FixYa.com
Tags:
Panasonic TH-42PD50U 42 in. EDTV Plasma Television
Panasonic VieraWidescreen Plasma TV Model No... (by 4 users)
posted by satishyerra on Apr 14, 2007
It has been year since I dont have problem any more with Plasma, suddenly my Plasma TV is getting in standby mode and it turns of automatically with RED light- aledy (redlight -near ON/OFF Switch of TV)keeps constinously blinking
To restore back for temporary solution, i switch off the power completely and switch back again,
It blinks for sometime and plays very well for first 40 minutes, then it goes again in standby, then when i do the same process , this works for 10 minutes and then it goes to stand by
I checked all the setup menu , and made sure that the OFF TIMER is not activated
I am out of warranty and now I called a servce centre , they give my high quotes to just see for inital investigation
I doubt wether a change in power cord can save the problem ,
I am from australia, and there are no current fluctuations in my area,
Please advise
Thanks and regards
Satish
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by Guest, posted on Jul 28, 2008
my panasonic th-50px75u plasma turns itself off after approx. 50 minutes. the red light flashes 8 times. i have to unplug set for awhile to reset it.
Comment by texas10380, posted on Jun 30, 2008
Same problem here. Panasonic TH-42PV30 (4 years old) Read on US website that it is a common problem with 6th Generation Panasonic Plasmas. Apparently it can be repaired with a 25cent part. I contacted Panasonic (even though it is out of warranty) They wouldn't confirm the problem and could only provide details of an authorised repairer.
Comment by chriswa, posted on Mar 23, 2008
i have the same problem has anyone found out why and what is needed to fix.
Provided by PANASONIC STAFF
Best Solution
posted on Jul 21, 2008
FixYa! (100)
AMRITH
STAFF
Rank:Master Master
Rating: 79%, 10 votes
Hi, you did not say how many times the red led flashes. This is an important clue as to where the problem might be. On some 6th generation plasmas, a regulator in the power supply could cause that problem and had to be replaced with an improved version.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Flat Panel Televisions problems?
Panasonic TH-42PD50U 42 in. EDTV Plasma...
hd tv problem
I have a 42 panasonic hd tv... Answer This...
Remove front cover and replace...
I have on order the entire... Answer This...
tv or cable issue
i recently purchased a 50 inch... Answer This...
Panasonic TH-42PD50U 42 in....
Hi Kevin, the comments posted... Answer This...
cable connector
the connector that is attached... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
