Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Water to water dispenser but no ice. Changed out filter,pump
I have a Whirlpool ED2LHAXMQ10 and I have changed out the water filter and installed a new pump. I have turned up the temp. inside the freezer. What do I do now???
  • 700 Answers
First off you are going to have to turn down the freezer . Also oyu need to remove the air thats in the line. Then wait for the box to cool down and make ice. Thanks for using FixYa!
Posted on Dec 25, 2008
When I changed my filter in my Whirlpool refrigerator, my refrigerator stopped making ice and dispensing water. How do I get it to start back making ice and dispensing water.
If you still have the old filter replace the new with the previous. If all works OK check new filter for blockage or manufacturing defect. Usually most units will work with no filter installed.
It is likely that you have not fully assembled the new filter in the location.
The filter can be removed and there should be no leak and the ice maker and water dispenser should work just like before except the water is not filtered. This feature is available for customers who have whole house filters.
Hope this helps?
Nov 22, 2016 | Whirlpool Refrigerators
Whirlpool double door refrigerator model# ED5KVEXVB04 water dispenser is not working to my knowlegde my ice maker is fine I've changed the water filter and still nothing but when i remove the water fi
Replace the water filter. These things get clogged with the debris they're intended to filter. I'd be surprised if ice is being made if the filter is that clogged. Change the filter at least annually.
Oct 14, 2014 | Whirlpool Refrigerators
Hotpoint ice/water dispenser will dispense ice but not water
You may have a blocked filter. Has this even been changed since you have hook-up the water line, or did you recently just install a new filter. If so it may not be in right correctly. try removing it and reinstalling it.
Mar 13, 2010 | Hotpoint HSS25GFP Side by Side...
Water dispenser has stopped dispensing water. I have a whirlpool 25.4 cu ft. Side by Side Refrigerator
there are a few things to check real quick
does your ice still work
does your ice make still work
when was the last time you changed the filter
when you do call for water can you hear the water solonoid
Nov 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have an old Kenmore 26 side by side that dispenses water and ice. At one point it stopped producing ice and dispensing water. I changed the inline filter and it worked perfectly. Happened again shortly...
It sounds like you need to replace your water inlet valve , it is a dual valve for ice and water in the door and they go out often , the solenoid is not opening anymore , it is located where you hook up the water line.
Let me know if you have any other questions.
Phil
Apr 10, 2009 | Whirlpool GD2SHGX Refrigerator
Freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Mar 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool water dispenser ...metalic taste
Hi!!! you seem to have a bad water valve in your refrigerator.change your water filter and the water valve on the back on the frig..
Jan 03, 2009 | Whirlpool GD2SHGX Refrigerator
Water dripping from water dispenser
You may have something in the solenoid valve seat that is keeping it from closing fully - could have happened at the filter change.
Jul 19, 2008 | Whirlpool GS6NBEXR Side by Side...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
48 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
