Question about Plumbing
My kitchen faucet pulses
Only when the water is turned on. it seems to only be in the kitchen.
  • Chris Ballard
    Chris Ballard May 11, 2010
    What brand faucet? Single or double handle? Does it do it on both hot and cold?
    The most common cause is a loose washer in a double handle valve. Some washerless models develop defects in the cartridge that can cause the same effect.
  • Linda Gahlbeck Jul 26, 2013
    I have a Moen, single handle faucet that does the same thing with hot and cold.
    Novelist:
  • 148 Answers
This could be something as simple as debris n your aerator
To see if this is the problem remove the silver collar(nut) at the end of your faucet spout by turning counterclockwis (plug the drain holes so nothing oges down the drain) If it is hard to turn put a soft cloth around it and grip with chanel lock pliars or vice grip be areful not to clamp too hard
once you remove the aerator you will see a plastic type of gear and a screen carefully remove thes and rinse with water (look for grains of sand or any obstructions)
before you re install the aerator turn the water on full blast and alternate from cold to hot then together
if this does not work you will need to se if the problem is in the mixing valve which requires removing the cartridge to remove the cartridge:
turn water off under sink(hot and cold)
look for an erasure side cap or cover located at the base of the fauet handle and remove with a sharp screwdriver
take a hex rench (you may need a fashlight) and remove the hex screw then take the handle off
take a channellok wrench and turn the cap nut (large washer type of nut) this will allow you to remove the cartridge
Remove the cartridge and inspet for debris
go under sink and trn water on slowly to flush any debris then turn water off
reinstall cartridge( it is usually keyed )
be sure to snug the nut down but not extremely tight
Reinstall handle and check faucet before you put the set screw in .
This should stop the pulsating if not replae the cartridge
GOOD LUCK!
Before you reinstall the
Posted on Jan 01, 2009
Wateridge Olivia. Where can I get a manual?
Customer Reviews: Water Ridge Pull Out Kitchen Faucet
www.amazon.com/Water-Ridge.../B00O2AGROM
Amazon.com, Inc.The older Water Ridge faucet had a 6 page manual; it seems the company .... me a new Olivia Pullout Kitchen Faucet by WaterRidge' Dual Function Spray Head ...
REVIEW: Costco WR Water Ridge Pull Out Faucet Brushed ...
? 3:21
https://www.youtube.com/watch?v=wsreMTL_whc
Apr 19, 2013 - Uploaded by HillBrosReviews
REVIEW: Costco WR Water Ridge Pull Out Faucet Brushed Nickel .... gave me a new Olivia Pullout Kitchen Faucet byWaterRidge' Dual Function Spray ... They sent a hose... with nodirections how to replace the defective one.
Dec 18, 2015 | Plumbing
When i turn my kitchen faucet on the water is very
It is air in the line just run the sink one as it is off the main . if this does not work water company can do it from outside at a hydrant
Jan 05, 2018 | Delta Commercial 400-WFELHHDF HDF Series...
My kitchen faucet is loss from the bottom and it seems it can not be tightened. The water facet water valves seem to be in the way.
Tightening the nut on a faucet is tough to do in the tight space you have to work with. The proper tool to use is called a 'basin wrench' and is not too expensive. It has a swivel head to let you get it up to the nut and turn it from below. Here's a picture:
http://www.amazon.com/Ace-881041A-WRENCH-BASIN-11/dp/B000H5YESW
Apr 11, 2010 | Grohe Classic Kitchen/Bar Faucet ...
Delta Signature 470 kitchen faucet leaks when using cold water
well it do or it don't come out if it is old U R better off buying a new, it is the seals that R leaking, then it could B a weld gone bad
Mar 24, 2009 | Delta Model 470: Signature Kitchen...
Portable dishwasher won't stay connected to the kitchen faucet
it the faucet connector has a lever u push in order to latch on to the faucet, just jam something under it so it maintains upward pressure and wont come unlatched when the water starts flowing
Jan 30, 2009 | Maytag MDB9600A Jetclean II Built-in...
Valve in Delta faucet closes as water warms up
Yes, you are on the right track, but Deltas use a fancier kit inside them. It is quite a bit pricier than an O ring, but will solve the problem. It is not hard to install at all.
Jan 10, 2009 | Delta Faucet Delta 156-WF Victorian Single...
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Plumbing Logo
4,581 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
