Question about Yahoo Messenger
I have been trying to download yahoo messenger for weeks...
I have disabled my firewall and it sits on "updating system configuration, please wait" for hours. I have deleted the complete messenger from my computer numerous times and reinstalled it. I am very frustrated!! I have also completely shut off my virus protection and tried it. I have also tried different versions of messenger. At one point, it did install, just sat at 97%, another time at 99%. I really need this to work as it is my main communication with relatives and my boyfriend. Any help would be greatly appreciated. Thank you.
  • shar7_98 Dec 25, 2008
    Thank you. Nothing worked. I just went to Meebo.com.. I have exhausted my options, did everything you said and everything I can think of. If you think of anything new, please email me at shar7_98@yahoo.com. Thanks again.
  • 40 Answers
This is from the Yahoo site. Hope it helps
Windows 2000/XP:
  1. Reboot your computer.
  2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab.
  3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation.
  4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list.
  5. Click the "End Task" button. This will temporarily close all background applications on your system.
  6. Click the "X" in the upper right corner to close the Task Manager window.
  7. Install Yahoo! Messenger. You should not experience the same issue that you had before.
  8. After Yahoo! Messenger is installed, reboot your system. All other background applications will return to their original configurations.
Posted on Dec 25, 2008
    Master:
  • 416 Answers
Messenger 9 for Vista users and XP users with 9, With windows new update to their FireWall, Has so many glitches. Yahoo has given up and no longer trying to fix it. The updated Firewall will not let Messenger download correctly.And is causing 8.1 users to have major problems now. The only option is turning off the firewall to download and install then turning it back on.If fire wall still causes problems,then revert back to 8.0 or 7.5 these and all versions of messenger from 3 up to the 6th version of 9 can be found here; http://www.freecreed.com/ymsgr-archive.h... They will be releasing a new version 10 (untested) as usual!
You need to remove version 9 1st to get another version to work. To remove Messenger version Use Unwise located middle of page of Messenger Folder.. Your contacts are stored online But if you want to save your old messages archives,they are saved on your PC in the messenger file you are about to delete.Go here and copy them to a new folder
Start>my computer>c:drive>program files>yahoo>messenger>profiles>(your ID)>archive>messages Good Luck
  • 6,487 Answers
This can be cause by some virus or malware on your computer that wont allow the software to be installed and to work fine, i would suggest you run a good anti virus and anti malware like Malwarebytes to check and clean your computer....if it still failed you can install some third party meesnging software that you can use with your yahoo account like, Pidgin and trillian or just go to Meebo.com..
Hi, Am facing a problem in downloading yahoo
The best possible solution is to disable the firewall setting on your system. Turn it OFF. Where do you find it? Double click on the Control Panel. Double click the Windows Firewall icon. Click on the General tab. Select "off " and click OK.
Now try installing again the yahoo messenger.
Some of antivirus software also have its own firewall setting.. look on your manufacturer the procedure to disable it.
Aug 10, 2010 | Yahoo Messenger
I tried my best to down load yahoo messenger latest version but installation is failed.please resolve this issue.i will be waiting for your reply.
there are different reasons why you can't install yahoo messenger. First if your files is corrupted it will be impossible to finish installing. Second you need good internet connection, if the connection is unstable, i will take too long to respond from yahoo. Last, is firewall connection, better disable this when installing yahoo messenger.
Here is a better file to download, Ymsgr 10.
Thank you for using fixya.
Jun 14, 2010 | Yahoo Messenger
Firewall stops me using yahoo messenger
Uninstall or disable any security software running on your computer. Try restarting your computer in safe mode with networking and then installing. If all of the above doesn't works and still you were getting message for firewall then either disable your Router's firewall by opening Router's page or Bypass router for a while and connect directly to Modem and then Install.
May 23, 2010 | Yahoo Messenger
Yahoo! Messenger is unable to download files needed for install
yahoo!7 messenger is unable to download files needed for installation. Please
check firewall settings and retry installation.
