Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Netgear dgn 2000 port trigering
How can i open port for m-torrent
  • 854 Answers
Port Forwarding A. Determining the IP Address and MAC Address of a Computer: Note: Please use the computer for which the Ports are to be opened: For Windows 2000/XP users: 1. Please click on Start and select Run. 2. Type in cmd and click on OK. 3. In the Command Prompt, please type ipconfig/all then press Enter or Return key. 4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router). 5. Please note down the IP address and Physical address. B. Reserving an IP Address: 1. Please open any web browser like Internet Explorer or Netscape Navigator. 2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key. 3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password". Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it. 4. When the setup page opens, click on LAN IP Setup under Advanced tab. 5. Click on Add under Address Reservation. 6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table. 7. If the computer you want is not on the list, please click on the Refresh button to update the table. 8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add. 9. Click the Add button when done. C. Opening Pre-Defined Ports for Internet Services: 1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu. 2. Please select the service type Port Forwarding. The router pre-defined services are listed there. 3. From the Service Name pull down list, select the service that needs to be hosted. 4. Enter the IP address of the computer in the Server IP Address box. 5. Click the Add or Apply button. 6. Repeat all steps to open more ports. Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below: D. Opening Ports for Games, Applications or Custom Ports: 1. Click on Add Custom Service button. 2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box. 3. If the application uses only a single port; type in the same port number in the Ending Port box. 4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box. 5. Type the IP address of the computer in the Server IP Address box. Click Apply button. 6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation. 7. Repeat all steps to add more ports for more services. E. To Edit or Delete a Service Entry: 1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page. 2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Posted on Jun 15, 2009
Dell XPS M1530 laptop can't access Internet with Netgear router DGN 1000.
Have you opened Internet Options, Connections tab, Lan settings, Check Auto Detect. OR release and renew your IP address : http://www.wikihow.com/Refresh-Your-IP-Address-on-a-Windows-Computer Is your wireless adapter enabled? Drivers up-to-date? in working order? Have you run the diagnose in Manage Network Connections. What is your Anti Virus? Try connecting with it disabled?
Dec 26, 2012 | NetGear DGN1000 Wireless Router
Netgear G54 Wireless Router says authentication failed
To RESET the Netgear, power up the Netgear then press and hold the RESET button at the back of the router until all the LEDs flash. Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Dec 01, 2012 | NetGear Computers & Internet
I have a netgear DGN 3300 wireless-N router. I can't seem to open any web pages. Any advise? Could it be my router settings?
its either router settings or your computers internal security settings
(Anti Virus or Firewall).
I would reset it and start again personally or.........
Try running your internet connection wizard again and that will replace the existing connection to the net when its finished,
If still nothing then reset the adaptor settings
I have an example of a router set up on this link below....
http://www.fixya.com/support/r4582466-set_up_speed_touch_5x6v6_broadband_modem
Please rate me thanks
May 07, 2010 | NetGear RangeMax DGN3300 Router
Cant play online
You need to login into the router setup page and need to trigger the ports which your play station use,,,you need to change the mtu to 1365 and mac filtering should be disable,,,,firmware should be up to date
Dec 30, 2009 | NetGear DGN2000-100NAS Router
It is blocking while i am uploading from torrents
Hi Ashutosh first of all make sure that the ports for your application is opened or not on the netgear router. It might be possible you required to do port forwarding. Still if are looking for the steps how can you open ports let me know.
Thanks
Oct 26, 2009 | NetGear WGR614 Router
Netgear DGN 2000 won't connect to internet by cable / wifi works
Might I suggest looking at the routers configuration. This can be done by typing in 192.168.1.1 into your web browser. Typically the default log in is: User Admin, Password is password. You want DHCP set on. Save all your settings. Then reset to factory default. There should be a reset button on the router. This will reset it to when it was new- any changes you made will be gone.
Oct 11, 2009 | NetGear DGN2000-100NAS Router
Hangs with Bittorrent
That is because you need to open a port on router with the same number assigned to your torrent client.
You need to check port number on bittorrent configuration, then access router control panel typing router IP on internet explorer address bar and configure the router to open the port.
Read the following articles.
How to configure your router to allow fast BitTorrent downloads
Brian's BitTorrent FAQ and Guide: What ports does BitTorrent use
Slow Bit Torrent downloads? Router configuration tips.
Opening port BitTorrent |
forum.bittorrent.com / how to open firewall/router port
Guide to Open or Forward Ports for Utorrent and Azureus BitTorrent
Port Forwarding for the Netgear WGR614
Tweaking your system to get the most out of BitTorrent
Apr 13, 2009 | Computers & Internet
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
318 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
