Question about Acomdata 500GB External Firewire HD 500 GB FireWire 400 Hard Drive
My external won't mount, the light works but it won't mount to my power book G4. help!
  • 3 more comments
  • Anonymous Dec 26, 2008
    Hi, I have the same problem, blue light, doesn't mount. Cant access my data, on web now looking for a solution.  Tried a different firewire cable without success.  My other hard drive mounts ok so I dont think it's my G4 Mac.
    pseroka@serokagroup.com
  • markanels Jan 01, 2009
    Help... blue light on.... hard drive won't mount... won't be recognized by Windows and Apple machines...
    worked just fine for a year... then suddenly.... this!
  • Anonymous Jan 05, 2009
    i have the exact same problem
  • Anonymous Mar 18, 2009
    I just had the same problem with my 320 GB external HD Acomdata.
    Have any of you guys figured out how to mount it?
    My blue light is on, but the hard drive is not being found on my iBookG4.
    Help!!
  • Anonymous May 25, 2009
    I have a red light solid, and the dialog came up "Device removal...etc." I have 260GB of data on it, I am a dead meat.
I opened up the harddrive and noticed that the copper magnetic film strip right above the USB port entry was lifted from the metal. I pressed it down and plugged the drive back in and it worked.
you just have to unscrew the drive on the 4 front side and two small ones on the side using two different phillips. then make sure and register the Western Digital drive inside because it has a seprate warantee. my acomdata is already out of warantee but if the drive ever fails again, I can have it replaced by Western Digital until 2011.
Posted on Aug 20, 2009
Light blinks on my portable WD elements 500 but the computer dosent recognize it. Im using a Powerbook g4 power pc. I have info in it i need to reach & other computers recognize the HD but not my...
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 14, 2011 | Western Digital 500GB ELEMENTS 500 GB USB...
I recently bought a 1.5 terabyte My Book Essential external hard drive. I am trying to copy files from one external hard drive to another with the help of my MAC laptop iBook G4). The laptop detects...
I would suggest copying the data to your My Book as an interim step before copying to the second drive. Copying directly from one removable media device to another will necessarily move the data to your computer temporarily anyway, so there is no disadvantage to simply using your My Book as a middleman in the process.
Dec 20, 2010 | Western Digital My Book Essential Edition...
Powerbook g4 no brightness have yo use flash light
Okay. Try this
http://support.apple.com/kb/TA25861?viewlocale=en_US
If it does not help then it is possible that the Back light on the screen is faulty. If you just purchased the computer, then you should go back to the vendor and ask him to change or fix it .
Oct 25, 2010 | Apple Power book G4 Refurbished Notebook -...
How do i back up a power book g4? What application do I need to do the back up?
Suchisart,
If you want a stand alone backup solution, you can download a free program called "Carbon Copy Cloner" and purchase a USB 2.0 external hard drive. You can use the CCC software to backup the entire contents of your Powerbook's hard drive or just selected files to the external USB hard drive.
If your Powerbook is unable to boot into OS X and you need to recover the files that are on the internal hard drive, you can boot the Powerbook into "Target Disk Mode" and transfer the files via firewire cable to another Mac. To do this do the following.
  1. With both Macs off connect them with a firewire cable.
  2. Turn on the Powerbook and hold down the "T" during startup.
  3. Once the large icon shows up on screen your in "TDM".
  4. Turn on the other Mac and login to your account.
  5. The Powerbook's hard drive should mount on your desktop.
  6. You'll be able to transfer your files from the Powerbook's hard drive just like you would an external hard drive, thumb drive, etc.
Don't forget to vote and leave us some feedback. :)
Thank you,
Scott Computer Services http://www.scottcomputerservices.com
Feb 16, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
How to save data from hard drive off my apple power book g4
You can drag and drop your files on to an external hard drive or USB flash drive, burn the files to CD/DVD using an application called toast - you will need a CD/DVD writer to do that. If you can find one, you can save your files to a zip disk.
Dec 04, 2009 | Apple PowerBook G4 Mac Notebook
I have a power book G4, it's about 4 years now, apparrently i can turn on the laptop but the screen just black out i cannot see anything on it what could the problems be? thank you
It could be the tube that lights the screen not working. best thing is to get it to a service centre.
You can use the mac by plugging in an external monitor to check that the mac itself is OK.
Aug 08, 2009 | Apple Computers & Internet
Power Book G4 reinstall using Power Book G5 OS X10.4.6
Apple have software locks to stop you using the bundled disc in the "wrong" machine, get a copy of 10.4 (try eBay, ) and you should be OK
Apr 13, 2009 | Apple Titanium G4 and 8413i Book series AC...
80 gb hard drive from apple pro book does not work
Try using Disk Utility to mount the drive. This can be found in the Utilities folder within the main applications folder. Launch Disk utility and see if the drive comes up in the list of drives down the left hand side. I presume that the hard drive in the enclosure is spinning. You can normally hear it, and feel a constant light vibration.
May 29, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
External Hard Drive No Longer Recognized
hey im the same person who just posted above. i went to WD's website, and it said unplug the hard drive from the computer, and unplug it from the power source. then plug it into the power outlet, wait for it to spin up, then plug it in via USB/Firewire, whatever. it worked for me, so hopefully it will work for you.
May 11, 2008 | Western Digital My Book Home Edition 500...
Wd external drive screw up
try removing the hard drive from the external enclosure and connecting it to your pc, this way you should be able to retrieve the files from the drive and then reformatting it may fix it and allow you to put it back in the external enclosure.
Dec 31, 2007 | Western Digital Caviar WD2500BB 250 GB...
Acomdata 500GB External Firewire HD 500 GB FireWire 400 Hard Drive Logo
340 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