I found the answer its so simple, The problem has nothing to do with firewalls.
Yahoo instant messenger (yim) needs internet explorer 7 or above version to
enable yim to operate properly with the current yim versions. If you have an
earlier version of IE (I was using IE 6 coz I always use firefox and did not
have windows update enabled coz I did not want my windows operating system to be
revealed as it was copied and theredore not legit) So I disabled windows update
and kept using firefox, but even if you never use internet explorer, yim still
needs internet explorer 7 to operate without these errors shown above. I tried
to fix it for weeks thinking it was fiewall or such, but it just needed IE 7 so
I downloaded it here:
http://www.microsoft.com/en-au/download/internet-explorer-7-details.aspx
and even tho it says its for a windows server it still worked on my windows
XP pro 64bit and now yim is working properly, allowing multiple copies of
contacts etc, no problems at all now. I also downloaded firefox version 35,
which helps yim too coz its yahoo preferred.
https://www.mozilla.org/en-US/firefox/35.0/system-requirements/
Apr 02, 2010 | Yahoo Messenger
Unable to download files needed 4 installation
Go to Start>Control Panel > Add or remove programs remove all the things related yahoo ( Yahoo toolbar, Yahoo mail advisor, Yahoo installer, Yahoo browser plus etc.) Try download and install then....If still same try download offline installer http://download.yimg.com/ycs/msg/dl/msgr10/us/b4/msgr10us.exe
if still you are having difficulty download old version like Yahoo messenger 8 or Yahoo messenger 7
I think it will help you..Further result please let us know... Thanks for being with Fixya...Good Luck
Nov 10, 2009 | Yahoo Messenger
I can't install Yahoo! Messenger showing this error message:
The issue lies in the Firewall settings. The Windows Firewall has blocked the Application from connecting to Web Servers. You must have to unblock it to get the problem resolved. If you have a Anti-Virus Firewall, reconfigure it, this will erase the Firewall's rules and will ask again that do you want the application from connecting to internet. You allow it and then it can download.
Thank you Sir, Have a nice day.
Sep 28, 2009 | Yahoo Messenger
Unable to Install Yahoo! Messenger Firewall Issue or What?
The problem is with the Yahoo uninstall software which fails to clear the old Messenger folder out and creates conflicts with the incoming new software - Your firewall doesn't know whats happening and hoists a red flag. If you had not started to uninstall I would have recommend you download revo and uninstall with that.
http://www.revouninstaller.com/revo_uninstaller_free_download.html
bear this in mind if you manage to install messenger but still have problems
You have to go into your C drive and delete the left behind software
Click ( > ) Start > Computer >> Local disk (C) >> Program files >>Yahoo >> Messenger - if you have Vista the folder should be empty - if you have pre- Vista the only sub-folder remaining should be 'Profile' ( The message Archive file) manually delete everything except 'Profile' by right clicking and deleting. When finished restart your computer and finish the install
Aug 07, 2009 | Yahoo Messenger
How much of time the installing yahoo messenger will be taken?. I tried so many times. Yahoo messenger installing shows 100% completed and it started another time downloading.How many times it will shows...
maximum of 10 mins. if you already download the yahoo exe. then if system updating configuration pls wait is appear for a long minute of time... then you did not properly uninstall the previous version of the messenger... kindly uninstall it and delete the remaining folder of yahoo in program files/ yahoo folder....
Feb 22, 2009 | Yahoo Messenger
Yahoo messenger 81003005 error how do u fix it?
New 9.0 version: fix for sign-in issues February 5, 2009 on 1:32 pm | In 9.0 version | 32 Comments
emot_wink.jpgWe released an updated version of Yahoo! Messenger 9.0 today (9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code “81003005” when trying to sign in, this latest version should fix that problem. Even if you were experiencing a different kind of sign-in issue, we recommend installing this latest version.
Dec 19, 2008 | Yahoo Messenger
Yahoo Messenger Logo
18 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
