Question about La Crosse K2-100 Wrist Watch
Need a part
I broke off the rotating black compass dial on the face. Where can I get another one? The watch is still in awesome shape, but it needs this compass dial.
  • Chet Conner Apr 15, 2007
    That's what I needed to know!!
  • 944 Answers
Here is the link to the user manual if you need it; Page 12 gives you contact details for lacrosse support or use; Hope this helps, please ask again if not and i can hopefully find you another source :)
Posted on Apr 14, 2007
Girl broke face when replacing battery. Can't find EXACT replacement watch. So, where, how much and how long to replace crystal face?
It does greatly depend on the shape of the crystal. If it is an unusual shape, this would need a very skilled person to shape it correctly. If it is a regular round shape, these are easier to come by. This UK web site [link in blue] offers watch parts including crystals to give you an idea on prices. I use a vernier to measure the diameter and thickness of the crystal I wish to replace and UV activated glue to fix the replacement crystal in place and one of those UV nail lamps to cure the glue. This should be done in a clean environment and I use finger cots to prevent fingerprints. The whole process takes about 30 to 60 minutes. Any _competant_ watch repair place should be able to help you. At least you know the process now :)
Acrylic Watch Glasses Tension Rings Flat Top High and Low Dome
Jul 05, 2015 | Crystal Watches
How do i set the two faces of a rotary relelation watch
What happens when you pull out the button when viewing the white face?
May 26, 2014 | Rotary Revelation Reversible Black/White...
51-30 black face. brand new from store and watch wont run. do i need a battery or is the watch supposed to be wound? what is the smaller lower dial for?
bring it back to the store where you had purchsed it. and ask for the warranty of the battery of the watch. the sub dial is for tide tracker whether it is low or high.
Jul 30, 2011 | Nixon 51 30 Tide Watch
I have a tcm 217362 watch with a digital compass how can i set it up to show me north it currently shows cal. and when i press the top right and left button it shows err.(probably error) it is a black and...
Hi john30x,
You have to calibrate the compass.
1. Press the upper right button (switching to compass mode)
2. Press and hold upper left button. The "CALL" will appear on the display. You are in compass calibrating mode.
3. Rotate the watch horizontally (around his vertical axis) slowly, so to be sure that he point the North at least 2 times.
4. Now press the upper left button again to input the
declination (this is the angle between the magnetic and real pole). It is different for the area around the world, that you want to explore.
5. Switch between the positions of the cipher by pressing bottom left.
6. Change the cipher by pressing bottom right.
Switch between the active position by pressing bottom left. Now you have to enter East or West declination
8. If you are ready press the upper left. "END" of calibration will appear on the screen
Once you calibrate and set the declination you can use the the compass by pressing upper right button. As the compass is very sensitive It is good idea to calibrate it on a field, far away of metal objects and electromagnetic fields (cables, ect.). You need to calibrate the compass each time you want to use it by different surrounding.
Remember the compass function of your watch need much more energy than the watch itself. Don`t worry to change the battery when dead. The water resistance remains good even after. Very robust and accurate device. I hope that should help.
May 15, 2011 | Watches
I want to swap the tan face for the black face and replace the crystal how do i do this?
try parsec enterprises..they carry the old parts, dials and things to replace what you need
Sep 03, 2009 | Luminox 3007 Original Navy Seal Diver...
Compass dial turned opposite direction
you might be able to reverse the poles back to normal with a magnet but be careful not to scratch face or get it closer than you need to to the insides of the watch.
Sep 26, 2008 | Field and Stream F25SLUMI Wrist Watch
Vostok N1 watch
In the 2nd position of the stem rotate the hands between 8 and 12 and the date will change.
Sep 26, 2008 | Vostok Europe "Rocket N 1" Black Dial with...
Rotating outer ring
It is primarily cosmetic - the bezel was originally designed for diving, military activities or similar where counting down time was critical. Before digital stopwatches etc were built into watches as a feature, what you did as a diver was turn the bezel to the time (say 30 minutes) of air you had left, then the minute hand would travel around the face to the position 0 on the bezel, telling you 30 minutes had passed. You often find compass directions, various job specific calculators etc on bezels also, but unless you need a stopwatch / time reminder and don't have that feature in the watch itself, then it is purely a tradition to include a rotating bezel. The original bezels would have the time markings going the opposite way to the watch face usually, however on many modern watches, they often go the same way, allowing you to see how much time has passed, rather than how much you have left. Hope this clears things up :)
Mar 31, 2007 | Fossil CH2332 Wrist Watch
La Crosse K2-100 Wrist Watch Logo
91 people viewed this question
Top La Crosse Watches Experts
Starnley Johnwells
Starnley Johnwells
Thomas Perkins
Thomas Perkins
Are you a La Crosse Watch Expert? Answer questions, earn points and help others
