NetGear WGR614 54Mbps Wireless Router (obwgr614_1) Logo
john hughes Posted on Apr 14, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No internet connection through the router
Hi ya I am trying to rectify a problem on my netgear wgr614 router. The power on status light comes on and the test light is on. Do i take it that when the router is omitting a signal that the wireless status light should be on. If so then my router does not display a wireless status light being on. I have a us robotics pcmcia card that i have tried to use with the dedicated software but this did not work. I also tried using Wireless zero configuration in windows xp but this did not work either. I have tried using a hardwire connection using a network cable between the network port on a laptop and the lan port on the router. I went into internet explorer browser and entered "www.routerlogin.net" this gave me the internet connection tab netgear router page. However, when i entered "http://192.168.1.1/basicsettings.htm" i got nothing. 192.168.1.1 was the default gateway address in the command prompt. Please note i am only testing the connection between the router and the laptop without being on the internet as i should be able to verify if the router and the laptop are communicating. Could anyone help me thank U
wayne walker
Level 3:
  • Master 779 Answers
  • Posted on Apr 14, 2007
wayne walker
Master
Level 3:
Answers
779
Questions
Helped
328987
Points
2177
The test light should go out - on power up it runs the self test - light on and then goes out when completed OK Page 2-6 of PDF manual from the netgear website for V6 of that router. "The power on status light comes on and the test light is on" i think "test light stays on" thats your problem
Anonymous
Level 1:
  • Contributor 854 Answers
  • Posted on Apr 11, 2009
Anonymous
Contributor
Level 1:
Answers
854
Questions
0
Helped
308726
Points
62
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Network Key for netgear wgr614
Hi, taffy_man, the network key is something you configure yourself. If you dont know it you have to RESET the router to the factory defaults.
Take a paper clip, or something sharp, and insert it into the little reset hole in the back of the router, and hold for 15 seconds or so, that'll reset the router. Wait for all the lights to stop flashing and remain on, then try to connect to the internet.
Or you could type www.routerlogin.com into your internet address bar and it'll ask you for the username and password, the defaults are admin and password..
If that doesnt work do the same thing but first disconnect the power cable. Then while pressing the reset button THEN connect the power cable again but keep the reset button for 10 secons and then go to the routerlogin.com or (192.168.1.1) and do what I wrote above. Then you will have to reconfigure your settings. I hope this helps.
1helpful
Trying to set up a netgear access point with a moterola surfboard
Try doing a hard reset on the Netgear router then powercycle it together with the modem
Printer dosnt connect thru netgear router
Well if there is no light on port 3 it means,its not connected physically to printer(or could be that port 3 is faulty can try other port number to rectifie that )
Please check and let me know for further support
Happy to help
Thanks for using Fixya
2answers
How to connect Netgear to Time Warner internet modem? I have Netgear installed on my computer, and I have the internet modem plugged in to my computer.
Just disconnect the ethernet cable from the computer and put it into the slot called internet on the router then run ehernet cable from port 1 to computer.
2answers
Can you tell me if all of the four numbers should be lit up to reflect the Netgear WGR614 is working? My internet connection suddenly quit and I just noticed that on the number "1" is lit.
On a router, the numbers light up only if there is an active computer plugged in to that port. One computer plugged into port 1 the number 1 wil light, and same with 2, 3, 4. No device plugged in to port = no light. Different color lights with different data rates.
Netgear WGR614 internet light not coming on
Hi there.
Reset the wireless router by removing the power cord from the back of it for 30-60 seconds, then plug the power back in wait for 2 mins then try to reconnect again.
If you get no joy please post back for aditional advice.
Good luck and thanks for using FixYa!!
Netgear WGR614 v6 router drops connection
Hi, what ISP are you using (aol,tiscali...?), and how are you connecting to the router? Wired or wireless? I had similar problems with mine, it wouldn't connect or would drop connection, or loose all the settings. I updated the firmware to the latest from here:-
http://kbserver.netgear.com/products/WGR614v6.asp
Be sure this is the correct model as firmware differes from model to model.
Then I had to manually configure my ISP settings etc. Or you may have software from your ISP which configures for you.
Hope this helps.
Can't access configuration for Wgr614 v5 Netgear Wireless router
Since you cannot ping the router, first thing to do here is to reset the router by pressing the reset button of the router for 30 seconds while power is On and then after the reset power off the router for 5 seconds and then when the router is already power On try to ping the IP of the router using a computer that is wired to it if still cannot be ping better contact Netgear support if the router is still underw arranty and have it replace...
Light Status on Netgear WGR614
Access router. What does it say? did you set up the wireless network yourself? Is the cable modem working properly? Rebooted it? Is there a problem with the internet provider?
1helpful
2answers
Connected to internet but cannot browse.
hi there ;
there is no such solution for ur problem ..... the only solution is to firstly reset the router for 30 seconds and then upgrade the firmware of the router ..... remove the powercord for 10 seconds ...
> Again redo the settings then ....
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
