Question about Maytag NFW7200TW Front Load Washer
NFW7200TW washer won't engage spin cycle
Hello, we have an Amana NFW7200TW washer that has been showing 8 min left in the cycle for about 20 minutes. It spins slowly one way with what sounds like the pump on and then spins the other way for about 30 seconds then does this all over again over and over. Any suggestions? Have tried turning it off and on again and just trying the spin cycle but the same thing happens again. the spin cycle does not seem to be engaging.
  • Anonymous Mar 22, 2009
    Same problem....spin cycle is stuck on 8 minutes and does not seem to fully engage. Just keeps going and going- first one way slowly, then the other....but never really picks up speed to spin the clothes dry.
We had the same problem with the same model machine and solved it.
Our machine was a month old and started getting stuck at minute 8, so we arranged service calls through Amana customer service. Long story short, the first three service reps couldn't figure out the problem. Two of them called Amana's in-house tech support line and the Amana techs didn't know what the problem was. The fourth repairman was smarter than his predecessors. He called the Amana in-house tech line, spoke to a rep who didn't know what was wrong, and then called in again. He explained that. based on his experience, some in-house techs knew more than others. That turned out to be the case because on his next call-in to Amana, that rep knew exactly what the problem was and recommended replacing the main computer board module. The repair guy ordered and installed the part. The machine has been working perfectly for a month.
Posted on Dec 17, 2009
  • 2 more comments
  • momscheap Aug 05, 2011
    We just got done fixing our machine without having to replace the $150.+ pump!!
    step 1. Make sure there is nothing clogging the drain to wall hose (kink,hairball etc.) by hooking up a shop vac to the end.
    step 2. repeat with tub to pump hose (we found a coin there).
    step 3. remove the pump from the machine and inspect the impeller for foriegn objects (like a piece of broken clothespin).
    step 4. if all of these fail, take the pump apart. It's not hard, and that is where we found the heart of the problem- the pump impeller is magnetically driven, we have a well with high iron content in the water. after removing a few screws and carefully taking the impeller & drive out, we found a large mass of iron laden mud was caked around the drive shaft !! After thoroughly rinsing out the mud, drying the parts and carefully reassembling the pump, hoses, etc. I have just started my first load of clothes in a week.
  • Jmendez Dec 21, 2011
    I would like to add that the details provided by momscheap was spot on. I went online looking for repair hints off the Amana website and was unable to find anything helpful only a replacement pump part number. I had a similar issue with the OD display and the washer being full of water. I remove the pump and disassembled and found an obstruction causing the OD display. One word of caution, make sure to wear gloves! Once you remove the back panel of the washer, the location where the pump is located is against a very sharp edge. Be prepared to have quite a bit of water come out once you disconnect the discharge hose (gray/white hose). As momscheap mentioned, having the use of a shop vac to remove all the water is an important first step! The De-assembly is very straightforward.
  • chaoticrash Aug 13, 2013
    MOMSCHEAP was right! I took the back panel off and located the pump. Once I dismantled the pump and took of the white portion off the black and white pump there she was an old quarter lodged in it. Thanks, saved me a bunch.
  • patsy hill Sep 15, 2013
    same happened to me .. But still won't spin good.
I have an Amana front load washer Model NFW7200TW it was making a loud rattling, growling noise when I heard it the first time. I loaded a 2nd load and this time during the spin cycle it wouldn't even start to spin, I could hear what sounded like the washer trying to energize the pump to remove water but nothing would happen. The error code nd flashed on the display which means no drain. I disconnected the hoses and removed the pump. I could see a quarter had gone through the washer and was lodged against the impeller of the washer pump. I used a needle nose pliers to remove it. Reinstalled the pump and it is working fine. Hope this helps someone.
Posted on Jul 31, 2012
  • Mike O Jul 31, 2012
Mine did this same thing last night, but was stuck at 34 minutes (between regular cycle and rinse). I was worried, but the spin finally kicked in after about 10 minutes.
It may be that it can't get the load balanced - if this reoccurs try removing some of the laundry and see if that helps. If it still refuses to spin, take out all the laundry and see if it will complete a spin only cycle. If THAT fails, then there's something wrong with it other than an unbalanced or overloaded load problem.
There's a way to get it to do a diagnostic cycle, I do not have the info at the moment, but I will be able to get it later this evening.
