Question about GE ZFSB26DNSS Side by Side Refrigerator
Resetting temperature to default. GE zfsb26dnss
Both temperatures are reading 27 and 49. What we did wrong? refrigerator was working in perfect condition since we bough it 2 years ago.
    Genius:
  • 2,920 Answers
Unplug the fridge and set the thermostat to where it should be but just a bit cooler....have you moved or tilted it at any time and then plugged it back in right away? if so the compressor will be bad as you have to let them set up for 12 to 24 hours prior to plugging them back in
Posted on Dec 25, 2008
  • 916 Answers
Unplug it for 5 minutes and plug it in to reset it if it does not help. Check the connectors on the control board and make sure they are not corroded. GE fridges are commonly known to have corroded connectors after time.
My freezer has had ice built up on the bottom shelve for about a year now. It leaks once in awhile, what can I do?
The power cut may have damaged the compressor. If it overheated trying to restart it may just click on and off for a while. Check if the compressor is hot and running.
Jul 11, 2015 | Bosch B22CS80SNS (220 cu ft) Side by Side...
Kelvinator beverage cooler E2 error code
Temperature sensor error code.
Login'Contact Us Appliance Appliance Repair Questions? Ask a Technician for Answers ASAP
Ask an Expert Home Improvement Questions Appliance Technician
How JustAnswer Works:
  • Ask an Expert
  • Get a Professional Answer
  • 100% Satisfaction Guarantee
Ask Daniel Your Own Question
Daniel, Home Appliance Technician
Category: Appliance
Satisfied Customers: 16124
Experience: 20+ yrs. experience in white goods repair. NVQ Level 2 electronics manufacturers training courses. Type Your Appliance Question Here... Daniel is online now Hi, I have a BWE40 Wine Cooler and an E2 Error Message.
Resolved Question:
Hi, I have a BWE40 Wine Cooler and an E2 Error Message. What does this mean please?
Submitted: 3 years ago.
Category: Appliance Share this conversation
Expert: Daniel replied 3 years ago.
Hi
E2 error code is a temperature sensor error code.
Remove the plastic black cover on the back and you will see the control board.
On the board you will see a wiring block with 4 thin wires going to it.
Test the 2 wires on the left and the 2 wires on the right with a multi meter. The reading in Kohms (kiloohms) should be the same.
If any are faulty then they will need to be replaced.
If the readings are the same, replace a faulty control board to be rid of the E2 error and your problem.
Feb 12, 2014 | Marvel 61AR Compact Refrigerator
Temperature on display will not go down
HI PAULA.this is too new but the fact that it went wrong after the power cut indicates that the power surge has damaged the pcb board.try manufactures warranty.good luck.Ali
Aug 21, 2012 | Frigidaire Refrigerators
Hi, my admiral side by side fridge is having problems. The freezer is working fine but the fridge is not cooling. I noticed 2 days ago that the temperature indicator for fridge was bleeping at 4 degrees. I...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Admiral 26 cu. ft. Side-By-Side...
I have an all fridge model with water accumulating under the vegetable/crisper bins. Like other I have read about here, I have to sop up the water at least twice a day. I have had this refrigerator for...
I have also had a similar problem with twi different fridges. The first I fixed by unblocking a tube that runs out of the back to a tray underneath where the water goes and evaporates naturally, this was a very old fridge. The second was because of the door seal. I replaced it and it was better but not perfect. I then realigned the door, which seemed to cure the problem. I sold the fridge a year ago, and the guy who bought it says it works fine.
Nov 30, 2017 | Whirlpool EL7ATRR Refrigerator
FRIDGE/FREEZER MODEL: SR42NMB Multi Frost
You have a clogged defrost drain tube. best way is to thaw unit out. Your vents are being blocked so no air flow is pushed down.
Jan 05, 2008 | Refrigerators
GE ZFSB26DNSS Side by Side Refrigerator Logo
57 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
