Question about Vehicle Parts & Accessories
Model car alarm APS2K4SAW is not working
Hi
2 days ago I change batteries on my alarm remote control for my Nissan Altima, and now my remote control and my car not working.
My remote light is blinking when I push any buttons, and my security light in the car is still blinking.
How I can fix it?
Have a prestige APS2K4SAW remote and it just quit working, I need help please????
Posted on Jul 01, 2010
  • 15,935 Answers
Reprogram the remote using the following instructions.
http://www.audiovox.com/manuals/other/APS2K4_DOC_TPG.pdf
BTW... your remote is aps2k4saw the model of the alarm is on the brain under the dash.
Posted on Dec 25, 2008
How to check why my car alarm in 2006 nissan altima is not working
If it aftermarket(bunch of wires and modules under the dash on the drivers side) remove it. If it is still factory it takes a scanner.
Dec 03, 2015 | Nissan Cars & Trucks
My Nissan Quest 2000 does not start at all. The battery and the starter are fine. The problem has to do with resetting the alarm system. Can anybody help me with this problem?
you must do a search for the owners manual it will have the sequence in it for programming the remote control to reset the alarm you must disconnect the battery cables then reconnect the ground first then connect the + when the alarm sounds press a button on the remote control to shut it off if this works it should now disable the starter disable circuit and let the car start make sure the remote has a fresh battery in it LATER MAN!
Aug 22, 2014 | 2000 Nissan Quest
The viper alarm reset on my car how do I disarm it?
some you can push a button under the dash with the key in the on position and i had some disconnect the battery turn the key to the on position and hook the battery up
Aug 04, 2012 | 2005 Nissan Altima 2.5
2003 Nissan Altima car alarm won't stop going off. Went off every 30 minutes last night until I disconnected the car battery. Reconnected the battery this morning and still went off. Don't have a...
hand it over to a mechanic or Nissan. If you recently had an M.O.T and it went of quickly then ask for a refund, even better, ask him to take a look at the car again
Jul 02, 2011 | 2003 Nissan Altima
Nissan Altima 2000 Manual. Recently had remote starter installed and was working fine for a few days. This morning I remote started the vehicle and when I came out car was off. Try starting the car up...
the remote starter is not going to damage the starter, but if wired wrong it could damage the wiring or fuses, or run the battery down from a short.
Jun 11, 2017 | Nissan Altima Cars & Trucks
2005 Altima Nissan break light and battery light went on then car died 2 days later. Replaced the battery but lights did not go off. I think that @ two days ago I heard like a thump like a belt broke or...
Check alternator belt. Light is to show alternator working, not battery state.
If you have a volt meter check output is around 12.5 -14.5 volts when car running.
May 27, 2010 | 2005 Nissan Altima
2005 Nissan Altima trunks opens by itself
sounds like your remote. the trunk button is stuck on it can you pop the remote open and se if the button is stuck on the chip
Nov 20, 2008 | 2005 Nissan Altima
My car alarm is blinking but the remote doesn't work. I already replaced the battery to the remote so I know that's not the problem. If I open the car the alarm goes off and doesn't allow me to start the...
You need to first look under the drivers side dash area near the hood release/fuse panel area and see if there is a valet switch. The switch will look like a little toggle or a push switch. After you locate it, turn the ignition switch to the on position(dont start it) and flick the valet to the opposite position it is in now. If done correctly in most cases the red system light will stay a constant instead of off or blinking indicating you are in valet mode. Next try to start the engine. If this doesnt work you need to remove the alarm system and repair the ignition switch wiring or replace the electrical portion of the ignition switch. The aftermarket alarm cuts into the ignition switch wires and bypasses the start circuit through the alarm module. When disarmed the alarm completes the circuit and allows the car to start. Good luck hope this helps and please rate this.
Nov 05, 2008 | 1997 Nissan.5 Altima
1997 Nissan Altima problem
Check your battery fuse mine just also did that and it was the fuse under the hood. Location of fuse box is by the battery and it should be the big fuse close to the middle
Nov 03, 2008 | 1997 Nissan.5 Altima
Vehicle Parts & Accessories Logo
3,054 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
