Question about Kenmore 63942 Dryer
GE Dryer DDE5300BALAD will not start
I put wet clothes in the dryer and it will not start. No sound of any kind coming from dryer. I have checked the breaker, everything looks O.K. I have unplugged the dryer and plugged it back in. Does this dryer have a reset button on it? I can't fine one. Any other suggesstions?
  • Thomas F. Schneider May 11, 2010
    Have you tried playing with the door.Raise it up slightly etc. Their is a switch that the door activates that does not allow the drier to run w/o the door being closed.
  • Ronald East
    Ronald East Feb 21, 2013
    I have the same model number and it quit heating while it was running this morning. the lint trap is clean. any suggestions?
    Genius:
  • 1,122 Answers
Also there is a main fuse under the top back,if it blows nothing works-mike
Posted on Dec 25, 2008
GE,DRYER,MODEL # DDE5300BALAD
if the bel if the belt breaks the idle pulley will shift actuating when thi when this happens all power t to the dr is shut of
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Aug 09, 2012 | Dryers
Water under and around dryer. Clothes dry but water on floor. The wash not leaking. I the vent and line are not clogged. What is causing the water under dry?
Unless the clothes are dripping, soaking, wet when they're put in the dryer (and it would take them a loooong time to dry if that were the case) there's bound to be a leak of some kind coming from somewhere other than the dryer. Do you have a lavatory or toilet on the other side of the wall behind the dryer? They dryer has no water of its own to leak.
Dec 27, 2011 | GE DBXR463EDWW Electric Dryer
I have a GE dryer that won't dry our clothes. It heats up, but water is all over the inside door and the lint that comes out of the hose in the back is wet! The outside of the dryer (the top in...
It really sounds like your washing machine is not spinning the clothes out enough. Have they been wetter than usual lately? The dryer could just be struggling to keep up with the heavier / wetter load as there is no reason for it to create moisture on it's own.
Oct 06, 2010 | GE Dryers
Water in the dryer
You did not explain if the dryer is getting hot or not, if there is water inside the drum then it sounds like the heating element is not working and maybe the clothes are too wet when being put in the dryer
Sep 27, 2009 | GE Profile Harmony DPGT750EC Electric...
I have a ge profile dryer model dpsb513eboww and the sensor dry doesn't work properly. It runs 3 minutes then shuts off. The clothes are still wet. All else works fine.
You should inside the driver and on the front or back wall will be the sensor: two metal bars that send an electric current through the clothing. When the dryer detects more current goes through, it knows the clothes are still wet and keep running. If the sensor bars are broken, disconnected, or dirty, it will read no current and think you put clothes in there that were already dry. Make sure those contacts are nice and clean. Failing that, you'll need to test the sensor circuit for voltage to see what the problem is.
Sep 19, 2009 | GE DPSB513BW Dryer
Dryer puts out heat, but clothes are still wet
There may be a clog underneath the lint trap or the exhaust vent may be clogged, if either fails try changing temperature knob to a different setting.
Mar 09, 2009 | LG DLE8377 Dryer
Dryer model # RES7648JQO Serial # MK2707517 I put up a load of clothes to dry and when the cycle is done the clothes are still wet and there is water on the door inside the dryer. I've tried adding a...
it sounds like an airflow problem. check everywhere the air flows. inside the lint catch. the vent behind the dryer may be clogged or kinked. the exhaust line in the floor or wall of the house might be clogged. 689b12c.jpg
Aug 01, 2008 | Roper Dryers
Dryer appears broken, heard LOUD sound from other room (broken belt?)
gjtgjtgjtgjytgfjytjytgjtgyjtgujytgujttjtytgjtjytgjtgjtyjtgjytjytjgjykykuiykyyuuxuxxudkdssyzxhclds dskhsdlhkshkchdsflfhlhsdlo
Apr 14, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 63942 Dryer Logo
176 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
