Question about Linksys Wireless-G WRT54G Router
Linksys WRT54GP2 - cannot access to voice_adminpage
I used this modem for voip.I tried to restart and it stucked. It shows message '' Router still restarting. Please wait a moment.'' Please let me know how can I access to voice_adminpage
  • JDTec
    JDTec May 11, 2010
    Linksys reset
    The easiest method of resetting your Linksys router’s password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL addresshttp://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
    Guru:
  • 1,049 Answers
If you REALLY hosed it, unplug it and let it sit for a while then do a hard reset and try again.
Posted on Jan 26, 2009
I just got the Belkin router F5D7234-4 v3, replaced the old F5D7230-4 v7. Output of Modem goes into Router, one port connected to VOIP adapter - Teleblend. I cannot hear voice on inbound/outbound...
Here is a link to Teleblend tech support.
http://support.teleblend.com/index.php?_m=downloads&_a=view&parentcategoryid=1
With my VOIP setup @ home, my path is as follows:
Modem -> VOIP Adaptor - phone
Ethernet out - router Wan input
Dec 04, 2017 | Belkin F5D7234-4 Router
Linksys Router Issue
My VOIP Adapter is lock I can't reach the web page
Jan 09, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
Linksys Wireless-G WRT54GP2 continually "freezing"
With regard to problems like this you will have to update the firmware on the unit. You can contact your VOIP provider who provided you with the router and have them update the firmware.
Jan 05, 2009 | Linksys Wireless-G WRT54G Router
Can't access adminpage of the router from the 1st lan
you can use ethernet cable, or you can use the wireless.
search for the wireless network and connect your pc to that wireless network. or simply connect an ethernet cable to your pc and connect other end to the Linksys WRT54GL .
open an internet explorer (or whatever you use) type ip address.
Dec 17, 2008 | Computers & Internet
Can't access voice tab on WRP400
If your wireless VoIP router was provided by your VoIP provider they will usually lock this option on the router since they have pre-configured the voice settings(sip server, phone number, password, codecs) before they deliver the device to your location. if you have a working internet connection already you can give your VoIP proiver a call so that they can remotely check the voice settings on their end to verify if it's working or not.
Nov 24, 2008 | Linksys Wireless-G WRP200 Router
Linksys SPA2102 interfearing with winmx/360 sharepro, frequently resetting connection
If your planning to connect the phone adapter behind a router make sure that the following ports are open/forwarded on the router; UDP ports 5060-5061, UDP ports 16384-32767 take note that 5060 and 5051 one are SIP ports and must be assigned to the IP address of that was assigned to by the router to the adapter or the IP that was manually configured on it.
I found a link that could help you check the setting on your linksys phone adapter
http://www.voipvoip.com/linksys-pap2/
Hope this will help you solve your VOiP problem...
Regards,
Sep 11, 2008 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
How do i unlock VOIP on Linksys Router WRT54GP2?
Visit the link and find your model in the unlock links
Unlocklinksys-com
Jul 07, 2008 | Computers & Internet
Lose Connections over and over...
You may need to set specific ports on your router to use the voip. log onto router and go to the applications and gaming tab to set the specific ports voip needs to access Internet.
Jul 07, 2008 | Linksys Wireless-G WRT54G Router
Siemens S765IP w/ router linksys wrt150n
What VoIP provider are you using?
Try connecting router directly to the modem and the laptop to the router and see if your laptop can get out onto the internet. If you cannot, then your router might not be handing out IPs to the devices on the internal network. You can enable the DHCP server on the router using the administrative web interface at http://192.168.1.1.
If you can get out onto the internet with your laptop behind your router then look at defining a DHCP reservation on your router for your VoIP phone and then forwarding the following to your phone:
5061 UDP
5060 UDP
10000-20000 UDP
These are common ports amonst the VoIP providers.
Hope this works, if not we'll give it another shot.
Jan 30, 2008 | Linksys Wireless-N WRT150N Router
Not able to connect my voip adapter to internet
hello sir iam working for voip and iam a tech?
and u r using linksys pap2 which is not a router its just a phone adapter so it will work through a router so try this first
is ur modem is a modem router and u have 4 ether net port on it and u can able to access inter net through hard wired and connect this pap 2 adapter through one of the ether net jack on the modem router (ut starcom)>an dit has a fire wall which block ur voice signals so u need to open some ports on it try this link to open all ports and u need to try this with a pc which connected through hard wired on the modem router go to through this link
http://www.portforward.com/english/routers/port_forwarding/UTStarcom/UT-300R2U/Vonage.htm
and also disable the fire wall on the router screen and reboot the linksys pap2 and ur ut star com modem router also and connect ur phone directly to phone jack 1 on the pap 2 device if u have any issues let me know
and rate me solved if its helps thx
Dec 04, 2007 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Linksys Wireless-G WRT54G Router Logo
208 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
