Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Need to clean out the defrost drain tube on our Kenmore refrige
Can't figure out how to get into it.
  • 71 Answers
Remove the back freezer panel and the drain is below the coils in the drain trougth. use hot water to remove the ice to get to the drain inlet.
Posted on Dec 25, 2008
Kenmore elite refrigerator
It is suppose to when it defrosts. It is also suppose to drain out into the evaporator pan under the refrig. The tube may be blocked.
Dec 01, 2016 | Kenmore Refrigerators
Kenmore elite model 52603100 freezer defrost water freezes in drain tube/plan then over flows to bottom of unit. freezes then water eventally runs on kitchen floor
You need to clean out the drain tube it's clogged that's why the water is freezing.Try using hot water and maybe something like pipe cleaners to get what's in there out.Hope this helps. On some models it may be easier to pull out the refrig from the wall and get to the drain from the back.
Jun 15, 2011 | Kenmore Refrigerators
Need to know if my refigerator maytag mtf2193ar has any kind of system to drain defrost water because all that water is just acumulating at the bottom of the fridge and is just leaking out tru the door...
Yes the auto defrost drain water should run into a drain tube and out into a pan under the refrig where it just evaporates. You have a clogged drain and will need to look for it. Move your refrig out from the wall and you should be able to see the drain hose and get it cleaned out.Hope you find this helpful.
Jun 15, 2011 | Maytag Top Mount Refrigerator w/Cool Flow...
Leaking water maytag plus rsw2400eam ...ice maker not hooked up. seems to be coming from freezer side can you help
When your refrig goes into auto defrost the water normally goes down a drain tube and into a drip pan under the refrig, then it evaporates. But now your drain in plugged somewhere and you will need to find it and clean it out. Hope this gets you going in the right direction.
Jun 05, 2011 | Refrigerators
1992 T&B refrig drips water from inside top of refrig compartment Is it a blocked drain tube? Or bad heater evaporator unit?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 25, 2010 | Amana ATB2135HR Top Freezer Refrigerator
Kenmore refrig/freezer. freezer side is cold,
Check your condenser coil (should be below the refrig.). If dirty, you can clean it with a condenser brush from Home Depot or Lowe's. Turn the appliance off while cleaning. Be careful not to damage the refrigerant tubing (copper). If this doesn't solve the problem, then there may be an issue with the defrost thermostat, defrost heater(s) or the main temperature control assembly.
Contact an appliance service company.
Feb 17, 2010 | Kenmore Refrigerators
Kenmore Cold spot refrigerator model 106 70182001 leaking inside in the back of the refrigerator. Having to keep bowls in the back of the top shelf. How can I fix this?
Your defrost drain in the frezer is cloged. Every day when your refrig sellf defrosts the water should drain into a hole that leads to a tube wich drains the water to a pan under the refrig. You need to turn offrefrig and remove frezer floor and rear wall and clean out hole and tube with hot water.
Dec 12, 2009 | Cars & Trucks
Leaking water from kenmore freezer to refrig below
its possible that the drain pan behind the back freezer wall is clogged or coverd with ice, sounds like when unit goes into defrost melt water leaks under sides of drain pan and into fridge. unplug and remove back freezer wall if drain is covered with ice defrost the ice, can be prevented by loosely coiling a piece of solid copper wire around element and into drain slightly radiant heat during defrost should keep drain fromicing over. if drain is just clogged wth debris clean drain and you should be good to go, hope this helps you.
Mar 14, 2009 | Kenmore Refrigerators
I have a Kenmore Elite top freezer refrigator. Water is driping or somehow forming on the top shelves [under the top freezer] and a thin layer of ice will appear and the water contuniues to form. then over...
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 02, 2009 | Kenmore Refrigerators
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
110 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
