My Element 32 inch tv has black screened.
Its an Element T.V. ELCHW321 is the model number. The screen went black, I have sound, and if I shine a flash light in it, I can see the screen. Help!
  • 21 Answers
Hope I dont sound too crude, but have you checked the contrast and brightness controlls ?? they may be labled as 'picture options' or some other odd label...
does this tv have a LED, LCD or the older CTR display ?? If it is LED or LCD, then the light source that illuminates the screen are not working.. this light source could be damaged..
Posted on Sep 09, 2012
SOURCE:
  • 81 Answers
SOURCE: black screen in middle of picture
go tothe menu, caption, take it off the text mode. this should solve your problem
Posted on Apr 07, 2007
Shuttle83
  • 1139 Answers
SOURCE: RCA 32 in TV no picture no sound just a beeping noise TV power is on
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Shuttle83
Posted on Mar 24, 2008
bhur
  • 85 Answers
SOURCE: 32 INCH tv
the cpu of your tv is not working,coldsolder the mainboard of your tv and the cpu then get the voltage output of your tv.
Posted on Jun 13, 2008
  • 280 Answers
SOURCE: black screen on EVERY input/channel
Turn off the closed capition
Posted on Jun 19, 2009
SOURCE: Black box taking up over 1/2 the screen.
caption box selection is on. disable caption
Posted on Jun 29, 2009
Very low sound on Element 32 inch model no ELCHW321
A couple of possibilities, both will require repairs to the tv. Either the speakers are blown, or more likely the speaker amplifier on the main board is bad. Both are repairable if you want to spend the money. It is probably cheaper to buy a new 32" tv than to have your tv fixed.
Aug 02, 2016 | Element Televison & Video
I have a elchw321 model. I get a picture, but no sound
Please look at p11 of the manual available here
Element ELCHW321 User Manual
I don't know if this only an online reference or whther it's available as download.
If your computer has an HDMI o/p just connect that, this should supply video and audio. If not you will have to connect the aufio and video using separate leads. Note what it says about not all computer equipment being compatible with your monitor
10.March.2015
Mar 01, 2015 | Element ELCHW321 32-Inch Class 720p 60Hz...
How do I hook up a laptop to my 32 inch element to watch movies?
You have to activate the external video port. Usually F8. Check your owners manual.
Nov 18, 2014 | Element ELCHW321 32-Inch Class 720p 60Hz...
How to fix a crack screen on my 32 element TV model elchw321
There is no repair to a cracked screen, other than replacement.
May 08, 2013 | Televison & Video
My t.v has blacked screen, how can I fix this. I am technological inclined.
most likely you have a failed backlight inverter, but there could be other issues as well. IF you have access to a multimeter, you will first you want to verify that the 24vcd output is present from the power supply. Second, you want to verify that you are getting the "backlight on" signal from the main board which should be around 3vdc. There should be a terminal on the power supply or inverter board that says "BL ON" or "lamps". If it is your inverter that has failed, the good thing is that they are usually very cheap and easy to replace.
Sep 09, 2012 | Televison & Video
I have an Element 32" flat screen tv model # ELCHW321 that i am trying to use as a computer monitor via vga to vga connection and am not having any luck. The tv says no signal. I have tried a newer laptop...
When you are using a laptop you have to press and hold down the function key and hold down the dual monitor key (either F5 of F8) for about 15 full seconds. The screen of your laptop should darken and the image should come up on the tv screen.
May 06, 2010 | Element Electronics FLX3210 32 in. LCD TV
32" flat screen that went black
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 17, 2009 | Element Electronics FLX3210 32 in. LCD TV
Flashing red ''M'' all over Screen
As you have only recently purchased the TV and it is misbehaving right in the begining, then I suggest that you return and replace it with another piece. Or another brand if possible.
Nov 08, 2009 | Element Electronics ELCHS371 37 in. LCD TV
Televison & Video Logo
193 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
