Question about Tasco Galaxsee 45-114375 375X (375 x 114.3mm) Telescope
Cannot see through lense
Cannot view anything through the lense. just black and no image. it's like there is no light source to view. i am a complete beginner, so any help would be helpful.
thanks
BSS
  • 3,186 Answers
A telescope only shows about 1 degree or LESS of sky-- this about the size of the tip of your finger held at arms length! Point it at the moon and practice focusing the telescope.
Posted on Jan 04, 2009
Which is the good spotting scope for higher amount of light?
Bushnell Trophy Xtreme Spotting Scope
Overview
Bushnell Spotting Scope has extra power for extra range; its BaK-4 Porro-prism design delivers magnificent clarity in a traditional design. The multicoated optics ensure maximum light transmission for the brightest and take the images more colorful and clear. If you are searching Bushnell Scope that can be used for different activities, you should consider Bushnell Trophy Xtreme Spotting Scope Review.
The highly refractive BAK4 Porro prisms diminish spherical deviations for increased edge-to-edge sharpness and help progress depth of view. This combination of optics and coatings creates a spotting scope that produces clear, bright, highly contrasted images with the exact color transmission.
The rubber-armor structure stands up to demanding use. This scope is 100% waterproof and fog proof for wet hunting conditions. It also Comprises compact tripod with window mount, compact soft case, and waterproof hard case.
Specifications
  • Brand:Bushnell
  • Viewing Configuration:Straight
  • Magnification:16-48X
  • Power Variability:Variable
  • Objective Diameter:50 mm
  • Close Focus Distance:25 feet
  • Length:13 inches
  • Weight:31.4 ounces
  • Field of View:125-60 feet/1000 yards
  • Eye Relief/Exit Pupil:16 mm/ 3.1-1 mm
  • Optics Coatings:Fully Multi-Coated
  • Glass:BaK-4
  • Focus System:Focus Knob/Single Focus
Feature Analysis
  • Porro Prism Lens
    Though many optics producers keep on trying to transform roof prism lens, Porro prism lenses are more affordable and light-efficient. These Porro prism lenses can display images with better contrast than roof prism variations. This is how Bushnell Spotting Scope is more reliable and affordable for its high-quality performance.
  • 20-60×65 Zoom Magnification
    The wide range of magnification allows user flexibility for long-range view finding. You can observe details with 65x zoom for long range objects. But, you can still enjoy an increased field of view with 20x zoom. This is used when separating the areas for closer zoom viewing later on.
  • 65x Lens Light-Gathering Capability
    This advanced magnification lenses can light gather at long distances. The Bushnell Trophy 20-60x 65mm Waterproof Spotting Scope resolves this issue by designing 65x zoom lens in a way that brings 17% more light than most high-zoom lenses.
    If you fully read Bushnell Trophy Xtreme Spotting Scope Review, it will support you how to setting zoom for longer distances images.
  • Waterproof Construction
    When you go out in nature, this waterproof construction anticipates you about rain or even snow. It is pretty obvious that any liquid that leaks into your scope will detract from the overall image. But many people do not consider the effects of concentration on the inside of the lens.
    This spotting scope is actually water and fog proof not only for outside moisture but also prevents lens fogging from risky temperatures.
  • Fully Multi-Coated Optics
    The multi-coated lenses prevent any reflections in the glass that can delay your view. The sunlight at certain angles can cause reflections from water or wet surfaces that prevent the clear view of the images. That is why; Bushnell uses multi-coated lenses to remove any kind of reflection.
  • Well-designed Equipment
    The tripod often needs to hide from animals, and the scope cases also need to protect their insides from both jostling and the outside elements. The Bushnell Trophy XLT comes with both a hard-side case and a soft side case. The hard side case protects you from outside damage and a soft-side case protect you from a bumpy road when you are riding.
Mar 18, 2018 | The Optics
Olympus e420 no live view black images
are the photos on the memory card? LCD could be shot or loose.
Mar 12, 2014 | Olympus Cameras
View finder displays are upsidedown
Telescopes generally will display images upside-down, due to the way the image is magnified. On many telescopes, the eyepiece is removable, and can be exchanged with many different attachments and lenses. One of which being an image rectifier (or image flipper), which flips the image back to normal. Unfortunately these lenses can be pretty expensive, and will reduce the amount of light being passed through the telescope due to the addition of more lenses, so are only primarily used for day terrestrial viewing. Hope this helps.
Mar 24, 2011 | Edu-Science (10166) Telescope
I have new Nikon D90 with 18-105 Nikon lens. The only problem with the camera, when shooting potraits in dim light without flash, the pictures get black artefacts throughout the faces and skins. I used...
iv seen this on canon, are you sure it is on final image or only on view of image on camera?
view image out of camera it could be that it is not effected.
I hope this was useful.
Jan 24, 2011 | Nikon D90 Digital Camera with 18-105mm...
The led screen is black as is the video being recorded. Everything else seems to working. yes the lense cap is off. It as if no images are coming through the lense.
First, Please confirm that if LCD is blank then can you see the images in view finder ? If not then the CCD IMAGER is faulty and if LCD is blank and you can see the image in view finder then then a Flexible board which connect the LCD with the main unit is broken, Please replace these parts according to the symptom. Moreover, for your ease pics are shown below of both parts with part number.
First pic is for CCD IMAGER
second pic is for flexible board.
Thanks
Oct 22, 2010 | Sony Handycam DCR-TRV33 Mini DV Digital...
I dropped my camera and since then I can take photos, the camera focuses, my display is fine when viewing previously shot images and the normal display information but when the shutter is pressed all o see...
When you take off the lens and fire off a shot, does the mirror go up and return or does it stay up? If not, is it possible that it is staying up when the lens is connected? When you fire a shot, can you hear it returning?
Sep 19, 2010 | Canon EOS 400D / Rebel XTi Digital Camera
I am having problems viewing
All astronomical telescopes show upside down images. There is no up or down in space. To ERECT the image would take additional GLASS lenses. MORE glass means less light pass-through for those dim sky objects.
Dec 25, 2009 | Bushnell 675x5 EQ Reflector Telescope
How do Your delete stuff that you've Filmed?
Simply rewind the tape and record over the old stuff, if you want it completely blank, cover the lense with lense cap and press record button it will just record a black image.
Sep 21, 2009 | Panasonic NV-GS150 Mini DV Digital...
My camera does all the proper functions but when you look through the lense all I see is black it does not show images. I take the picture and all you see is black, because that is what is in the view...
1. lens cap. had to say it, you know that! i assume it's off.
2. settings. once i had my lumix set on a certain white balance (dial, manual, menus) , and it let in so much light that all my shots turned out completely white ( i wasnt reviewing the pictures at the time). make sure you didnt put your camera on some setting that's blocking out light. try automatic by turning the dial.
3. try to reset your camera to factory settings using the menu system. sometime you get lost on the menu system and change an important finction that completely changes what you get when you take pictures.
Jan 31, 2009 | Panasonic Lumix DMC-FZ50K Digital Camera
Images viewed are upside down
oh this is normal,because when looking at stars it really doesnt matter if they are inverted,but by leaving out the erecting lenses you get more light and less distortion. so you need an erecting lense to see images in the daytime,call bushnell@18004233537,im sure they can sell you the right adaptable piece....good luck...larry@reichinstruments.com
Nov 24, 2008 | Bushnell NorthStar 78-8831 (525 x 76mm)...
Optics Logo
191 people viewed this question
Top Tasco Optics Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Tasco Optic Expert? Answer questions, earn points and help others
