Question about Nintendo DS Lite Console
Power cable stuck
Is there a trick to removing the power cable from the back of the DS lite? mine seems to be stuck.
  • johnandanali Jan 02, 2009
    We got a ds lite for christmas and have also had the power cable stuck in the back of the unit.  nothing done wrong, it only does in one way.  help!
  • 23 Answers
Just gently woble the cable from side to side as you pull it out... thats all the advice i can give towards this problem... sorry
Posted on Jan 07, 2009
DS Lite Will Not Power On
There is a possibility that your battery has developed a short circuit or is so bad that it pulls down the charge voltage on the charger. You are therefore left starved of a power and therefore no function.
If possible, disconnect the battery and run the DS on the charger power alone. If the DS starts to work, I suggest replacing the battery.
Sep 05, 2014 | Nintendo DS Lite
Tip
DS Lite fuse replacement F1 F2
Does your DS lite refuse to charge?
Does the orange charge light not come on at all?
Has your DS stopped switching on with no green light at all?
Well this is the guide for you.
Remove the DS lites base plate (for a guide on how to do this see my other tips and tricks) and locate F1 and F2 (see pics)
F1- Charging fuse. Change this one if you have the following issue:
Orange light doesn't come on at all when the charger is inserted and a battery connected.
F2- Console power fuse. Change this one if you have the following issue:
The DS lite console charges but refuses to power on.
If you find that the DS lite console neither charges or switches on i.e. no lights come on, not even for a brief time you can replace both fuses and it "should" resolve the issues, however, I cannot guarantee this as there could be other factors for the lack of power e.g. water damage.
To change a fuse you need to first remove the old one, do this by desoldering either side of itand remove it from the board.
Putting the new fuse on is a little trickier, you will need to hold the fuse in place with a small enough item that will not get in the way ofthe soldering process such as a cocktail stick or tweezers. Solder either side of the fuse to the board taking care not to make a bridge* with the solder. Give your newly laid fuse a test to be sure you have done it correctly, put the DS lite back together and then your done.
*Bridge - A solid connection made over or around the fuse thus bypassing it.
I hope this helps and I have to say that I take no responsability for any damage that may occur whilst following my tips/ guides.
Regards,
SOD69
on Feb 08, 2010 | Nintendo DS Lite
Why does dslite have no power?
Make sure the ribbon cables or the screens are plugged in. one for each screen and one for the touch screen (i think the touch screen is the one thats causing your problem) its small and comes out easily. please wright back if it works
I am having trouble connecting to Wi-Fi on my DS. It keeps saying that there is no access point.
Make sure have a wireless broadband internet connection available within a short distance of where you are. The DS Lites are kinda slow. You may have to try a few times to get onto the internet. Also, sometimes if you are using a modem that is being used by some other people at the same time (coffee shop etc), it can be painful getting on the internet with the DS Lite. You might also want to power off the DS Lite and even remove the battery for a minute and put the battery back in and power the unit back on. This will reset the DS Lite and and sometimes accelerate the speed at which the DS Lite process.
Mar 24, 2011 | Nintendo DS Lite Console
Nds lite wont turn on
if you have another nds lite try switching batterys if that dont work then its broke, sorry.
Sep 21, 2009 | Nintendo FOR NINTENDO DS LITE NDS AIRFOAM...
Nintendogs experience microphone problem
Phillyxx1995
It is not the game that is here the problem. It is the DS Lite.
Your microphone is disabled by a defective connector at the front of your DS Lite.
I explain...
On the front left of youre DS Lite, there is a headset connection. Inside this connector (soldered on the mainboard of the DS Lite) there is a contact that shuts down the microphone on the top screen enclosure if this headset connector is used.
For some kind of reason (and I see a lot of them), this internal switch stay closed when a headset was inserted and removed again Result.....the microphone in the enclosure is always off.
I've even seen this problem without ever using a headset and the front connector.
The only way to solve your problem is to replace this headset connector by Nintendo or a DS Lite repair service
John
Oct 31, 2008 | Nintendo DS Lite Console
Rebuild power problems
I figured it out... make SURE that the ribbon cable from the upper screen is up into the connector as far as it can go... When I redid both of mine they both had this problem. I've since researched it more, and found this to be a problem (which makes sense as I tried to turn it on w/o the top screen connected as well and it did the same exact thing)...
Make sure that the black tabs on the cable as up touching (well almost) the white connector before you push down the black clip thing that holds it in place. Once you get it connected right, it should work for you (it did on two of mine)...
Oct 14, 2008 | Nintendo DS Lite Console
Fixing my DS lite
don't panic you probably knocked the screens ribbon cable out you will need a special screw driver(ebay).there are many good guides available on taking them apart and putting them back toghether.the trick is to take your time and be very careful.
Jul 28, 2008 | Nintendo DS Console
DS lite
I'd suggest removing and then re-inserting the battery (this should at least switch the power off).
Is the power switch loose? If so it's been broken and needs replacing (not an easy job).
Alternately it could just be stuck in sleep mode which happens when the DS is closed while powered on but should awaken when re-opened.
HTH
Mar 03, 2008 | Nintendo DS Lite Console
Ds lite
I think mine had this problem. It used to boot to the settings screen,where i would select what i wanted,then it would save and power off but when i rebooted it returned to the settings screen again. I found that by sticking a supercard in it(google it), it bypassed the settings screen. Mine now works fine all the time
Dec 20, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
41 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
