Question about Dryers
Poorly heating clothes dryer
The dryer has four heat settings: very low, low, medium, and high. Seems like the dryer is always on very low or low and takes a long time to dry. Changing the heat settings does not seem to change the amount of heat in the dryer. Heating element heats to a red glow. There is a thermostat next to the heating element, another about 20 inches directly above it where the heated air enters the drum, and a third thermostat near the exhaust and exhaust fan.
Dryer and vent to outside have been thoroughly cleaned providing a forceful flow of exhaust air.
Can the integrity of the heating element and the three thermostats be checked with an ohm meter? If so, what would the appropriate readings be?
I understand that the heating element only puts out one fourth the amount of heat if the element is shorted to the case. How can one determine if this is the case?
If the exact cause cannot be determined, is there an priority order for troubleshooting the problem?
Bob
  • 3,463 Answers
Best way to test the elements and stats is to disconnect each one in turn, and with your meter set on the ohms range ,test each one in turn for continuity, you should get F.S.D.(full scale deflection) on each component.
Another way to test the element, is to bypas the stats, and connect the 240v suplly directly to the element, it should get red hot, but do not leave it on for more than a few seconds..
If it had gone down to earth, then theoretically it should trip the circuit breaker.
Plz rate my solution.
Thanks.
Posted on Dec 25, 2008
LG Dryer low heat doesn't work
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
May 04, 2014 | LG DLEX7177 Dryer
What is the best setting to use to dry clothes
Medium or low heat and put a few DRY,clean towels in there.
AUTO moisture sensors will do the rest.
The HIGH setting is not good for the dryer or your clothing.
Always put in a dry article to speed the process up.
Permanent press w/cool down is good.
If you use the HIGH setting,you better be **kid and waiting for the clothes to be dry!
Sorry.
Aug 26, 2013 | Dryers
Kennmore Elite HE4 no heat on low or extra-low setting
Assuming this is a gas dryer, it is likely the igniter has failed. The igniter plate has to heat up to glowing in order to heat up the thermocouple that turns on the gas valve.
Sep 03, 2012 | Kenmore Dryers
Hi, I have a Kenmore dryer (110.86873100) - the dryer has a 'fabric care knob with three settings - low, medium & high. The dryer does not heat on the 'high' setting at all, when I use the 'medium' or...
First off.. befor we talk about changing parts you need to verify that your circuit breakers are set properly. Manually push the dryer CB to the off position... and PUSH to off with conviction then turn it back on again. Test your high heat setting once again. If it works you had one of 2 CB's tripped. If it still shows the same symptoms then there are a couple of suspects.
1. The 155 deg thermostat
http://www.repairclinic.com/Appliance-Parts?s=t-L155-%3d%3d&txt=1
2. Possibly one of the two electrical legs of the heating element is open.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-110.86873100-%3d%3dc244i3367&PartID=3367
3. The timer & resistor has a problem.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-110.86873100-%3d%3dc212i2031&PartID=2031
All of the above can be isolated with a meter.
Thanks for using FixYa!
Kelly
Mar 19, 2010 | Kenmore 63942 Dryer
Whirlpool commercial gas dryer - heating problem
Check the voltage to the switch when turned to high and the power button pushed on. If you are not getting any power there then the setting switch is bad replace it at repairclinic.com
Feb 14, 2009 | Whirlpool CSP2761 Gas Commercial Dryer
Dryer Heats on High all the time
I don't think it is the heating elements. You have checked out all the important stuff. Is there power coming from the controls on medium and low. It sounds like this is the problem.
Jan 23, 2009 | Frigidaire FEQ332E Electric Dryer
Consequences of using high heat in dryer
the vavle in using high heat only comes in to play when you have a load of towels or some other heavy cotton,,thats what high heat is mainly for,,more moisture,,,on the norm medium with a regular load is the way ..now go to the dryer and look at the back vent where the heat comes out does it look like burnt and dark as if you burnt shirt and it stuck to the iron,,that comes from high heat scortching,,rubber in elastic in your sock and other clothing...onthejob slow low and steady
Dec 27, 2008 | Whirlpool GGQ8831L Gas Dryer
The clothes dried on high or medium heat come out smelling like heated metal
hi .thanks for the question .yes i would check all venting from dryer to the outside . clogged venting, or dryer too close to the wall could cause this problem . thanks the appliance doc
Sep 30, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
154 people viewed this question
Top Dryers Experts
Marvin
Marvin
