Question about Samsung SHR-2082 8 Channel Stand Alone Dvr with Cdrw
I have a samsung home security shr-1040 and i tried to change my password and i must have put a different 4 digit code than i meant, i am now locked out and cannot access my settings.....please help
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 14 Answers
The manual says:
You cannot enter MENU by forgotten password.
- If you forget the password, you shall reset SHR-2160/2162/2080/2082 DVR to
the values set at the factory. Keep pressing both the "MODE" button and the
"PTZ" button on the left for 5 seconds, Keep pressing both the "MODE" button
and the "PTZ" button on the left for 5 seconds. The password default is "4321".
You can download the user manual here:
http://samsungsecurity.com/product/p_detail.asp?seq=94&sel_seq=64
Posted on Dec 28, 2008
How do you reset the password on a SHR-1040?
Posted on Jun 16, 2009
Shr-1040 password fail
Did you try typing the default password 4321?
Hope that helps.....
Jul 20, 2008 | Samsung 4 Channel Dvr
I forgot my password and I cannot do anything. What is the solution? SHR-1040 DVR security system.
Factory Reset Hidden Key :Mode Key + CH 2
The Password and all setting value will return to the initial default value.
Default Password is ‘4321’., Refer to 6-10p, 6-12p of User manual
I hope this helps.
Jul 09, 2009 | Samsung SHR-2042 4 Channel Stand Alone Dvr...
Samsung shr-1040
most likely you have a bad board. try resetting the unit if this works great if not then you will have to send it in to be repaired.
•Factory Reset Hidden Key :
Mode Key + CH 2
•The Password and all setting
default value.
•Default Password is ‘4321’ .
mj
Apr 28, 2009 | Samsung 4 Channel Dvr
I changed the passwors of samsung shr-1040
Mode Key + CH 2
default value.
mj
Apr 08, 2009 | Samsung 4 Channel Dvr
Samsung shr 1040 4 channel dvr
You have to hook it up to a tv monitor and change the settings through the menu. It will originally include a password just to get you on, then you will immediately have to change it. After you do that you can access the menu where you can change the output settings
Apr 05, 2009 | Samsung Home Security
Samsung shr 1040
try resetting the system and reprogramming.
if that does not work you may need to have it repaired.
Mode Key + CH 2
default value.
mj
Sep 18, 2008 | Samsung SHR-2042 4 Channel Stand Alone Dvr...
Trying to get hooked up
I made a hook up from the shr 1040 to a pc monitor using a VGA converter box. Cost less then 40 ( check amazon) and simple to use as well as still use your pc on your monitor,
Aug 27, 2008 | Samsung 4 Channel Dvr
Samsung shr-1040
it comes with a built in code it is 4321
Nov 20, 2007 | Samsung 4 Channel Dvr
Connecting the recorder to the security system
If you are hooking your cameras into the SMO-151qn then you can use the pigtail cable to connect to the Shr-1040. Make sure the video out from the SMO-151qn goes into the video in of the Shr-1040. If there is a choice use CH1. On the Shr-1040 hold down the mode button and press CH2 for about 10 seconds. The Shr-1040 should reboot. Once it comes up press the record button. After recording for a feww minutes stop the recording. On the SMO-151qn press the button on the front Live/Vcr. You should see the screen from your Shr-1040. IF you hit play you should see what you recorded. Good Luck!
Jun 11, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung SHR-2082 8 Channel Stand Alone Dvr with Cdrw Logo
2,244 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Jim Goldsmith
Jim Goldsmith
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
