Question about Yamaha HTR-5890 Receiver
Yamaha HRT 5890
I have contunuity between the input and output on the high side. The 10a fuse was open i replaced with the same result click but nothing else. Can I buy a new transformer? Where can I find one. I have klipsh F3 synergy towers with a 12" klipsh sub. I was running the reciever @ full throttle. I wonder if the cooling fan was working because she always runs hot and I never hear the fan?
  • 12 Answers
SOURCE: Yamaha HTR-5990 Audio no longer works
Hi everyone:
You may reset your unit, to do so here is the procedure.
1. Depress the MASTER little Button so it has to be in the OFF position
2. press simuntaneously the A/B/C/D/E and TUNNING/CH > buttons and the press MASTER again
3. Keep the two buttons pressed until the SLEEP blinks on th display, at this point you will see a message that last for maybe 3 seconds,
4. after the message you will see the number 1 and a series of numbers on the first row and the word MARGIN on the second row.
5. Turn the PROGRAM knob until you reach tothe number 11 FAC PRESET on the first row and PRESET INH on the second row
6. press the TUNNING/CH > button once, and the message on the second row will display PRESET RSRV
7. Press the MASTER again and your unit will have the factory settings.
I Hope this solve your problem
Miguel
Posted on Feb 16, 2008
  • 4234 Answers
SOURCE: Yamaha RX-V420 No power
If the standby voltage exists, the next step is to see whether or not the clock is working. Find the main micro chip. There should be a 3 legged crystal close by. You should see this oscillate (use a scope). No oscillation = no micro control = no turn on. It is possible that the micro is bad or the crysal is bad. Also, check to be sure that the output transistors are not shorted. It is also possible that these are preventing the system from turning on.
Dan
Posted on May 12, 2008
  • 905 Answers
SOURCE: connection a JBL surround cinema speakers with sub to a Yamaha
if you do not have the digital hook up from the tv to the reciever
304c659.gif then you will not get the subwoofer sounds or the dolby digital sounds
if you don't have this on your tv then just turn off the dolby digital when watching the tv , and you should be able to hear the subwoofer thru the virtual surround sound
hope this info is worth a fixya and if you need other help then just ask me and
i'll be glad to help
electech
Posted on Nov 23, 2008
SOURCE: want to connect my RCA sub to my yamaha htr-5940 reciever
Subwoofer needs to be enabled through menu on Yamaha. LINE OUT might be turned off or Subwoofer volume set to low or off... (-db level) kinda thing...speaker wires are usually always live etc...
Posted on Feb 04, 2009
dthomas1969
  • 4 Answers
SOURCE: Yamaha RX-V757 No Left Channel Output - Video Sources Only
First - make sure it is not a defective cable by reversing the leads/colors on the inputs if problem then goes to the right channel then you know it is a bad cable/RCA, etc., connector. I would try that first.
Thanks,
dthomas
Posted on Feb 07, 2009
How do I fix my yamaha receiver? I turned it up and it shut off,tried to turn on heard fuse blow. Replace one of the two fuses 10A 125v that one blew also.
Fuses blow due to an overload. What has happened in you case is one or more of the output devices (found on the big heat sink) has shorted and acting like it was a piece of wire. Now you have to find out which. By the way it might have gone due to bad speaker wires or speakers, or speaker wires touching each other.
Jan 11, 2016 | Yamaha HTR-5890 Receiver
Why is my bread machine relay clicking?
I have a Cuisinart breadmaker and I see these JZC-7F relays too. Popped one out and it's clicking but not closing the contact. will replace it.
Aug 26, 2014 | Sunbeam 5890 ExpressBake Bread Maker
Car only blows heat on passenger side, Drivers side still cold even after replacing the actuator. What else could it be?
If the blower motor is running, that means the 30A HVAC BLOWER fuse is OK. The HVAC control module obtains power through the 10A DIC/RKE fuse in the right instrument panel junction block and the 10A A/C CRUISE fuse in the left instrument panel junction block. Output from the HVAC control module controls the mode actuator and the recirculation actuator. You replaced one of the two. The other one may be defective or the replacement one may be defective. Also, the HVAC control module may be defective and not producing door control output
Sep 30, 2012 | 2005 Chevrolet Impala
I have a yamaha htr 5890. I would like to hook up
You are probably connected to the pre-out jacks. These are not amplified. Connect them to the B speaker outputs(screw down connectors). If that won't work (and it should), you can connect to the "Presence" speaker connections(spring loaded connections).
Feb 02, 2010 | Yamaha HTR-5890 Receiver
What do the symbols on the fuse guide stand for?
