Question about Polaroid M635 Digital Camera
Pictures are not being saved on my new SD card.
Why won't my pictures save to my SD card?
  • 423 Answers
Hi Greg,
Make sure you format the card in the camera before you use it. Cards won't work most of the time, until you do. Also, check to make sure the switch on the side is not in the locked position.
Rob
Posted on Mar 03, 2009
How do I save pictures to my sd card instead of the phones internal memory
in your camera settings there's a storage 0ption to change where your pictures are stored
Aug 23, 2014 | Samsung Galaxy S GTI9000 Smartphone
I gotta problem with my digital camera it looks like it doesn't wanna save any pictures on the card ??? it takes pictures but it doesn't save them?? i got SD elite pro memory card its a brand
There could be a few different problems, one, the pins that are inside that connect to the card often get bent or damaged. Two, the reader itself could be damaged inside.
Dec 11, 2012 | GE Cameras
My camera won't save to mass storage
Are you sure it's an SD card? If it's larger than 2GB then it's actually an SDHC card and won't work in the A300.
May 06, 2012 | Polaroid a300 Digital Camera
How do i save my pictures and videos on to my SIM card?
you cant save pictures on simcard rather memory card. connect your phone to pc in mass storage mode then copy from phone memory and paste in sd card.
Nov 23, 2011 | Samsung SGH-a777 Cell Phone
My brand new nikon coolpix S6100 is showing the internal memory is full after taking only 4 pictures
Hello Jennifer,
Your camera only has 20MB Internal Memory. So, it can only store very few pictures (depending on the settings). It is VERY advisable to use an SD card for your camera so you can save hundreds - thousands of pictures.The bigger the SD card capacity, the more pictures you can save.
I hope this helped you.
You can rate my answer if you appreciate my help.
-damneddle
Oct 20, 2011 | Cameras
Cannot download pictures from phone to computer
The easiest way to transfer pictures from a cell phone to a computer without incurring addtional charges is to transfer the pictures to a mini SD card and then insert the SD card into your PC. If you will tell me what kidn of phone you have, I can try to find the directions for where to install the mini SD card and how to transfer the pictures. At that point, you can also set the camera to automatically save the pictures to the SD card to save yourselves steps next time. : )
Mar 03, 2011 | Cameras
How do i add pictures to my sd card that is in my phone
Well if you want to save your pictues that you take to your SD memory card and if your phone automatically does not do that then you would have to manually choose save to SD card when you are taking the picture. If that option does not show up, try going to the memory settings of the phone and changing it so it saves to the phone. But if you are trying to add external pictures to the phone (ie digital camera to phone) you would have to use a micro sd card reader and a computer to do that. If thats the case you just have to connect the sd card to the micro sd card reader and plug that into the USB port of the computer and just drag and drop the pictures you want into them. then plug that sd card back into the phone and you should have the picture in the phone!
Feb 28, 2011 | Samsung Star GT-S5233 Cell Phone
Just put a new memory card in the camera but the screen keeps showing internal memory is full
How to switch the camera over to saving pictures directly onto the SD card.
    1. Menu
    2. Cam settings
    3. Chose AUTO or SD card option and Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you still experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
    After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    I have a new memory card. I cant get pictures
    Your camera is only supporting SD/MMC Cards (up to 1 GB)
    The card that you currently have might be faulty. Please try another card.
    You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
    Oct 27, 2009 | Kodak EasyShare C330 Digital Camera
    Chip says full after few pics
    The chip may not be inserted correctly. You can tell by seeing or not seeing SD symbol in the view screen. Try removing the SD card. Go through the memory and see if the pictures were saved to the camera or to the card. If the pictures were saved to the camera, turn off the camera and re-insert the card. See if the cards responds by showing more pictures available for taking and move the pictures to the card. If the pictures were saved to the card, then the card may need to replaced.
    Dec 31, 2008 | HP Photosmart R717 Digital Camera
    Polaroid M635 Digital Camera Logo
    69 people viewed this question
    Top Polaroid Cameras Experts
    Greg Cann
    Greg Cann
    Steven Wander
    Steven Wander
    Are you a Polaroid Camera Expert? Answer questions, earn points and help others
