Question about Refrigerators
How can I clean out the defrost drain tube on my kenmore refrigerator?
  • 145 Answers
Happy Holidays and welcome to Fixya!
What I use to clear out clogged defrost drains is a turkey baster and hot water. You can get them for a few bucks at any grocery store. I have one I modified with a length of 1/4 plastic icemaker line so I can get it down into tight places. Some defrost drains are recessed so you can't get to them very well with the baster, but having the plastic line as an extension can make for quick work when clearing a defrost drain.
Take some hot water in a container like a pyrex measuring cup draw the water into the baster and then use it to melt the ice coating over the drain and then you can work your way down into the drain to the point where you can use the baster almost like a plunger of sorts. And once you get the drain unpluged, pour more hot water straight down the drain and flush it out.
The only thing to be careful of is this- if you try to use REALLY hot water, when you draw it up into the baster, it will want to shoot back out at you, so be careful!
I hope you find this suggestion useful. it always works great for me.
Posted on Dec 25, 2008
Kenmore 10677181791 water dripping into refrigerator from freezer
probably an ice buildup around the drain tube not allowing proper flow thru to the drain. Try defrosting fridge for a while so the entire ice mass defrosts in between fridge and freezer
Feb 09, 2012 | Kenmore Refrigerators
About every 4-5 days I notice water on the floor coming from under the front grille.I assume it has something to do with the defrost cycle and maybe a drain tube is clogged? I have a 25 cubic foot side by...
Yes its possible clogged drain tube will cause that, de-clogged it by using soft stick or solid wire right enough to penetrate inside the drain tube. Then clean it with water, before doing that transfer the inside of refrigerator (food, beverages, fruits,etc) get it back until you finish the job.
Jun 12, 2011 | Kenmore 53642 / 53644 Side by Side...
Refrigerator and freezer have a bad smell. I
Remove the back panel in your freezer and at the bottom of the evaporator coil you will see a hole about ½” in diameter this is the drain tube. You might need to use some warm water to melt the ice and then run a wire being very careful not to puncture the hose and run it down the tube to free up the drain. This tube travels down to the bottom of your refrigerator to a pan sometimes located on top of the compressor or somewhere else down there. It collects the water there to evaporate. You can enter your model # at www.appliancehelponline.com for a diagram or illustration of your refrigerator. Not all models are available.
Mar 31, 2010 | Kenmore 64802 Top Freezer Refrigerator
It is leaking water and the bottom of the refrigerator has water
Is water leaking OUTSIDE your refrigerator or INSIDE at the bottom of your refrigerator ? If it is inside your refrigerator the most common reason is a clogged defrost drain tube - The water collects from a defrost cycle and drains through a hole on the ceiling of your refrigerator into a cup that drains it through the tube down to the defrost pan at the bottom of your refrigerator on the back and evaporated by the compressor heat. Sometimes this tube gets clogged and water does not drain from the cup and overflows inside your refrigerator against the backwall.
Aug 16, 2009 | Kenmore Refrigerators
Need to clean out the defrost drain tube on our Kenmore refrige
remove the back freezer panel and the drain is below the coils in the drain trougth. use hot water to remove the ice to get to the drain inlet.
Dec 25, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Water on floor in the morning front of refrigirator
HI thanks for your question. the drain tube is under the freezer. the drain hose goes to the drain tray at the back by the compressor. pull fridge from wall, remove the back panel, clean all the dust on the coils. find drain tube, by the drain tray. turn fridge off. let thaw. clean out the drain tube. if you need more assistance. please don't hesitate thanks
Oct 15, 2008 | Kenmore Refrigerators
Kenmore 71192100 frost free keeps freezing up
Hi. thanks for the question . The first thing i would do is clear the drain tube .that could be why the freezer ices up .too much moisture Clean the drain, And the coils at the back. thanks the appliance doc
Sep 14, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Defrost drainage
Very simple to fix. Remove freezer panel at the back of the freezer. Thaw collector pan at the bottom of freezer in the back. Make sure hole in pan is also thawed and cleaned. You may have to remove the panel on the back of the refrigerator to clean .the drain tube under the unit, A drain tube heater can be installed to prevent future freezing, but I would suggest a service tech to perform the procedure.
Jun 26, 2008 | Kenmore Refrigerators
Kenmore Refrigerator-Freezer top
install a defrost drain tube heater call sears for a part number have the model handy befor calling
Apr 21, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Open Questions:
GE Spacemaker JVM1339ww002 - looking for photo of plugs in control board plugs for reassembly or a wiring diagram? Disassembled without noting locations and now start & clear buttons do not work. I have a very old model GE spacemaker XL microwave, model# JVM1339ww002. I repaired the #1 key by cleaning contacts and reinserting the ribbon connector to the control panel. However, I did not photograph the connections. Some plugs have only 1 location where they fit. However, 2 pairs of plugs are the same size and I do not know the correct place to reinsert them. I took a guess & reassembled the microwave and it worked except for the start/clear buttons. If you press a number 2 shortcut for example, it will cook 2 minutes and the food is heated. However, start and clear do not work at all. These buttons DID work before I repaired the numbers. I contacted GE and they gave me a hard time about providing the wiring diagram which was removed or not inside my microwave. I am not sure if I reassembled the plugs wrong OR if I broke something else when I was repairing the numbers. Can anyone help me with the right locations for the 2 pairs of plugs listed below? And/Or tell me if it sounds like start & clear are a new problem or will be resolved by getting the plugs correct? These are the 2 sets of plugs that can be inserted in either location: 1) a pair of matching white plugs that snap in place along the bottom (1 has white wires only and the other has 1 white/1 black wire) 2) a pair of red and white plugs of equal size in the middle of the board. They are similar (but smaller) to plugs in wall outlet with 2 prongs. Similar to a wall outlet, you can rotate the plug 180 degrees and they still fit. In other words besides asking which plug is upper or lower, do I need to worry if the plug is upside down or this doesn't matter? The red plug has black wires, while the white plug has blue and white wires.
Apr 19, 2018 | GE Refrigerators
Refrigerators Logo
325 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
