Question about SanDisk Sansa MP3 Player
Express voice recorder
I could not get my sansa mp3 to start voice recording then it started now the unit has shut down and will not start up.
  • 728 Answers
First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work.
If it does not work, you may need to get a firmware update from this web site: http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Remember that you need to back up all of your information before doing the update.
Posted on Jan 17, 2009
How do i play back a recording i've made? I have the Sansa m200 series MP3 Player
To play back a voice recording, you will need to do the following steps after turning on the player. Press Power/Menu briefly to get the software menu. Press the Repeat/A-B/Down button to highlight the line Play Music and press Select to enter the play back sub-menu. Press the Down button again to go to the line Recordings and press Select again. Use the Down button to highlight a particular voice recording and press Select to start playing the recording.
The manual for the Sansa M200 MP3 player is available as a PDF from the manufacturer here: http://kb.sandisk.com/app/answers/detail/a_id/241 . The details for playing back a Voice Recording are on page 23-24 (24-25 of the PDF). You will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Mar 25, 2014 | SanDisk Sansa m240 MP3 Player
How do i use the micophone
To start voice recording, follow these steps:
1. Press the Menu button to return to Main Menu.
2. Select Voice
3. Press Play/Pause to start recording.
4. To pause recording, press Play/Pause again
5. To stop recording, press Select. A pop-up window will appear on the screen. Select Yes to
save recording. The recording will be saved in the RECORD/VOICE folder.
6. Press 'button to return to the Voice Menu.
Jun 20, 2011 | SanDisk Sansa Clip MP3 Player
I have the mp3 and just wondering how long you can record voice on it.. ?
2. Select Voice
6. Press '<< button to return to the Voice Menu.
Please leace feedback
Cheers
Andy
Jun 04, 2011 | SanDisk Sansa Clip MP3 Player
How do i delete recordings on a sanDisk Sansa m240 MP3 player.
Manual for the m200 series, see:
http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf
All about voice recordings in chapter 4, starting from page 22 of the manual.
On page 25 is the information how to delete recordings on the m240.
Nov 21, 2009 | SanDisk Sansa m240 MP3 Player
Why my sansa c250 does not record the voice in mp3, only in wma?
Unfortunately, Sandisk didn't include any options in their firmware to record in any other format.
If you happen to have a version 1 c250 then you can install Rockbox on it and have 4 recording format options, as well as being able to choose what bitrate to record in for the mp3 format.
To find out if your player is a v1 go to Settings -> System Info
If the version starts with 01 then it's a v1 player and you can install Rockbox on it. If it starts with 03 then it's a v2 player and you're stuck with the wav format, as Rockbox is not yet available for v2 c250 players.
Jan 13, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
I have a sandisk sansa m240 mp3 player i found but the screen is busted. I figured out how to do everything without the need of seeing what was on the screen, except how to record stuff.
This will probably be impossible without a screen, but here are the steps:
The Sansa Fuze has a built-in microphone allowing you to record your own voice, an
interview, or a speech.
1. Press the Home button to return to Main Menu.
2. Select Voice from the Main Menu.
3. Select Record Now.
4. To pause the recording, select Pause.
5. To stop the recording, select Stop.
6. Select Yes to save the recording.
7. Press the |<< button to return to the previous menu.
Dec 03, 2008 | SanDisk Sansa m240 MP3 Player
Sandisk Sansa M240 Screen Busted
Hard w/o screen, here are the steps:
Can I use voice record in combination with the timer shut down function?
refer to www.machspeed.com/052manual.zip
depending on the quality you set the player can record for two or more hours..No there is no timer
May 08, 2008 | Mach Speed TRIO Onyx MP3 Player
Sandisk sansa c240 mp3 player voice recording problems
Try the latest firmware upgrade from the Sansa website
Aug 03, 2007 | SanDisk Sansa c240 MP3 Player
SanDisk Sansa MP3 Player Logo
141 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
