Question about Microsoft Windows Vista Ultimate Edition
Laptop (32 bit Vista Home prem) only starts when F1 is pressed
The HP laptop is 18 months old. Will not wake up from sleep or restart unless the F1 key is depressed and specify the OS you want to use.I did a full restore from a backup copy but cannot seem to be able to use my recovery DVDs that I created nor can I use the recovery files on my hard drive. Apparently there are errors (?). Using the F8 key during bootup doesn't help because the computer will not autostart I do not have vista disks. .
  • 199 Answers
You need to reinstall your OS, probably both OS are corrupted. create a buck up of your important files before you format your laptop
Posted on Dec 25, 2008
  • 916 Answers
Go into your bios and turn off the option to have to depress f1, as well as switching the first boot device from the hard drive to the disc drive. After you have done this insert the backuip disc and run the automated recovery tool.
  • machadojr_fe Dec 25, 2008
    also if you are dual booting which operating systems do you have installed?
    Genius:
  • 2,920 Answers
Try turning the cmos battery over for a couple of minutes and then put it back in the way it was to bedin with. it should clear the memory and allow you to start all over again. the cmos is a small battery inside the computer and as i said it shoudl clear the memory of all its errors as well
  • 100 Answers
Try resetting it to optimized defaults from bios setup.also change the cmos battery.and select none in the setup instead of 1.44 floppy disk drive.
  • 15,935 Answers
You now have a dual booting system, and installed both O/S.
  • blueextc3221
    blueextc3221 Dec 25, 2008
    You cannot use a 64 bit program on XP, and likewise cannot use a 32bit program on Vista.
    You have the best of both worlds if both O/S work, Leave it.
  • blueextc3221
    the problem is NOT in BIOS if you are asked to select O/S !!
My Toshiba Satellite S75D-A7272 laptop has always had a problem with getting it out of sleep mode. Is there a fix for this?
Sleep or standby mode should allow your computer to conserve energy yet respond quickly to power back on when you need it. Most Toshiba laptops should exit sleep mode if you press a key on the keyboard or use the trackpad mouse. If the lid was closed, opening it should also wake up the computer. If none of these methods work to bring the computer out of sleep mode, you may have a power issue or software glitch. Causes Insufficient power can cause this problem, so try plugging in your Toshiba laptop before attempting to wake it from sleep mode. If this does not immediately fix the issue, your problem is more likely a software issue. If your laptop was shut down incorrectly prior to the sleep mode incident, it may be stuck on a blank screen that makes it appear to be in sleep mode when it actually is trying to start up.
Indications Press the power button for a few seconds to see if your computer will wake up. If it does, the laptop was not truly stuck in sleep mode, but rather went into hibernation mode. If your laptop is truly stuck in sleep mode, you may be able to force a shutdown by holding down the power button, but when you power back up it will move right back into sleep mode. In some cases, the power button may not shut down the computer from this mode at all.
Solution The best way to solve your Toshiba's problem is to completely remove all power from the laptop to ensure a fresh restart. Close the laptop's lid, turn over the unit and remove the battery. Also remove the power adapter cord from both the laptop and the wall socket. Open the laptop lid and press and hold the power button for approximately 20 seconds. This will drain any stored power in the backup battery. Wait a few seconds, then put the battery back in, plug in the laptop and press the power button to turn on the computer. It may start up with an error screen; in this case, select the option to start your computer normally. If the error recurs, start the computer in "Safe Mode" to see if a program running on your computer outside of the basic Windows operating system is causing the problem.
Further Help Sometimes this issue also requires holding down a specific key, such as "F8," when you restart. If the basic power drain and restart process doesn't work, you can use Toshiba's support website to look up further information for your specific model. Just click the "Product support" tab and enter your laptop's model information, then read through the support bulletins listed for your particular Toshiba model. Toshiba also maintains a support hotline at Call us : +1 850-610-1013 https://www.instantprintersupport.com/toshiba-printer-support
May 28, 2018 | Toshiba Computers & Internet
What is correct way to start computer back up from sleep mode
Unless you have set up differently, press the power button for no more than 1 second.
Mar 18, 2014 | Dell Computers & Internet
HP DC7800 doesn't wake up
Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity The computer will power-down and turn off unnecessary systems, including the monitor, while keeping the memory active so it can start back up quickly and still have all programs up that were being used prior to entering sleep mode. While this is a helpful feature that can extend the battery life of a laptop, it can result in errors where the computer won't power back up. You can usually solve the problem quickly.
Look for a sleep-specific key on the keyboard. It will usually be near the top row and have a symbol of a moon on it. Press this key as some laptops only respond to that command to come out of sleep mode. Press the "Enter" key to see if that will cause the computer to respond. Move the mouse back and forth several times and click the mouse button. Hold down the power button for 5 seconds if the previous methods have not worked. This is another common method for exiting sleep mode for many laptops. It may also trigger a full computer restart which would also solve the sleep mode problem. Unplug the laptop and remove its battery.
Reinsert the battery and then plug the laptop back in.
This should cause a full restart when the power button is pressed. Download the latest video drivers from the website for your video card manufacturer. Old drivers can sometimes cause problems with the laptop's power functions. See if your computer manufacturer has an updated BIOS on its website. The BIOS (basic input/output system) is the firmware that controls the initial boot processes for your laptop. Computer companies will release updated BIOS firmware if they get multiple complaints of boot or power problems. The BIOS interfering with Windows Power Manager is a frequent cause of sleep mode problems. Adjust your BIOS settings by rebooting the computer and pressing the appropriate function key when prompted on start up. It will normally be F1, F2 or F3, and you will often see a message during start up saying to press that key to enter the BIOS. Experiment with the BIOS settings by scrolling through the menu and locating Power Management. Increase the amount of time the BIOS allows before hibernating to make sure it is higher than the the Windows power setting. This can help eliminate conflicts between the BIOS and Windows concerning power shutdowns.
