Question about Garmin Quest GPS Receiver
Where is the battery in the garmin quest
Opened unit and would like to find battery so that it can be removed.
  • 24 Answers
Http://www.fixya.com/support/t3909146-change_battery
The battery is in the back side of the unit and is glued into place. It has a red and a black wire coming from it to a small plug that plugs into the main circuit board.
Posted on Jan 23, 2010
3 Suggested Answers
  • 24 Answers
SOURCE: Garmin Quest 2 GPS
www.batteryship.com. Look on the screen for "GPS Devices". Click on that and it will take you to a page of pull down menus. Find the Garmin menu and just look for "Quest". Battery is about $25.
  • 24 Answers
SOURCE: replace garmin quest battery
Instead of retyping everything. I outlined it here-
http://www.fixya.com/support/t3909146-change_battery
Garmin quest batteries
I have seen replacement batteries for the Quest GPS units on Ebay. Search for "Quest Battery" or "Quest GPS Battery". You may need to narrow your search but that will point you in the right direction. Another source is Batteryship.com. I have bought several batteries from them and have found their service outstanding.
Apr 05, 2011 | Garmin Quest GPS Receiver
Install replacement battery in Garmin Nüvi 660 and 670. How is cabinet opened?
The Garmin 660 and 670 like most Garmin satnavs cannnot be opened unfortunately. Garmin say that the battery may be replaced by sending the unit back to them only.
Jul 24, 2010 | Garmin Nuvi 660 GPS Receiver
My garmin quest will not come on even when powered by the car cradle. It flickers for a brief second, then fails.
This sounds like an old battery that has deteriorated to the point where the external power won't even turn the unit on. I have a fairly detailed description on FixYa of how to replace the Quest battery. Search for something like Quest Battery. It does involve opening the unit up. If you are not comfortable with the inner workings of electronic equipment, you will need to return it to Garmin.
Apr 06, 2010 | Garmin Quest GPS Receiver
How to change battery on my old Quest? And what type of battery do I have to bye?
I have successfully changed the battery in two Quest II units. While it may not be for some who are intimidated by the inner workings of electronic devices, it is not that hard either. You will need a small Phillips head screwdriver. Removed the back by removing the 6 small Phillips head screws on the back. Use caution with the two screws that hold the endcap for the antenna. It is not a problem if the endcap comes off, but there is a small spring holding tension on the antenna and if it pops out, it is easily lost. Handle the two parts of the GPS gently as there are wires that joining the two sections. The battery is held into the back section of the GPS with some glue but it is easily removed with gentle prying. Use a small flatbladed screwdriver to remove the plug from the battery to the circuit board. This should be all that is needed with the old battery. A new battery can be obtained from www.batteryship.com. They sell the direct replacement for the Quest and Quest II GPS units. When you go to their website, there is a list of various devices they sell batteries for. Click on GPS. This will bring up a page for various manufacturers. Select Garmin, and look for Quest. I think the battery runs around $25.
After plugging the new battery in, you may want to use a small dab of glue to secure it to the back side of the unit like the original battery. Reassemble the unit, reversing the process with the front and the back. The Quest units have a rubber sealing gasket between the two sections. Be sure you inspect that for kinks before tightening the 6 small screws. I would suggest the screws be tightened down gradually so uniform pressure will be applied to the gasket. I would tighten one screw down partially then move to the opposite side and criss-cross the unit until all screws are snug. Again, inspect the gasket for proper seating and you are done.
Jan 17, 2010 | Garmin Quest GPS Receiver
Replace garmin quest battery
Dec 26, 2008 | Garmin Quest GPS Receiver
Garmin Quest 2 GPS
Dec 18, 2008 | Garmin Quest 2 GPS Receiver
Dead unit
My Quest2 has a short in it that drains the battery even when it is turned off. But the battery lasts normal 15 to 20 hours when fully charged and unit is on. Whenever the battery is completely dead, I have to place it on the charger for a hour or two before the unit will even start even though it is plugged plugged in. The battery can be replaced by the staff at batteries plus for under $60.00
Oct 12, 2008 | Garmin Quest GPS Receiver
Screen froze up
"If your Quest locks up....on rare occasions, your Quest may freeze or lock up. In this case, reset the Quest by pressing the unit's Power key and the IN key at the same time. This will turn off your Quest. The unit will operate normally when you turn it on again."
Aug 02, 2008 | Garmin Quest GPS Receiver
Do you know where you got your battery?
I have successfully changed the battery in two Quest II units. While it may not be for some who are intimidated by the inner workings of electronic devices2_bing.gif, it is not that hard either. You will need a small Phillips head screwdriver. Removed the back by removing the 6 small Phillips head screws on the back. Use caution with the two screws that hold the endcap for the antenna. It is not a problem if the endcap comes off, but there is a small spring holding tension on the antenna and if it pops out, it is easily lost. Handle the two parts of the GPS gently as there are wires that joining the two sections. The battery is held into the back section of the GPS with some glue but it is easily removed with gentle prying. Use a small flatbladed screwdriver to remove the plug from the battery to the circuit board. This should be all that is needed with the old battery. A new battery can be obtained from www.batteryship.com. They sell the direct replacement for the Quest and Quest II GPS units. When you go to their website, there is a list of various devices they sell batteries for. Click on GPS. This will bring up a page for various manufacturers. Select Garmin, and look for Quest. I think the battery runs around $25.
May 30, 2008 | Garmin Quest GPS Receiver
Garmin Quest GPS Receiver Logo
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
