Question about RCA Lyra RD1080 MP3 Player
Cant play newly added music
I tried to add new music files and when I went to play them all I get is a 'error in memory' message. Help
  • 25 Answers
Sorry to say but the Lyra 1080 is the worst mp3 RCA ever put out...before my warrenty ran out i went through 5 of them...My advice is never use the play media junkbox or anything that will end up corrupting ur device....just get rid of all of that **** and just plug it in and it should come up as a drive in My computer from there click the drive and you should beable to see all ur music thats on ur external drive or pull out ur card them plug it in then you should see whats in ur internal memory add or remove ur music
Posted on May 13, 2010
    Problem Solver:
  • 12 Answers
Never had that problem make sure you did not delete some files that came with your player if you did your player will not play your music use windows midea player at 64k not 32k playes better
Posted on Apr 20, 2009
"Not enough free space"
If you delete files on a MAC they are still there. Go to Options or Utilities folder (depending on which OS is running). Use the clean utility to clear the dead files.
Mar 04, 2014 | Philips GoGear Ariaz MP3 Player
Hi, I would be very thankful if you help me. I have a brand new Mp3 Memorex 8590 and have added around 50 songs and it shows when playing one song on the display 1 of 1, and once the song is over, the...
It seems your new mp3 player memory is already full, you need to delete other files or songs before you added another. If it is not yet full, try to delete and reinstall other songs. Be sure the file songs you added has no error on it.
That the only things you will do, the mp3 player operate normally and trouble come as you add new songs, don't overload it, as it's built in memory will fail.
Thanks for asking.
Jun 22, 2011 | Memorex MMP8590 MP3 Player
NOT ABLE TO ADD SONGS IN MUSIC PLAYER FOLDER
In order to add music to your mobile you have to do it through your mobile itself. You can copy any number of songs to your memory card according to the memory available. Then start your media player in your phone go to options and select update media library. Your media library will automatically search for music media and add it to your playlist.
Jul 25, 2009 | Nokia N82 Handheld
Cant transfer music files from card to phone or find them.
I had the same problem and realised that you have to copy the file from the music section on your external memory to the sounds section. Firstly I sent an album to my memory card via windows media player and it went to the music section. My phone recongnised it was there on the external memory but not when I tried to play it through the mp3. I read an earlier message and it mentioned that the music needs to go into the sounds file so I copied it to that file and hey presto, I have music on my external memory that actually plays lol
Jun 18, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Cant play the music
Add music to I9
Connect your i9 to your PC via the USB cable.
On the phone select "Mass Storage Device".
On the PC you will see 2 new drives appear.
One will be the SD card. The other is the Phones internal memory.
Now just simply copy your MP3 files to the Memory card folder "My Music".
Do not use the phones internal memory as it just is not big enough.
The Audio player will only play music from a folder called "My Music" or "MP3"
depending on which firmware version you have on your i9. If one doesn't work try naming it the other!
Also make sure you are selecting the right storage area in the Audio player options, either the phone
or the memory card, because there can be identical music folders on both, and if you don't choose the
correct storage location, your music files still won't show in the Audio player!
Make sure the audio file is in a format the i9 can play. Known music file types are mp3, wav, amr, m4a, & mp4.
DO NOT place music in sub folders within either of the My Music or MP3 main folders, the Audio player
will not find them unless the music files are directly within the proper My Music or MP3 folders!
Every time you add new music to your i9 you will need to refresh the List in order for the audio
player to see all the newly added songs. To do this open the player. Tap "List" at the bottom of
the screen. Tap "Options". Tap "Refresh list". You can also go into the audio player settings &
turn ON the "List auto gen." option. If the option is ON, then after you add new music, the new
music should be added to the entire list of music already showing. If you have problems with the
music list showing up empty, or new music you have just added not showing up in the current list
of songs, then try turning OFF the List auto gen option and refresh the list manually again by using
the Refresh list option as described earlier. Manually refreshing the music list must be done every
time you add new music files to the phone if the List auto gen option is OFF.
You get to the List auto gen option by two ways with the Audio player open and onscreen
for most i9 firmware (some firmware might not have it, or may be in another area);
1.) Tap the little wrench icon to the far right on the black option panel,
then scroll down to the List auto gen. option!
2.) Tap the List option at the bottom of the screen, tap the Options button
screen, tap the Settings button, scroll down to List auto gen.
Apr 15, 2009 | Dual Electronics CECT P168 Cellular Phone
Unsupported file format
Maybe the phone line was cut. Call your provider and ask them whats up.
Dec 30, 2008 | Samsung SGH-D900 Cellular Phone
Memory full.
the phone memory must be free... so transfer all your datas from phone memory to memory card...........
keep some 20 mb free phone memory and then try..
it will surely transfer
Feb 17, 2008 | Sony Ericsson Walkman® W880i Cellular...
Message says player error - music is not available?
Your VX8300 can only play .wma files .. so if there's any .mp3 on there it's going to say that. Also, if you recently put on new files try taking them off then trying the card again .. .if that works then one of your new files are corrupt/unreadable
Another thing to try: goto: Get it now .. music n tones....my music ...songs ...options...reinitialize library database. ( Be warned, you may lose some files this way so make sure everything is backed up on your PC)
Nov 30, 2007 | LG VX8300 Cellular Phone
Samsung j600 mobile phone MP3 player not playing MP3's
If your music files are in a folder you cannot add them to play list, but if you have all your songs singly you can add them to your playlist, I had the same problem tonight with this phone, we added them individually no problem, this has worked but is a lenthly prosses, so far so good, not had a play about with them other than this, still to get them back as an album not yet done, Jackie
Any problems ring virgin, they were very helpful, SGH-J600 User guide not explained very well
Oct 23, 2007 | Samsung SGH-E900 Cellular Phone
RCA Lyra RD1080 MP3 Player Logo
101 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