Fuse Locations & Functions
1. Washer nozzle heaters, glove compartment light (10A).
2. Turn signal lights (10A).
3. Fog light relay, instrument panel light dimmer switch (5A).
4. License plate light (5A).
5. Comfort system, cruise control, A/C, steering wheel module (7.5A).
6. Central locking system (5A).
7. Back-up lights, speedometer vehicle speed sensor (VSS) (10A).
8. Open
9. Anti-lock brake system (ABS) (5A).
10. Engine control module (ECM): gasoline engine (10A)
11. Instrument cluster, shift lock solenoid (5A).
12. Data Link Connector (DLC) power supply (7.5A).
13. Brake tail lights (10A).
14. Interior lights, central locking system (10A).
15. Instrument cluster, transmission control module (TCM) (5A).
16. A/C clutch, after-run coolant pump (10A).
17. Open.
18. Headlight high beam, right (10A).
19. Headlight high beam, left (10A).
20. Headlight low beam, right (15A).
21. Headlight low beam, left (15A).
22. Parking lights right, side marker right (5A).
23. Parking lights left, side marker left (5A).
24. Windshield washer pump, windshield wiper motor (20A).
25. Fresh air blower, A/C (25A).
26. Rear window defogger (25A).
27. Motor for rear windshield wiper (15A). (if equipped)
28. Fuel pump (FP) (15A).
29. Engine control module (ECM) gasoline engine (15A)
30. Power sunroof control module (20A).
31. Transmission control module (TCM) (20A).
32. Injectors: gasoline engine (10A)
33. Headlight washer system (20A).
34. Engine control elements (10A).
35. 12 V power outlet (in luggage compartment) (30A).
36. Fog lights (15A). (if equipped)
37. Terminal (86S) on radio, Instrument cluster (10A).
38. Central locking system (w/ power windows), Trunk light, fuel door, Trunk lid (15A).
39. Emergency flashers (15A).
40. Dual tone horn (20A).
41. Cigarette lighter (15A).
42. Radio (25A).
43. Engine control elements (10A).
44. Heated seats (15A). (if equipped)
Fuse arrangements in fuse bracket/battery:
S162. Glow plugs (coolant) (50A).
S163. Fuel pump (FP) relay/glow plug relay (50A).
S164. Coolant fan control (FC) control module/coolant fan (40A).
S176. Relays panel interior (110A).
S177. Generator (GEN) (90 Amp.) (110A). Generator (GEN) (120 Amp.) (150A).
S178. ABS (hydraulic pump) (30A).
S179. ABS (30A).
S180. Coolant fan (30A).
Oct 14, 2009 | 2002 Volkswagen Jetta TDI
Yamaha HTR-5890 not powering up
Power supply is burned out. surge or spike got it, replace power supply unit.
Sep 08, 2009 | Yamaha HTR-5890 Receiver
RX-V2600 HAS BLOWN FUSE CB5 10A 250V REPLACED NOW RECIEVER WILL CLICK THE RELAY ON THE OFF ANY SUGGUESTIONS WE CHECKED ALL OUTPUT TRANSISTORS
check the DC converter and associated transistors. an overload may have taken some out, and rendered the unit useless.
Jun 11, 2009 | Yamaha RX-V2600 Receiver
Passenger headlight don't work 2003 lincoln navagator
high beam or low beam? or both of them on one side.
  • One low beam headlamp is inoperative
  • Central junction box (CJB) fuse 23 (10A) (RH headlamp).
  • CJB fuse 25 (10A) (LH headlamp).
  • Circuitry.
  • CJB.
  • Go To Pinpoint Test C .
  • One high beam headlamp is inoperative
  • Circuitry.
  • Headlamp assembly.
  • Go To Pinpoint Test D .
  • The high and low beam headlamp is inoperative on one side
  • Circuitry.
  • REPAIR ground circuit 57 (BK).
  • Headlamp switch
  • Multifunction switch
  • Vehicle Security Module
  • Central junction box (CJB) fuse(s):
    • 17 (15A)
    • 23 (10A)
    • 25 (10A)
    • 35 (20A)
    • 40 (20A)
  • Circuitry
  • Headlamp bulbs
  • Daytime running lamp (DRL) relay
Apr 19, 2009 | 2003 Lincoln Navigator
No power
no power, 1st you need a tester tester (range 1000vac) first the convinience outlet if there a voltage 2nd test the power cord if there a continuity(range your tester into resistance x10) put it in to the tip to tip of the C.O power cord of your turntable(the reading will have contunuity) if still no power check the fuse inside the turntable" remove the platter and the plastic be carefull trace where the power cord connect inside the circuit(maybe the fuse blown) if the fuse is still ok 4th check the contunuity of the transformer the input and output line(in tester there will have a reading supposed to be) after all if theres still aproblem just email me..hope i can help that way..
Aug 10, 2008 | Technics SL-1200MK2 Turntable
Yamaha HTR-5890 Receiver Logo
80 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
CHP6PH1
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
