Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Yellow Scanning--Trying to scan a color picture
I keep trying to scan a color picture using the webscan function, but at random times the preview and the scan will
(a) have a bright yellow bar in the middle
or
(b) be ALL bright yellow.
It's not really clear why--it just does it whenever it feels like doing it, apparently.
    Scholar:
  • 100 Answers
First thing is to make sure the glass and the white backing on the lid is VERY clean.
then go to this link to trouble shoot --
http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&product=2512008&lang=en&
Posted on Dec 25, 2008
I saw the error "an error occurred during preview. if the scanner is being used. please wait for it to complete the task.and then click preview" when iam attempting to preview the scanned pictur how c
If you continue to get this kind of error after restarting the computer, you may need to update the scanner's device drivers or reinstall the included software. You should also make sure only one program or application is attempting to use the scanner by closing all but the one program you are trying use with the scanner. One last note - always either let the program you are scanning to operate the scanner or let the scanner invoke its default application by pressing the scan, fax or copy buttons on the scanner. Do not for instance try and scan an image into a running program that initiates the scanning process itself while also invoking a scan from the scanner's control panel. The two operations will conflict.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 19, 2014 | Office Equipment & Supplies
When I scan transparencies, 1) The transparency to be scanned doesn't seem to lock itself into the MA-21 slide mount adapter the way it used to. I looked inside the adapter and everything seemed to be
I have four Nikons we use for commercial scanning. As you've seen the MA21 is a simple device that can hardly fail. There are two prongs that hold the slide down against the metal slider that after scanning ejects the slide. If you pull the MA21 out and put a slide in you can see if there is any undue play. Even if the prongs have worked loose an upright unit should function fairly well. I would suggest the cause of your issue is elsewhere and we've had this from time to time. I would change the USB port the scanner is connected to, maybe swap the cable too, reset / restart the scanner and (from my experience) the problem at some point will go away.
Mar 11, 2014 | Nikon CoolScan V ED Film Scanner
Scan access denied
If you are viewing your HP printer from your desktop, you probably got this message under Scan > Scan to computer > webscan.
So, to solve the problem, go to Settings > Security > Administrator Settings, and enable (checkmark) the box next to Webscan, and click Apply. If it saves successfully you will now be able to use Webscan.
Mar 31, 2012 | Office Equipment & Supplies
When scanning a color picture it comes through in black and white what am i doing wrong?
Change the Options on your HP Scanning Software to Scan in Colour or Else:
In this case u have to scan and Preview the scanned images using Windows Photo Gallery.....
Click on File and Click on Import from scanner or Camera...........
Then again click on Import...........It will scan and preview the Applications to u....
Thanku.......
Good Luck!@@!
Sep 23, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
I need a step by step guide to scanning a doc that i want to print please
  • hi follow the instructions
  • 1
    Clean the photo you want to scan. If you have canned air handy, blow dust and lint off the surface of the picture (not recommended for fragile photographs).
  • 2
    Fire up your computer and Multi-function printer. Check your connections and look the printer over, cleaning the scanning surface and the underside of the document lid.
  • 3
    Position the photograph face-down on the scanning surface. The alignment of your photo can be corrected in the editing process, but you can save yourself a step if you do this by hand, using the guides on the edges of the scanning area.
  • 4
    Shut the lid. Be careful to not disturb the picture's alignment when closing the lid.
  • 5
    Set the scan resolution. Increasing the dpi (dots per inch) count produces a clearer and sharper image and dramatically increases the file size.
  • 6
    Click the scan button on the software interface or push the button on the face of the printer. A preview of your scan should appear on your computer monitor.
  • 7
    Inspect the preview for any correctible flaws. If you need to start the scan over to fix something that went wrong, remember to label each scan of the same picture with a different name so you can sort through them quickly.
  • 8
    Choose the best version and save it to your computer's hard drive
  • Read more: How to Scan a Picture on a Multi-Function Printer ' ehow.com http://www.ehow.com/how_2006156_scan-picture-printer.html#ixzz1CA1jrDhB please dont forget to appreciate me
    Jan 26, 2011 | HP DeskJet F4280 All In One Printer InkJet
    How do you scan a picture?
    simply installoffice 2003 and there will be microsoft office tools select microsoft office document scanning select scan new document.....first of all u have to install printer drivers my dear friend
    Mar 11, 2010 | HP PSC 1210 All-In-One InkJet Printer
    Preview results in random croppings, rotations, and added pics
    Hi I'm having a similar problem and haven't managed to fix it. Have you solved it? Thanks Martin
    Mar 07, 2010 | Epson Perfection 4990 Flatbed Scanner
    Hp scanjet 8250. I want to set my scanner to default to PDF when I am trying to email. That is the way we do most of our scanning and right now it defaults to RTF.
    Have you considered simply scanning from within Adobe Acrobat or similar software that produces .pdf and then use the email feature within Acrobat?
    As I look over the HP User Manual, I can't see any method to set the default output. It simply says...
    Use the E-MAIL button() to scan documents or pictures and insert them in an e-mail message as an attachment. You must have an Internet connection and a supported e-mail application.
    1. Place the original face down on the scanner glass or face up in the ADF. If you are scanning two-sided originals from an ADF, slide the DUPLEX switch to two-sided mode.
    2.Press the E-MAIL button().A message appears asking if the original is a document or a picture.
    3.Select Document or Picture, and click OK.Note:A preview image will not appear when scanning from the ADF. To change this preview setting, see the HP Photo & Imaging software Help.
    4. Select the final scan area (the area inside the dotted lines) in the preview image.
    5. Make adjustments to the preview image if needed.
    6. Click Accept.The final scan area is scanned and your e-mail application is opened. The scanned image is added as an attachment to the e-mail message.
    7. The Save As dialog box appears. Type a file name and choose a file type, and click OK.
    8. Complete the e-mail as usual.
    Aug 07, 2009 | HP Office Equipment & Supplies
    Scanning problem with A940 AIO Dell printer/scanner
      Hi there, just found this solution to work perfectly. i just freaked out for a moment with the same problem. Use this or just type fax and scan in your help function. Hope this helps!
      Before you begin, make sure that you've installed your scanner on the computer and that the scanner is turned on.
    1. Windows Photo Gallery.
    2. Click File, and then click Import from Camera or Scanner.
    3. In the Import Pictures and Videos window, click the scanner that you want to use, and then click Import.
    4. In the New Scan dialog box, click the Profile list, and then click Photo. The default settings for scanning a picture are automatically displayed.
    5. If you're using a scanner with a document feeder, click the Paper size list, and then click the size of the picture that you've placed on the scanner or click the size that most closely matches the picture.
    6. Click the Color format list, and then click the color format that you want the scanned file to display.
    7. Click the File type list, and then click the file type that you want to use to save the scanned file.
    8. Click the Resolution (DPI) list, and then click the resolution, in dots per inch, that you want to use.
    9. Adjust the brightness and contrast settings or type the values that you want to use.
    10. To see how the picture will appear when it is scanned, click Preview. If needed, modify the scan settings, and then preview the picture again. Repeat these steps until you're satisfied with the preview results. Some scanners might require you to place the picture in the document feeder each time that you scan.
    11. Click Scan. When the scan is complete, Windows Photo Gallery prompts you to tag the picture so that it's easier to organize or find later.
    12. In the Tag these pictures (optional) list, type a tag name, and then click Import. Windows Photo Gallery displays the picture so you can view, fix, or organize it.
    Feb 01, 2008 | Dell A940 All-In-One InkJet Printer
    HP Officejet Pro L7580 All-In-One InkJet Printer Logo
    143 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
