Question about Philips Magnavox DVD/VCR Dual Player
I cannot get the dvd player to work with the digital converter
It seems I have tried every configuration in hooking up the digital converter box and I cannot get the dvd player to work in conjunction with the box. I am using an rf modulator. I can either watch TV with the current hookup but that doesn't allow me to play the dvd player. When I reconfigure, I get the reverse
5 Suggested Answers
SOURCE: tv/digital converter box & vcr-dvd hook-up
ATT:Max Parker GLAD SOMEONE ELSE COULD USE THE SOLUTION MIKE CAME UP WITH
IT'S ALWAYS NICE TO KNOW YOUR NOT ALONE IN THE WORLD
Posted on Nov 17, 2008
SOURCE: Connecting magnavox dvd/vcr player DV220MW9 to a 40 year old TV
What type of Inputs do you have on your TV. (ANT IN, S-Videio, RCA Video,RCA Audio)
If you only have a ANT In or RF Coaxial hook up you will need a RF Modulator
Posted on Feb 03, 2009
SOURCE: hook up of magnavox zv427mg9
I have a magnavox dvd recorder/vcr combo (ZV427MG9A) connected to my Sharp hdtv via hdmi cord, Can anyone tell me simple setup steps to make it record and play on either sides. I have read instruction book over and over and it is still not recording to disc or tapes. I also have Charter Cable connected. Can you tell me what do i need to do to make it work. H-E-L-P!!!!
Posted on Dec 29, 2009
Demonic-2011
  • 508 Answers
SOURCE: I'm trying to hookup my
Probably not. Better picture results are achieved with either S-Video, standard RCA AV cable (yellow-white-red), or YUV component cable (red-green-blue) (component output does not have audio - this requires extra cable to be connected). The video via either one of these 'AV' connections is stunning (based on a standard 16:9 LCD TV using a Panasonic DVD recorder).
RF tends to be lower quality - as opposed to AV/digital input. AV input/YUV component handles digital better. No one connects their DVD devices to their TV via RF (either directly to the antenna socket or with a modulator/attenuator) anyway. Because a VCR is mostly analogue, it will work fine with an RF connection, but DVD is digital, and so won't work as well, if at all.
RF also goes through the tuner in a TV, creating cross-interference, whereas AV is a direct input and is separate to the tuner.
I would say an RF modulator would not be designed to handle the output frequency that your DVD device generates. Throw the modulator out, or perhaps get another TV, or use RCA cables instead if the TV has AV inputs. Whichever is cheaper and easier, but don't use RF accessories except a standard antenna if/as required.
Posted on Apr 27, 2011
Receiving no signal with converter box
Where is the "no signal" coming from, the converter box or tv? If tv then unplug the dvd player and plug the plugs into the converter so the wires go from the converter into the rf modulator. set the tv up to watch dvds and try your channel scan gain. If it works then post again and we'll figure out the best way to connect the converter and dvd to the tv.
Jul 30, 2009 | Apex Digital (AL-A300ATX) 300-Watt Power...
Converter box
3/23/09 --- I don't understand why you would hook your converter box or antenna to your DVD Player. Converter box is only functional between an antenna and a vcr (and/or a TV). DVD Player hooks directly to TV (NOT thru a vcr, coding on dvd discs will screww up the signal and make it fade!) Good luck.
Mar 20, 2009 | Insignia Digital-to-Analog Converter for...
Hooking up converter box when i have a dvd player and direct tv
Hook your Insignia box between your antenna and your television. You still need the antenna.
Jan 01, 2009 | Insignia Digital-to-Analog Converter for...
Tv/digital converter box & vcr-dvd hook-up
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to www.google.com and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
Dec 04, 2008 | Televison & Video
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
Nov 02, 2008 | Insignia Digital-to-Analog Converter for...
Using the new Digital converter box on TV
I just bought an RF (2) switch box & now I just switch back & forth to watch DVDs or Digital TV. Thanks for your concern.
All my best wishes to all,
Michael
Sep 14, 2008 | Durabrand DVD-1002 DVD Player
Magnavox Converter Box
its not working because they haven't transitioned to hdtv yet....you don't need to hook it up til feb 17 2009.
Jun 06, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Panasonic DVD Recorder - Digital tuner stopped working
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
Mar 08, 2008 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Philips Magnavox DVD/VCR Dual Player Logo
32 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
