Question about Radio Communications
My uniden model uh036sx one is stuck on the squelch feature and i cant get it of help me
    New Friend:
I have a UH036SX so not sure if its exactly the same. If you open up the unit, there is a large black potentiometer near the base of the antennae. I found if I wound this counterclockwise by approximately quarter of a turn with a small flat blade screwdriver it reduced the squelch level to a better level. I suggest wind it down until the static is gone, then increase slightly to give the best level.
Posted on May 25, 2013
  • 1 more comment
  • Rob Law Feb 16, 2014
    This just makes the RX level quieter not adjust it.
    This only lowers the volume of the squelch not adjusts it, In my case anyway.
    Rx symbol still on all the time
    New Friend:
I emailed Uniden, this is the reply
Have not tried it yet
Please reset the unit:
Turn the unit off,Press and hold "[channel up] and [vol up]" buttons together at the same time and turn the power back on.After 15 seconds turn power back off then on
Posted on Feb 18, 2014
I have 2x uniden uh036sx-d uhf radios. both transmit well but only 1 receives clearly and loud. any ideas
Posted on Aug 30, 2011
Squelch is open all the time on uniden bc350a scanner
Have you turned the squelch knob all the way in both directions, to see if that helps?
If so, then you have to replace that squelch knob unit, with a newbie.
I hope this helps.
Cheers,
Peter
Nov 02, 2012 | Uniden Bc350a Nascar Police Scanner No...
The scanner is stuck in open squelch
Rotate the knob counter clockwise to close the squelch. If this does not work, remove the knob by pulling it off gently and make sure the "pot" is turning with the knob. Verify the knob and "pot" are not damaged.
Jul 19, 2010 | Uniden BC340CRS Base Scanner
The squelch will not turn down?
Sounds like your squelch pot is either shot or disconnected. If you're electronics handy, you can troubleshoot it yourself and replace the pot if necessary. You can also send the scanner to Uniden for repair. Follow the link below for troubleshooting help or to contact Uniden regarding repair.
BillB
http://support.radioshack.com/support_electronics/doc68/68646.htm
Jan 19, 2010 | Uniden BC340CRS Base Scanner
I don't have the manual for my Uniden Bearcat BC 855 scanner.
You can download/print the complete manual for your scanner by following the link below. It's a free download, and it provides detailed programming instructions. If you're programming a channel that is "empty" (showing 000.0000) just enter your frequency. Empty channels automatically show LOCKOUT but it clears with programming. The squelch setting will vary according to the strength of the signals you receive. Once you start scanning, turn the squelch down until scanning stops and you hear a hissing sound, then turn the control up slowly until scanning resumes.
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Dec 30, 2009 | Uniden BC248CLT Base Scanner
Acts like squelch is stuck
I had the same problem. Your board may be fried. I had to buy a new unit.
Jan 28, 2009 | Uniden BC248CLT Base Scanner
Unable to quit the squelch
This is an internal problem that can only be repaired by a technician familiar with Bearcat scanners. If you live near NJ, call 973-831-5900.
Dec 24, 2008 | Uniden BC248CLT Base Scanner
Scanner wont scan
provided you turned the squelch know and it didnt help, i would trace back from the squelch control to the first and second transistor you come to and that should be the squelch circuit. if you know how to check them with an ohm meter you can find out which one it is, if not you can just replace them both for under 5 bucks.
Oct 02, 2008 | Uniden BC278CLT Base Scanner
Police scanner
Uniden wont admit it but it has installed faulty squelch on the 248's I had the same issue. Wont sell parts either. 60 bucks to fix.
Jul 05, 2008 | Uniden BC248CLT Base Scanner
Radio Communications Logo
1,171 people viewed this question
Top Radio Communications Experts
Marvin
Marvin
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
