cameras-showing-black.html
http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportProductContent.jsp?dbid=839010&prodcat=2147483647&sscucatid=664262&quicklink=true
Applicable cameras include:
F303, F410, and F700
Posted on Dec 23, 2007
cammedic
  • 667 Answers
SOURCE: READ ERROR
I would try another card with the camera to see if there is a fault in your camera or the USB cable. If the other card works fine, then there nay be some compatibility issues with the M type XD card in your camera. Just for reference: I have several older FujiFilm digital cameras that I still will not use the newer style cards with. Newer meaning the 'M' and 'H' series cards. Fuji says they will work fine, but I'm always leery of newer techno gear being 100% compatible with older stuff.
Here is a link to Fuji's memory card chart: FujiUSA
Posted on Jan 15, 2008
  • 3 Answers
SOURCE: I got a pink Fujifilm Finepix Z20fd and pictures won't download
You don't have to use the software that came with the Fujifilm. I have the same camera. If you're on a laptop that has a slot for SD cards, (if you have an SD card) you can just put your card straight into your computer and load the pictures that way. Also, if you have an SD card reader, you can use that. And if you're on a desktop without either of those options; once you plug your camera into your computer, go to your start menu and click 'My Computer,' then your camera should come up as a removable disk device in the folder. From there, you can drag and drop the pictures onto your desktop or your My Pictures folder.
Posted on Jan 08, 2009
SOURCE: My FINEPIX s1000fd fujifilm camera
Try these:
1) Make sure the lens cap is off. When the camera fires up, if it feels any resistance, it will stop zooming and tell you "zoom error"
2) Recharge or fit new batteries. Use 2700 power if you can get them.
3)Is there a bit of dirt between the zoom part and the camera body? I had this problem after my camera had been in my overcoat pocket. I cleared it out with a stiff artist's brush. Do NOT use WD 40 or similar, as I found to my cost on another camera. It eventually seeped through to the works and made all the pics cloudy!
4) Hold the camera body in one hand and gently wiggle the zoom part from side to side and up to down.You will hear a quiet click in the mechanism.
I have used my S1000fd lots now, and the initial "zoom error" problems have stopped.
It's a fine little camera, I especially like the 12x zoom and the live histogram. Mine has taught me lots about photography.
Posted on Apr 01, 2009
Obertelli
  • 3006 Answers
SOURCE: My fujifilm finepix s5000 SN 4FL37025
This is the classic symptom of a failed CCD sensor. The only fix is to have the sensor replaced, but as the camera is around six to seven years old now any repairs will not be cost effective and you will likely have trouble sourcing the parts as Fuji stopped making their 3MP sensor many years ago. New, old stock sensors may also have degraded to the point where they are either faulty straight out of the box, or will develop the same fault within a few months of being powered up.
Sorry, but your camera has reached the end of it's useful lifespan: five years is pretty good going for any digital camera and six to seven is really exceptional. Digital cameras simply do not last anywhere near as long as many of the film cameras which they replaced.
Your only real choice is to buy a replacement, but if all you need is a similar technical specification to your current model then there are plenty of cameras for less than £100 (around $175 in OzDosh) which will do at least as good a job as your present camera. Just don't expect a sub £100 camera to last anywhere near even five years though.
One other advantage of an update is that you'll finally be ditching the expensive and highly inferior xD memory cards which were basically repackaged and slightly tweaked SmartMedia cards. If you buy a new Fuji then you'll find that they all take SDHC cards now (back compatible with SD cards) although they often still accept xD cards as well.
Sorry I can't be more positive, but I hope that I've still helped you. All that I ask in return is that you take a moment to rate my answer.
Posted on Jan 11, 2010
How many pictures does the A1250 camera hold
It depends upon the size of the memory and the picture quality.
The camera's display normally displays the number of photos taken and or remaining number of photos that can be taken.
Jan 08, 2013 | General Electric A1250 Digital Camera
No image shows when I take picture
Usually the photo is displayed for a short period of time. Try the setup in the menu. There should be an option for previewing recent pictures.
Jun 20, 2012 | Fuji FinePix S2 Pro Digital Camera
Fuji camera screen does not display picture even when screen is turned on when taking picture. but screen shows picture when you view pictures already taken
Hi dear, you need to see the manual (http://www.retrevo.com/support/FujiFilm-S700-Digital-Cameras-manual/id/2488ag805/t/2/)
Some camera only use viewfinder to shoot photo,The LCD is for setup and display photo only.Because it's off it will save a lot of battery power so that you can shoot more photos.Check it out in the manual.Have FUN!
Jan 21, 2010 | Fuji FinePix S700 Digital Camera
New xD M+ card won't work in the digital photo frame.
Alot of the digital photo frames will only display images up to a certain resolution. There is a good chance your camera resolution is too high for the photo frame. try change the settings on your camera to 3mp or so and take a few photos and see if they will display.
Jun 16, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
Panasonic lumix Fz28, Error "Thumbnail is displayed"
I have this problem too, but only when I try to view pictures I have taken on a later model. Photos taken with the FZ28 view as per normal.
Jun 14, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
I am unable to transfer my digital photos to my computer
Dear Sir
I uninstalled the Adobe System and have obtained my pictures by clicking 'my computer' etc.
Yours sincerely
Derek Hickie
Jan 17, 2009 | Cameras
Canon PowerShot A510
Your LCD display might have switch off by mistake.
Press on the display button in the camera.
Jun 09, 2008 | Canon PowerShot A510 Digital Camera
Unable to view downloaded photos on camera screen
I had a Camedia 560 and it had this problem. Take a picture and then look at your memory card or camera from the computer. I think you will see that there is a complicated structure of folders - the pictures are in one folder and there is some kind of index file in another folder. The camera cannot display pictures restored from the computer unless you restore the index files as well as the picture files. Sorry I can't remember the details, but one way to do it would be to copy every last thing on the memory card. Not very convenient. This is a design flaw - my new camera doesn't have the problem and will display any picture I copy to it provided it was taken on the camera and not rotated or cropped. It doesn't mind other editing like putting a caption in the photo with a paint program. Panasonic Limix.
Sep 10, 2007 | Olympus Camedia C-60 Zoom Digital Camera
Black screen when viewing photos taken
When the picture does not display - do you see the normal text and icons that you would expect to see? Or, is the screen completely blank?
Feb 22, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Fuji FinePix A205 Digital Camera Logo
70 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
