Question about Kenmore Vacuums
Kenmore Manual I am looking for a manual for a Kenmore Central Vac ....model # 34630
    President:
  • 2,692 Answers
Sears/Kenmore central vacuum systems are no longer being made ergo no manuals available,especially on line on line. If contacting Sears parts directly, maybe one may be purchased ?
http://www.searspartsdirect.com/partsdirect/contactus.pd
The below website is an example or parts available (outside of SEARS) to fit you centeral vacuum.
http://www.centralvacuumplanet.com/sears_central_vacuums.htmI hope I have been of some assistance with your problem.
Posted on Dec 25, 2008
Wand attached to hose - how do you detach? Kenmore central vacuum system model s107 34730
Many central vacuums have similar or the same parts made by a small number of manufacturers. I found the MD Central Vacuum website to be very helpful and I hope it solves your problem. I have attached pictures and descriptions from their website so you can see if this is what your wand looks like. If so, to separate the wand from the floor brush unit there should be a lever or button on the brush housing you can push with your foot to release the wand. If you are asking about where the wand connects to the hose you push that black button that you see at the top of the wand in the picture, the top smaller black part. I hope this helps.
Sep 08, 2017 | Kenmore Vacuums
Why Kenmore Central Vacuum wont power on?
The unit is overloading proberbly because the motor is seized or burnt out
Remove motor and bench test
Aug 09, 2014 | Kenmore Vacuums
I want to disassemble a canister vac model #5561209 for cleaning. Vacuum bottom plate says to check manual for instruction. Can't find manual for instructions...:)
I can't find the manual for that model number. Here's the Kenmore site with most of their models.
Double check the number, and type it into the given space. Again, that model number comes up blank. Googling it also provides no hit.
http://www.hammerwall.com/Manuals/Kenmore/Description/116.31913/Kenmore%20Vacuum%20Cleaner/L0403208/
However, I did find one for the 55612-90, which may be what you want, or at least very similar (55612).
http://www.hammerwall.com/Download_Manual/60467/
Mar 02, 2011 | Kenmore Vacuums
We just moved in - the house is about 9 years old. I have a Eureka Mega Boss central vac - looks like model # is CV20220. 12.4 amps, 120 volts. Can't figure out what type of bags I need. Can you...
Well, for this unit you will need any of the following bags,
Eureka genuine Part# 90610
Eureka replacement (Central vac bag)
another genuine bag style called CV-1, and/or CV-2
Kenmore Central vac bags
Most of the bags there are available at your local vacuum shop, and sometimes even Sears. The Kenmore central vac bag is, can and will fit your Eureka Mega Boss. Prices range on these bags anywhere from $12-$20 for packages of 3. Generally you will replace a bag once every 3-4 months.
Good luck,
Mark
Nov 10, 2010 | Vacuums
Central vacuum power head no work
Looks like a Beam central vacuum www.beamvac.com, and a Kenmore vacuum head.
Reply what problems you are experiencing and I will try to help.
Jan 23, 2009 | Vacuums
Central Vac does not shut off
Sounds like the relay that is in the central vac unit is stuck to the ON position. When you plug it back in..does it start right up ? If so.. You should be able to disconnect all the receptacle feeds to the central vac unit at the central vac unit to determine which one ( if any) is calling for the vac to stay on.. if none are.. then it is internal to the vac and may be a stuck relay... Hope that gives you some ideas to check...
Aug 28, 2008 | Vacuums
Kenmore central Vac - where to connect low voltage wires?
Mosy central vacs have 2 spades close together that stick out on the side, usually where the circuit breaker and auto/manual switch is. This is where you plug the low voltage wires into.
May 13, 2008 | Vacuums
Kenmore vacuum manuals
I tried what reddevil6 suggested and was not able to get Sears to produce a manual. I would prefer an online manual but at this point I'm desperate enough to try anything.
Dec 10, 2007 | Vacuums
Vacuums Logo
838 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
