Question about Samsung SyncMaster 173T (Black) 17" LCD Monitor
How to open Samsung SyncMaster 173t?
Hi; I need to open this Samsung SyncMaster 173t monitor up to get at the motherboard to troubleshoot... but I can't figure out how to open it up; the four screws holding the base on are the only ones on it, so looks like it needs to be pryed open? Anyone know how? Scared to pry on the wrong spot and crack the thing...
SOURCE: No Power, But I can't open the plastic case
Viewsonic Vx922 is sight tuf to open the rear door
Take and sharp blade
one side there is small gap to insert it
and then just twist and move front and round the monitor
all clips inside will unlock after that it will open
Thank U
Posted on Apr 16, 2008
SOURCE: samsung SyncMaster 913v Monitor
if there are too many black spots already then that means there are lots of dead pixels on your lcd and it cannot be repaired anymore. that will continue to add more dead pixels and eventually damage the device.
Posted on Aug 24, 2008
SOURCE: remove cable
I have the same monitor and it should be screwed to the PC and have some sort of protection over the screws so you don't see any screws on it...
It's there...the screws...
Posted on Mar 02, 2009
  • 563 Answers
SOURCE: How to open the back cover of Samsung SyncMaster 794mg CRT .
"Don't kill yourself just to save some bucks"
Here are the instructions:
http://www.josepino.com/?open-samsung-back-cover
Posted on Aug 29, 2009
Testimonial: "very thanks...."
732nw
k open it from the top side
Aug 27, 2012 | Samsung SyncMaster 732NW,SyncMaster Magic...
Samsung syncmaster 920lm wont stop going off and on
For this case, you need to open lcd case and try to find power inverter board. That cause by cold soldering joint and you need to check and resolder all them.
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jun 30, 2011 | Samsung SyncMaster 920LM 19" LCD Monitor
Hi, I am using Samsung SyncMaster 551s monitor. Suddenly i found vertical stripes in my display when i opened my pc. Pls suggest me solution. Rgds/Himel
if the stripes take 45 dgree and acolor of white then its aproblem in the line then you can decrease the brightness (the 3rd pot) and see
Mar 18, 2011 | Samsung SyncMaster 551 15" CRT Monitor
SyncMaster 203B (Black) LCD Monitor: Monitor will not stay on (Samsung Syncmaster 203B)...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 16, 2010 | Samsung SyncMaster 203B LCD Monitor
How do you open up Samsung LCD 740N monitor?
This monitor contains a latches to open. Its recommended that you use suitable tools and service manual.
If the unit is in warranty its recommended that unit to be serviced by service Engineer.
Dec 21, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
The monitor turns on and off every 1-3 sec, how do I fix it?
Hi dcalderon128;
I'd cover your basics first. Try checking the monitor cables at both ends, make sure they are tightly connected. Next, if the monitor is plugged in to a power strip or surge protector disconnect it and plug it in to the wall directly.
Lastly, if you have more then one computer(including laptops) try plugging your monitor in to another computer.
If any of this solves your problem great!
You may be able to find further information, warranty repair and Samsung Service centre's in your area by visiting the link below:
Samsung Self Service Support
Aug 14, 2009 | Samsung SyncMaster 173T (Black) 17" LCD...
I need a a SAMSUNG monitor driver ( SyncMaster 753s)
You do not need to install any driver to use this monitor. The operating system has built-in drivers for this monitor
Apr 30, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Image blur
You need to check that display resolution in your Display properties is set to the native resolution for wide monitor typically 1440><900 for the size you mention.
Blurred image is due to using 4 : 3 resolution setting of 1024 >< 768 on a 16 : 9 wide monitor.
Samir.
Please rate the solution and provide feedback.
Jan 02, 2009 | Samsung SyncMaster 214T 21.3" LCD Monitor
Schema diagram samsung syncmaster 551v
Hi and welcome to FixYa,
Initially, pls try here.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 10, 2008 | Samsung SyncMaster 551 15" CRT Monitor
Syncmaster 214T
http://s807.photobucket.com/albums/yy352/budm/Samsung%20Syncmaster%20214T/
Replaced all those caps (not hte big on in the primary circuts) with PANSONIC FM or FC series from DIGKEY.COM
May 15, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
Open Questions:
Samsung SyncMaster 173T (Black) 17" LCD Monitor Logo
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
