Question about HP Pavilion a800n (PP163AA) PC Desktop
So i was trying to change out the ram for a better on. while doing that i decided that i was going to clean out the insides, mainly cause its never been done. also while doing this, i took out the processor to clean it out aswell. when i put it all back together, and powered it up, the fans were running and in about 5 seconds it shut down. it didnt even get to the BIOS and didnt even kick on the monitor. after shutting it down it wouldnt turn back on untill after i unpluged it and waited for a really small green light to flash on the power supply. then plug it in and try again. but nothing changed, not even after putting everything back the way it was before i took out the ram. all i need to know is, how can i just get it to run?!?!?! its been stressing me out for about 4 hours now and i just have no clue on what i can do. i think it may be a processor issue because of taking it out and putting it back in. but i have no idea. HELP ME!!!
  • side501 Dec 25, 2008
    ive reseated the ram more times than i can remember, and i think that i may have touched the thermal paste, im not sure if that is a bad thing and ive touched it more than once.
  • 238 Answers
Are you hearing some beeping sound while turning on your computer? Is the type of your new Memory Card same as your old Memory Card? Try to check if the Power supply and Processor fan cables are properly connected on your motherboard. Take out your RAM and insert it again, make sure it is properly fitted on its slot. If you have 2 RAMs try the only one stick of RAM(Memory Card) first.
Motherboard
1. To know of your motherboard is ok then try to remove the RAM and turn it ON. If your hear error beeps then that's a good sign. Your motherboard is fine.
Memory
1. Try to clean the memory contacts using the eraser. I'm pointing about the gold contacts in the memory. Might be the dirt only that causes the problem.
Power Supply
1. Try to replace the power supply. It could be insufficient supply of power due to the lots of peripherals attached to your computer. The recommend PSU watt should be 500W to accommodate all the peripherals attach to the unit.
*Note turn off your computer while setting these up.
Posted on Dec 25, 2008
    President:
  • 1,179 Answers
Make sure the cpu is seated properly. It should only go in one way. Also make sure you have applied a good thermal paste between the cpu & heatsink. Check and reseat RAM. Then try rebooting. Hope this helps.
2 Suggested Answers
dapidc
  • 111 Answers
SOURCE: HP Pavilion a800n wont boot up
I think the processor is the problem, too.
Does the board beep? How is the beep?
Just try to remove it again. Make sure everything is placed properly when you put it back.
Also try to put old RAM back, to see if it is the new RAM is OK.
Tip
10 reasons why PCs crash-You must know tip 3
3 BIOS settings
Every motherboard is supplied with a range of chipset settings that are decided in the factory. A common way to access these settings is to press the F2 or delete button during the first few seconds of a boot-up.
Once inside the BIOS, great care should be taken. It is a good idea to write down on a piece of paper all the settings that appear on the screen. That way, if you change something and the computer becomes more unstable, you will know what settings to revert to.
A common BIOS error concerns the CAS latency. This refers to the Ram. Older EDO (extended data out) Ram has a CAS latency of 3. Newer SDRam has a CAS latency of 2. Setting the wrong figure can cause the Ram to lock up and freeze the computer's display.
Mcft Windows is better at allocating IRQ numbers than any BIOS. If possible set the IRQ numbers to Auto in the BIOS. This will allow Windows to allocate the IRQ numbers (make sure the BIOS setting for Plug and Play OS is switched to 'yes' to allow Windows to do this.).
on Mar 04, 2010 | Computers & Internet
Where is the main switch to shut off the power in the house? I was vacuuming and the power went out in various areas around my condo. I think I have isolated the breaker and want to change it but I do not...
In some condos/apartments the main breakers are located outside. This is because the meter and incoming service are some distance from the local panel. Perhaps your breaker isn't bad, but the additional load of the vacuum caused it to "trip" Unlike some brands the Bryant don't show a trip indication other than the handle moving. Try turning this breaker completely off, ( if it was tripped, it will click) then turn it back on. If you do locate the main outside, and decide to change the breaker inside, be sure to "lock out" the main disconnect while you're working on the panel.
Nov 11, 2010 | Bryant /murray Bj2200 Main Circuit Breaker...
Changed ram in acer netbook and now will not turn on
The quickest test, is to try another stick of RAM, or try the original stick again.
Laptops can be very fussy at what memory they work with. I have at least 5 models here (2 made by ACER actually) which refuse to use any but one specific type each.
You say that it won't turn on, but do you mean there is no signs of life at all? or it just doesn't actually boot (into Linux i am assuming).
