Question about Pioneer AVH-P6500DVD Car DVD Player
Portable Car dvd player
I would like to know either a portable dvd player can be used at home?And what power does the car dvd player use?Does it use the batteries for its power supply or it uses the car battery?Can a power supply be contructed for it to be used at home if it cannot be used at home?
  • Chaippah Mlozi
    Chaippah Mlozi Sep 11, 2015
    it can be used at home as long as you have a 12 Volts Dc supply
  • 944 Answers
Here is the link to the owner's manual and the installation manual for your player; http://www.pioneerelectronics.com/pna/v3/pg/support/details/0,,2076_310070347_38318,00.html You have to register to access the info, but it is free. The player runs from the car battery power source, so it can be run from a transformer in your home - available from any good hardware store. The player itself specifies a power source of 14.4 voltsDC preferred, 10.8 - 15.1vDC is allowable. maximum current drawn is 10Amps. If you take these specifications to a hardware store they will be able point you in the right direction. a car battery charger could do the job, but i would recommend putting it through a battery not directly to the player as this will possibly damage it. make sure you put a fuse in the system near the player i would recommend a 5A fuse, if that blows too much then try a 6 or 8 A fuse - dont go over 10 amps and make sure it is a quick blowing type. If you have a charging car battery in your home, be very careful to ensure there is proper ventilation - when charging, the battery gives off hydrogen gas which disperses without problem from a car engine bay, but can build up to explosive concentrations in a building without adequate airflow. Some batteries have a small connector for a breather tube, which can be led outside through a window or a hole drilled in the wall. other batteries need to be boxed, and a breather tube put on the box. If you are careful about the hydrogen gas then this can be quite safe - make sure you keep the battery well maintained - follow the safety instructions about dealing with acid, insulate the battery terminals properly to avoid shock, sparks or power surges. Box the battery in a vented box - make the lining acid resistant (polyester or epoxy resin for instance) if possible. Simpler may be to charge the battery elsewhere and connect it alone to the player - you will have to move the battery around a lot which is inherently a bad idea in many ways. still make sure it is fused regardless. Easiest would be a proper mains transformer/rectifier as described. there is no other reason why you would not be able to use this player at home. Hope this helps, please ask again if you need more info :)
Posted on Apr 14, 2007
SOURCE:
Need new car charger for the LMD model for my true tech portable DVD player
What about a small, light power inverter, that plugs into your cigarette lighter in your car, and has 100 Watts available?
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3970959&CatId=237
(Your laptop won't EVEN use 100 Watts! Look at the Ac adapter. (Charger)
Read the specifications on it.)
Aug 07, 2009 | TruTech PVS12701 Portable DVD Player
Useing in the car
It doesn't have a car adapter but you can purchase power inverter for the car so that you can hookup any electronics just like at your home. The power inverter converts your car power into multiple outlets.
Feb 09, 2009 | LG DP781 Portable DVD Player
Car Charger and home charger
my car dvd melted around the edge while it was plugged to recharge in car bmathis7643@bellsouth.net
Feb 04, 2008 | Venturer PVS177W Portable DVD Player
Need accessories for portable dvd player...
I was tol Funi makes the Durabrand for WalMart, Try this addy http://www.funai-corp.com/support/contact.asp Good Luck
Mar 19, 2007 | Durabrand PVS1966 Portable DVD Player
Pioneer AVH-P6500DVD Car DVD Player Logo
219 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
