Question about Symbol MC3000 Portable Terminal
White vertical lines
After powering-up the device for 3-5 minutes the screen display random vertical lines (whitecolored) and if powerwd-down then powered-up again it works fine for another 3-5 minuts then the same problem appears, please advice me how to fix it thanks
  • 53 Answers
The LVDS cable between the units mainboard and LCD is loose, or the LCD driver IC is on the way out. the only way to fix this is to reseat the cable or replace the mainboard
Posted on Nov 09, 2007
Samsung TV LN32A550P3F problems. About 4 minute after turning on screen displays some picture with vertical lines & a lot of louder white noise over the normal sound.
Please check sound on main power board. Could be a failing component that is heating and not functioning normally that is causing interference and thus the vertical lines.
Nov 18, 2016 | Samsung Televison & Video
Vertical line down screen
This problem can be caused by a lose connection between LCD and motherboard, however you can check it by opening the LCD or hinge bezel to ensure if there isn't any lose connection.
Oct 28, 2013 | Dell Vostro Computers & Internet
Flashing black and white vertical lines
Vertical lines in the display indicate a failing screen. New screens are expensive and not worth the labor and parts charges to repair it. It's new monitor time.
Jul 28, 2017 | Samsung LTN1535 15 in. HD-Ready LCD...
Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Jul 24, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
Plasma TV with vertical lines
chake to make sure it is hooked up right and not lose
Feb 02, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
White vertical line on left side of screen
I had a smililar problem after taking it apart i realised that i had screwed my mount skrews into the video main board and cracked it along with a few soldered wires, if you havent done any physical dammage to it try a firmware upgrade
Jan 20, 2008 | InFocus IN72 Multimedia Projector
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Jan 01, 2008 | BenQ PB6100 Multimedia Projector
Gateway laptop vertical dotted lines across the screen
Sounds like a problem with the LCD assembly or cable. You may want to reseat the LCD cable at the LCD end. It could be a loose internal connector in the LCD assembly.
Ron-
Dec 13, 2007 | Computers & Internet
White vertical line in the center of projected image
I have a Dell 2400MP projector that had the same problem of vertical white lines appearing over the screen.
This may seem like a simple solution, and I don't know if this will work for you, but the way I solved the problem was simply to press the bottom side of the projector, until the white lines disappear . Until now, the problem has yet to resurface.
Here's some simple steps:
1. Turn on projector
2. Connect projector to computer
3. Focus projector
4. If white vertical line appears, firmly press underside body of projector
5. See if vertical white line disappears
6. If not, try slowly pressing other parts of the body of the projector and see if white lines disappear.
7. If solution doesn't work, you may need to send it to the service center.
Hope this solution works for you.
Best Regards,
Ghazali Ridzwan
http://www.ghazaliridzwan.com
Nov 28, 2007 | ASK Proxima Proxima DP2000S Data Video...
Symbol MC3000 Portable Terminal Logo
99 people viewed this question
Top Symbol Computers & Internet Experts
Vish Iyer
Vish Iyer
George Etukudo
George Etukudo
Norman Al-Anbar
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