Try the memory testing mentioned above, and if still no life, try again, but with any battery removed first (after removing the battery hold the POWER button down for 30 seconds - to remove any traces of old electric from the netbooks insides).
The most common problem with all laptops/notebooks/netbooks is a broken charger socket, and this would be the next thing i'd check for. It may just be that it could have broken by coincidence at the same time as you have decided to change the RAM.
Remove the battery, unplug the mains charger from the mains but plug it into the netbook as normal, and 'very' gently rock it from side to side just a fraction, to see if it's loose. Don't be rough doing this as the power sockets are always fragile. Remember you're not trying to see if you can make it move, you only want to see if it is already possible because it's broken away inside.
If it feels loose, now take something such as a wooden match, and gently see if you can see the centre pin in the charging socket move when touched. Any movement in there indicates a new socket may be needed - a good working socket should be solid.
Nov 10, 2010 | Acer Aspire One Netbook 8.9" Notebook
Hi, I have this mother board, in my pc running windows xp, i decided to put more ram in it one day, and it just quit working. It says No Signal Input or Cable disconnected. Everytime I turn it on it...
One continuous beep should mean power supply, motherboard or keyboard problem. Assuming you didn't change any p/s connections, it's telling you the motherboard won't start.
The most likely cause is that you haven't put the RAM in correctly - it's often difficult to add RAM because it's so hard to see inside there with everything connected. Or you may have dislodged something else while pushing things out of the way.
While working inside the case, leave the power cord plugged in at both ends to provide an earth, but turn off the power at the wall. This will help to avoid static damage.
You need to remove the extra RAM again and see if the PC works as before.
If not, you'll need to carefully check that the original RAM isn't loose, and that no cards were dislodged.
If it does work without the extra RAM, you know it wasn't plugged in correctly. Try again, very carefully plugging it in and make sure it clicks into the motherboard completely. [RAM sticks only go in one way, if they've been put in backwards they can be fried.]
See how you go.
Jun 20, 2010 | ASUS P4SGX-MX Motherboard
My d845 mother board dont display
Its probably caused by the RAM, have it checked. If you can do it yourself, clean the RAM as shown in the image below:
Install it back to the computer and turn it on. If problems persist try another RAM, it may already need replacement.
In case your computer has 2 RAMS installed, clean them both. To test if there is a busted one, install the one then turn on the PC, if it works shut down the PC. Then try the other one, if it works too then it just needs some cleaning. But if not, one of them needs replacement. You can still use your computer with 1 RAM, just don't expect the same performance as having two RAM. Resetting the CMOS may also help you in the process.
Please reply if this has helped you. Thanks.
Oct 26, 2009 | Compaq Evo D310M 845G P4 Motherboard
Computer slow
Sir,
The problem is caused for many reasons. One of the main reasons is virus infected. Install a good and full version of anti-spyware software and full scan it. Update the antivirus frequently and clean the unwanted files, registries etc..... using the cleanup tool from this site
Thanks
Good Luck
"Appreciate to rate as FIXYA"
Jul 07, 2009 | Microsoft Windows Vista Ultimate Edition
Monitor turn dark frequently
it sounds like your PC trouble, you may try (it is better to make sure the monitor connect other PC ok)
1) check PC ram, change ram sticks position if there are two ram stick, or change a new ram if only one ram inside. not fix go next
2) check VGA cable connection, reseat the cable. still not fix go next
3) if you use AGP VGA card change VGA cable to onboard VGA interface (setup bios VGA to onboard),
is this helpful to you olease feedback thanks.
Feb 11, 2009 | Acer Computers & Internet
it is possible you "Fried" the processor or something else. all it takes is a small static charge to kill those delicate circuits. dont wanna be all doom and gloom. i would strongly suggest you take this to a pro that can test all the hardware and find out. hopefully it's just a problem with your power supply. please let me know
Dec 25, 2008 | HP Pavilion a800n (PP163AA) PC Desktop
2 problems with Ps2
go inside your ps2 and dust it you heard me just dust it from the inside trust me this always works use a small cotton ball and dust the ps2 everything is going to work better no more slamming the ps2 on to your bed!being all angry i though mine broke but i went inside it for the heck of it and decided to clean it to see better then all of the suddeni made a sound i was freked i fin. cleaning it put it back together and bam good as new no freezes no pulling on the sony emblem to get the disk back! good as new!
comment me please
Jan 01, 2008 | Video Game Consoles & Games
HP Pavilion a800n (PP163AA) PC Desktop Logo
56 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
