Question about Canon EOS 40D Digital Camera
I have a canon eos digital camera. It has error 99 code on it when I try to take a picture
    Novelist:
  • 121 Answers
Error 99 can be caused by poor communication between the camera and the lens. Often it can be resolved by doing one of these following fixes:
1) Turn the camera off, remove the lens, replace the lens, turn the camera on.
2) If that doesn't work, turn the camera off and remove the lens. Use a clean pencil eraser to clean the electrical contacts between the lens and the camera body. Hold the lens or camera body "upside down" so that the contacts are facing down as you rub them with the eraser so that any eraser debris falls onto the table rather than falling into your camera or lens. Replace the lens.
If neither of these fix your problem you will need to send the camera and lens in to Canon for repair.
Posted on Dec 25, 2008
Error 99
There are many possible causes for this and unfortunately, some require expensive repairs. First, however, try turning the camera off and (in a clean, dust-free environment) removing the lens. Clean the electronic contacts on both the camera and lens (q-tip with 70% isopropyl alcohol is fine). Let is dry and then reassemble. Sometimes this is a lens issue.
Dec 30, 2011 | Canon EOS 40D Digital Camera
When i on my Canon EOS 450D camera it says error 99 turn off and on the camera or re install the battery how can fix this problem
The error 99 code has different sources, to identify it do this:
Remove the Lens, and try shooting at various speed high (1/1000 or more) then at more normal ones 1/15, 1/50 etc.
If you see the error 99 then contact canon this is a problem wit the camera.
In this case contact Canon directly.
If you still don' have the error message, then put back the lens and try shooting at different apertures (for a lens the error 99 correspond with an aperture problem)
try every aperture. If the problem appears then, clean the lens contacts both on the camera and on the lens.
If the problem is still there, contact the lens brand, you certainly have a blocked or sticky aperture.
Hope this helps.
May 19, 2011 | Canon EOS 450D Digital Camera
CANON EOS REBEL XSI 450D BODY WHEN TAKING A PICTURE ERROR 99 COMES UP
Unfortunately, the Error 99 code is a catch-all code that means an UNKNOWN error has occurred. Because of this, it is difficult to pin down exactly what is causing the problem.
It could be a fault with either the camera (main circuit board, software, shutter mechanism etc.) or even the lens.
For starters, I would make sure that the lens electrical contacts are clean and the lens is mounted correctly and fully locked home. If you have a spare lens, try that also.
Next, I would reformat the memory card (do this in camera). If you have a spare memory card, try that also.
Check that the battery contacts are clean, and also the contacts of any external hardware such as vertical grips.
If none of these solve the problem, the only option left is to take it to a Canon service agent :-(
Hope this helps,
Matt
Apr 30, 2010 | Canon EOS Rebel XSi Digital Camera
Error 99 ?
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Apr 14, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Canon EOS - no data on LCD and viewfinder says busy
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
I hope that helps.
Nov 04, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Error 99 in Canon EOS Rebel XS 1000d
Have you been to the support section of Canon's website to find out what "error 99" means?
Aug 21, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Error 99 comes on after I have taken a few pictures. I have tried cleaning with eraser as people have done and it still comes up with message.
I hope that helps.
Jul 14, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Error 99 message keeps popping up
err 99 is moisture or dew inside the camera.
May 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Error 99! Wont' take picture, the message states
Go to the www.canon.com website and find out what Error 99 means. ted10
Apr 18, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon eos 40D error 99
Check this link: www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Oct 20, 2008 | Canon EOS 40D Digital Camera
Canon EOS 40D Digital Camera Logo
163 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