Posted on Feb 18, 2009
I have the same washing machine. The only time I have experienced this problem is when we overload or wash heavy blankets. When this happens, the washing machine is trying to redistribute the load so it will spin balanced. Try taking some of the wet clothes out. This always works. Hope this helps....
Posted on Oct 05, 2009
  • 750 Answers
Hello tjoudrie
Welcome to Fixya
My name is Huum,
You said, You have an Amana NFW7200TW washer that has been showing 8 min left in the cycle for about 20 minutes and will not stop!
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Check timer motor.If timer motor is not operating then replace this.
If the timer motor motor runs but timer will not advance, replace timer.
Here at this site you can find the schematics and diagrams. Plus buy parts!
Find the diagrams under the title sub componets
http://www.searspartsdirect.com/partsdirect/getModel!retrieveModelDetails.pd?modelNumber=NFW7200TW10&productCategoryId=0153200&brandId=1268&modelName=RESIDENTIAL-WASHER
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
NFW7200TW washer won't engage spin cycle - moz-screenshot.jpgmoz-screenshot-1.jpg
Posted on Dec 25, 2008
My amana front load washer, model NFW7200TW won't drain it gets down to 8 min of cycle and stop and display nd code. Check pump, fine also I can open washer door when it get stuck in this mode
remove the drain hose from back to see if there is any foreign object stuck in there , if washer faults out on code its common for door to unlock
Aug 16, 2016 | Amana Washing Machines
Amana front load washer error E3
https://www.youtube.com/watch?v=fx7Lrj7gEy4
Jul 06, 2015 | Amana NFW7200TW 27-in. Washer Front...
Amana nfw7200tw will not run. all wash settings read 1 extra minute. Is this a code or something like that?
have you tried unplugging and resetting the computer, it seams hung in the last cycle, can you open the door and remove all inside, reset it again and try it, the washer sounds like it has water in it and needs to drain first,if it is full of water you have to drain it, by moving it and taken the drain hose off the pump,if that's the case i recommend flushing the inside with hot water and some bleach right through the front door or reservoir on top,after you get it emptied, the water sensor may be full of soap, by the way the soap your putting in this machine should only be about a 6th of a cup, I know it sound crazy but a half or a 3rd is to much, for the sensors, try this an get back to me,Matt
May 01, 2015 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Hi, I have an Amana front load washer NFW7200TW that will go through entire cycle but won't spin- cycle ends and clothes are very wet. Unlike the other posts I read, mine shows no error code nor does the...
I have a similar problem with a Kenmore top loader washing machine.It turned out a problem with the main shaft of the drum; it wears out and caused drag on it. at one point i installed a washer or spacer between the shaft and drum it worked for a while and the problem came back again. it is a mechanical problem and it is present with other brands that share the same drum and shaft.
Finally I end up buying a different brand this time a LG .
Mar 08, 2015 | Amana Washing Machines
How do I fix it?
Probably a loose balancing block. this the only thing that comes to mind.
Oct 28, 2014 | Amana Front Load Washing Machine Washer...
E3 trouble code
E3 Error: Machine control is attempting to drive the motor but is not seeing any tacho response. Visual check shows motor is not moving. (Locked, Hall Sensor fault). The hall sensor is a circuit in the motor. the motor will need to be replaced. Here is a link to the motor.
Mar 22, 2014 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Washer will not advane from wash to rinse
It sounds like, when the dial gets to the pump stage, the contact expected to pump the water out isn't making contact. That could be a burnt contact within the controller, or a loose wire to to the pump from that section of the controller. Once the weight, or water level was low enough from your pumping it out, the sensor that checks the level/pressure allowed the spin. The problem could be on the control board too.
Here's an incomplete schematic I found:
http://www.doityourself.com/forum/electric-large-kitchen-home-appliances/474475-front-load-washer-amana-model-nfw7200tw.html
Jan 02, 2014 | Amana Front Load Washing Machine Washer...
Amana nav5805aww washing machine won't spin
You will need to replace the thrust bearing kit. Here is the part to order.
It comes with the instructions and is an easy fix.
Oct 30, 2012 | Amana NAV5805A Top Load Washer
3E error during rinse cycle on Amana NFW7200TW washer
E3 Error: Machine control is attempting to drive the motor but is not seeing any tach response. Visual check shows motor is not moving. (Locked, Hall Sensor fault). The hall sensor is a circuit in the motor. the motor will need to be replaced. Here is a link to the motor.
Oct 18, 2012 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Maytag NFW7200TW Front Load Washer Logo
6,632 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
