Question about Panasonic PT-53WX42 53" Rear Projection Television
Center Target Blue Convergence and Contrast Adjustment
I have been working on my daughter's Panasonic PT-53WX52F RPTV, which had bad convergence amplifier IC's. Originally the blue convergence was not adjustable on targets 3, 6 and 9. I changed the IC's today and now have full adjustment. Here is my problem. In the Convergence Adjust 1 Menu, I am unable to bring the blue far enough to the left to converge with the center target cross. The blue has a good adjustment range, but when I am at the left hand limit, the blue is still about 1/4" to the right of the center target. In the same menu, the green is adjusted to the center calibration points on the frame, and the red adjusts to the center target just fine. In the Convergence Adjust 2 Menu, I can adjust both blue and red to converge on all 8 targets. Is there a physical adjustment for the blue CRT for the center target (or an adjustment accessable through the service mode)? Please provide instructions. Also, having cleaned the lenses, the picture is plenty bright but it seems to have too much contrast with a loss of fine detail. There is no Contrast adjustment in the Picture Menu. Is that also a Serviceman Mode adjustment? Any help would be greatly appreciated. Thanks.
  • muddakota91 Jan 04, 2009
    i have been tryin to access the menu using these steps but have been unable to get in, are there any specifics as far as the volume and remote? thank you!
  • Panasonic Master
  • 5,138 Answers
Yes there is a Service Code you have to have to get into Alinement menu and its a Dog following step by step to get in! (1) Turn set on cable (2) Turn sleep timer on 30 min (3) Press Action Twice exit menu 4) now tune to ch 124 (5) adjust vol half way down (6) Now Press vol- on front of TV ,now you should see a RED chk appear in upper corner (7) Now Power on remote hand unit and you shiuld be in menu Press cursor to move Mute locks where you want to aline ADJUST with vol-,Vol+ ch- ch+ for up&down back and forth.If you need anymore help let me know .
Press R-tune to change R-G-B
Posted on Dec 25, 2008
Convergence problem on panasonic rear projection TV model PT-53WX52F
the PT47WX42 Convergence repair kit from www.tvrepairworld.com also works for your model. The kit contains the ICs, resistors and the CD with instructions.
Sep 21, 2010 | Panasonic Televison & Video
I have a 7 year old Panasonic HDTV. Picture quality has been great until today. As an example, the banner at the bottom of the picture is visible but it is also displaying in an arch mode above the...
Tv any colors mis alignment.The tv convergence board parts are dead.The convergence board require changing the 2 STK convergence ICS and some or all it resistors,this parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 27, 2010 | Panasonic PT-53WX53 53" Rear Projection...
I got a Panasonic PT-53wx52f from a friend for free, but I'm wondering if it's even worth fixing to work properly. The picture is warped, most notably at the bottom of the screen there is a "bubble". After...
You can get to the convergence menu using either the front panel buttons or the remote, but once you get there see if you can adjust either red or blue in any direction. If you can't adjust both colors in all directions you will need to replace the convergence chips and possibly a few low value resistors. If you need more details simply reply.
Dec 16, 2009 | Panasonic PT-53WX52 53" Rear Projection...
Blue convergence wont work
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly. 4) TV Chirps
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Service Manual for Panasonic PT53WX52F
<span class="postedby"><span style="font-weight: bold;"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadBox1_lblAuthor" lang="6649">lonemountain,<br /><br />Did you receive the Service Manual? I'm in a similar position with convergence problems. If you did, would you send a copy to<br />vipnite at yahoo dot com<br /><br />I would greatly appreciate your help.<br />Kind Regards,<br />Ricky<br /></span></span><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadBox1_lblTime"> </span></span> <!-- from fixya rte -->
Dec 27, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Convergence Problem and Contrast Adjustment
Have you checked all of the resistors inthe convergence circuit as well? If not, check them for the correct impedance.. Remember, you have to pull one side of the resistor out of circuit to measure it correctly.
If all of the resistors are good, then you have to do a coarse convergence adjustment on the set through the service menu.. if you need the service manual for the convergence directions, I have one uploaded in the technicians corner of techlore.com
Dec 25, 2008 | Televison & Video
Panisonic projection tv pt-53wx52f
There is a mechanical adjustment on the tubes themselves when it was dropped it could have knocked it out of alignment, or the Convergence ICs are bad with is a common problem with CRT projection tvs.
Mechanically adjusting the tubes can be tricky I wouldn't suggest working on it unless you have some kind of experence with tvs. But if you do adjust the red and blue to the green.
Oct 06, 2008 | Panasonic PT-53TW53 53" Rear Projection...
PT-47WX53G green convergence and wave on bottom of screen
Had same problem with Red. Could not adjust. Funny broken lines. Found this link:
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Replaced the ICs. Was disappointed at first 'cause it was still all bowed out, but then realized that the Convergence 2 "target" can be changed with the number keys. Working thru 1-9 and going back to readjust as necessary adjusted each one into perfect alignment.
Problem solved. TV works great.
I should add that while I am reasonable technically adept, I am a software geek and never soldered before... hardest part was getting up the courage to dive in and do it myself. Glad I did.
Sep 24, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-53WX52F Color blue adjustment
most likely the two convergence Ics need to be replaced. They are STK392-110 you can get replacements at the following link with free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Jul 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
196 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