Jan 28, 2013 | Computers & Internet
Not wake from sleep or hibenate
Usually, to wake from sleep pr hibernate, you just need to press the "Power" button of your laptop. It will not turn it off or restart the laptop if it is in the "sleep" or hibernate mode. Pressing any key usually wake it up. The default way is to press the power button as if turning it ON for the first time.
Feb 11, 2010 | Toshiba Satellite Pro M300-S1002X Notebook
My brother just gave me his hp pavilion dv4-1313dx laptop and i want to reinstall windows vista. how do i remove windows xp? i just want to clean all of his garbage out of my laptop then reinstall vista,...
First check the System requirements The following list describes the recommended minimum hardware requirements for basic functionality of the different editions of Windows Vista. Actual hardware requirements vary, depending on system configuration and on the programs and the features that you install. If you install Windows Vista over a network, additional hard disk space may be required.
Windows Vista Home Basic
  • 800-megahertz (MHz) 32-bit (x86) processor or 800-MHz 64-bit (x64) processor
  • 512 megabytes (MB) of system memory
    Note On system configurations that use system memory as graphics memory, at least 448 MB of system memory must be available to the operating system after some memory is allocated for graphics.
  • DirectX 9-class graphics card
  • 32 MB of graphics memory
  • 20-gigabyte (GB) hard disk that has 15 GB of free hard disk space
  • Internal or external DVD drive
  • Internet access capability
  • Audio output capability
Windows Vista Home Premium, Windows Vista Business, Windows Vista Enterprise, and Windows Vista Ultimate
  • 1-gigahertz (GHz) 32-bit (x86) processor or 1-GHz 64-bit (x64) processor
  • 1 GB of system memory
  • Windows Aero-capable graphics card
    Note This includes a DirectX 9-class graphics card that supports the following:
    • A WDDM driver
    • Pixel Shader 2.0 in hardware
    • 32 bits per pixel
  • 128 MB of graphics memory (minimum)
  • 40-GB hard disk that has 15 GB of free hard disk space (the 15GB of free space provides room for temporary file storage during the install or upgrade.)
Note A Windows Aero-capable graphics card is a graphics card that meets the following requirements:
  • Supports a Windows Display Driver Model (WDDM) driver
  • Has a DirectX 9-class graphics processor unit (GPU) that supports Pixel Shader 2.0
  • Supports 32 bits per pixel
  • Passes the Windows Aero acceptance test in the Windows Driver Kit (WDK
If your computer is compatible follow directions below.
Option 1
loadTOCNode(3, 'summary'); To perform a clean installation of Windows Vista from the current version of Windows on the computer, follow these steps:
  1. Start the computer and make sure that the current version of Windows has started.
  2. Insert the Windows Vista DVD into the DVD drive and then close the drive tray. Wait a moment for the Setup program to start automatically.
  3. If the Setup program does not start automatically, follow these steps:
    1. Click Start and then click Run.
    2. Type Drive:\setup.exe and then click OK.
      Note Drive is the drive letter of the computer’s DVD drive.
  4. When the Setup program starts and the Install now screen appears, click Install now.
  5. When the Which type of installation do you want? screen appears, click Custom (advanced). The follow the instructions to install Windows Vista.
If Windows Vista is now running on your computer, you have completed the installation successfully.
OR
Option 2
Note for the option below The computer must be configured to start from the DVD drive.
To perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD, follow these steps:
  1. Start the computer.
  3. Restart the computer.
  4. When you receive the "Press any key to boot from CD" message, press a key.
  5. Follow the instructions to install Windows Vista.
Please rate this a fixya
May 18, 2009 | HP Pavilion Notebook
I have a Gateway M-6824 laptop running Vista Home Prem 32-bit. It has a Sony Optiarc DVD RW AD-6375A ATA Device which has stopped working. Unable to find any drivers for it. Help!!
Hi marjan425,
there is no need for a driver to be installed since this kind of hardware is supported by any version of Windows by default. Please shut down the laptop, remove the entire drive from the laptop (first have a look in your laptop's manual to find out how to do that!), then restart the laptop, wait for Windows to come up, log in to Windows and then insert the drive again. Now Windows should load the drivers for the drive and make it useable for you. In case it doesn't, the drive is defect most likely. In that case please contact your hardware vendor for a replacement.
Good luck and greetings from Germany,
noris017
Feb 25, 2009 | Lenovo IdeaPad Y510 Notebook
Computer won't wake after sleep mode
there is no other solution part from this..............all brand follos the same procedure to come out of the sleep mode do not worry.................................Sameeraryan
Jan 13, 2009 | Sony VAIO VGN-FW230J/B Notebook
Hp vs. toshin=ba window vista
Hi ,
click the link below -
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-47462-1&lc=en&cc=us&dlc=en&product=1141647&os=2093&lang=en
scroll dow - click download only - save it on desktop - run and restart the computer. While running maintain the same normal installation process.
Apr 09, 2008 | HP PhotoSmart C4180 All-in-One Color...
HP PhotoSmart 2575
hmmm..sounds like a new set of drivers might be just the thing.
get em here
Mar 05, 2008 | HP Photosmart 2575 All-In-One InkJet...
Scanjet 6300c
Check HP's website to see if there is a driver. Otherwise you may be out of luck.
Feb 15, 2008 | HP Scanjet 6300c Flatbed Scanner
Microsoft Windows Vista Ultimate Edition Logo
26 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
