Question about Canon imageRUNNER 5000 Copier
Hello can you really help me solve the error code that i getting on my IR 5000 the code is E000012-0000
  • printingchin Jan 08, 2009
    i'll check it again thank you. but the other day i turned on the machine and it ran for about 30 minutes before giving me the code again.
    do you think if i replace the entire drum the problem would go away or that wouldn't make a difference?
    thanks again for the response, i'll get back to you
    Sniper:
  • 57 Answers
That error means that you have a problem with the drum motor. Check the it's connectors. Or maybe something keeping the motor from running, like an uptwisted blade with drum.
Posted on Dec 25, 2008
    New Friend:
Canoncopier ir 5000 error e000012 i'my changed Drummotor and d c board not solvedoing problem please help me
Posted on Dec 02, 2016
My copier is apear code E00014
your machine canon iR5000P your Error E00014 i not solve
Aug 21, 2012 | Canon Office Equipment & Supplies
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
CAnon xerox Machine IR 2318 L Error code : E 000007-0000
My canon ir 2318L shows error**E000007-0000 how can i solve this problem
Feb 28, 2011 | Office Equipment & Supplies
My iR 5000 had an error code E000004-0000. solve this
Contact a Canon Dealer/Authorized Service. It's either an error that needs to be reset or you have a hardware issue... with some errors, once you get it, it will never go away until you get a technician to clear it out.
Nov 25, 2009 | Canon Office Equipment & Supplies
Error Message E000001-0000
its a fuser error high temp or lower temp
try to rest this error in *28* FUNCTION,CLEAR,ERROR then on off the machine
if the error the same try to replace tem sensor
Oct 28, 2009 | Canon imageRUNNER 5000 Copier
Canon 500IR - Error Code E000602 0004
Is your copier a IR-5000 or a IR-550? It dose not really matter - the code means that the hard drive in the copier is not "Booting Up" correctly. Are you a service tech? If so, you can try to reseat the boot rom and clean the contacts with rubbing alcohol. After you turn the copier Off and then back On after you reinstall the boot rom. You can also try to do a HD chk in service mode. You will most likely have to replace the "HD" and have it "Flashed" to your copier configuration. Good Luck....
Feb 17, 2009 | Canon imageRUNNER 5000 Copier
Help me quickly
Scanner home position sensor,faulty scanner error .Switch machine on/off if the error still show you will need a qualified tech to atted to your machine.
Nov 02, 2008 | Riso RZ220 Duplicator
Canon iR-2016 System erro E007
hi how do solve this problem system error E007
Dec 04, 2007 | Canon CLC 1140 Copier
Canon imageRUNNER 5000 Copier Logo
393 people viewed this question
old marine
old marine
