Question about Nikon D80 Digital Camera with 18-135mm Lens
How to turn off "highlight" image display on D-80
Over exposed highlighted areas flash on image playback - need to find out how to turn this off.
This happens when you accidentally press the up or down button when viewing images on the playback. If you press up or down a few times it goes to a screen that looks like normal playback but with the flashing highlights.
All you need to do is press up or down until it goes back to the normal screen.
Hope that helps!
Posted on Dec 25, 2008
The LCD on my Epl1 has red flashes on all the images. Why???
It sounds like you have turned on the Highlight/Shadow point warning. I use this all the time to check for blown out highlights.
You should press the INFO button in playback mode to cycle through the picture display options until you get back to the display that you like.
Feb 11, 2011 | Olympus PEN EPL1 Body only Digital Camera
My Canon 40D LCD monitor when displaying a photo has just started displaying white sections of a picture as alternating black then white. The rest of the photo is fine just the white flashes. Any idea what...
It's possible that your Highlight Alert is enabled. Over-exposed areas of your image will blink to indicate blown-out whites. If you don't like this feature, go to the Menu, under the second blue tab (for playback), look for Highlight Alert and Disable it. When viewing the image on a computer, the blinking will not appear however. It's just to warn you that some parts of the image is so bright that all detail is lost. I enable mine so that I know this and is able to make adjustments on the ground.
Apr 11, 2010 | Canon EOS 40D Digital Camera
On the viewfinder, parts of the picture flashes black.
It sounds like you have the display set to show image "highlights", this is a mode that shows parts of the picture that has become over exposed and have no detail contained within that area, in other words the parts of the photo that are pure white.
The camera Highlights as one of several different modes that can be flicked through after looking at a photo you have taken. hope this helps  Ian
Sep 07, 2009 | Nikon D60 Digital Camera with 18-55mm lens
When ever there is a picture taken there is a flicker when i view the picture in my camera it happens only on the bright spots ...ehy is it
It's normal.
The Nikon dSLRs have various LCD display modes, and one of them is called "highlight clipping warning display". Basically, when you set your LCD display to "highlight clipping warning display"(it's the mode right before the "histogram display"), it blinks white/black wherever your picture has blown highlights (i.e. where your picture is overexposed)
A histogram display is very helpful in telling whether you've got the exposure right, but to it isn't adequate by itself. With digital cameras, it's very important not to blow-out the highlights in a picture (they're similar to color positive film in that respect), since once you hit the maximum brightness, the image just saturates, and any highlight detail will be lost. A histogram display does a pretty good job of telling you how the image as a whole is doing, but what if there are just a few critical areas that you're worried about for the highlights? If only a small percentage of the total frame is involved, it won't account for many pixels. That means any peak at the "white" end of the histogram graph would be pretty small, and easy to miss (or just plain invisible). What to do? The folks at Nikon recognized this problem some time ago, and so have provided another special display mode on the D60 (as on most of their dSLRs) that they simply call "highlights," accessible via the Playback settings menu, under "Display Mode." This mode blinks any highlights that are saturated in any of the color channels. It does this by taking the nearly-white areas on the LCD and toggling them between white and black.
Aug 03, 2009 | Nikon D60 Digital Camera
When viewing photos some white areas blink black on the lcd.
This is becasue those flashing areas are over exposed highlights. Reduce you exposure compensation a stop to capture those white areas. Increase your shutter speed or use a smaller aperture (f-stop) to let in less light. When you loose highlight detail in a digital image it is hard to reclaim back on a computer program.
Jul 06, 2009 | Nikon D40x Digital Camera
Nikon D60 highlight
When you have the flashing highlight areas, press the down arrow on the command dial and it will scroll through various playback screen options until you get to the screen you prefer to view.
May 29, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Highlight feature was turned on don't no how to switch off
Just click on the top arrow on the multicontroller twice. On the first click, the histogram will show and next normal image will show up.
Dec 25, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Blackout on LCD Image Playback
It baffled me too, at first. What has happened is that the navigation dial has been (probably) accidently pressed, thus putting the display in "highlight" mode. When it is doing the blinky thing, press the down arrow to scroll thru the playback modes. A couple of presses and you'll be back to normal. This will show you the super light areas of an image, so it can be useful to avoid loss of detail in highlighted areas, but it sure looks wierd at first.
May 30, 2008 | Nikon D40x Digital Camera
Nikon D40 - Flashing black on the light/white areas of inside & outside pics
It sounds as if you have changed the viewing setting so that the camera highlights over-exposed/highlight areas of the image.
While playing back images, press the multi-selector (4 way cursor) up or down to cycle through the various options.
This should be explained on page 51 of the cameras manual.
Hope this helps.
Matt.
Mar 04, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
666 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
