Question about Frigidaire GLTF1670A Front Load Washer
Pump keeps running dose not go to spin cycle
What part do I have change
  • Official Brand Answer
  • 4,342 Answers
Check your door latch and the control panel for any error codes that might display. If you do not see any error codes, check your drainage lines for debris or blockages. If that is clear, contact a professional to have the control board and timer diagnosed for possible repairs.
Posted on Sep 12, 2012
SOURCE:
Crosley washer motor runs in spin cycle but drum dose not spin
Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the timer and control board not communicating correctly.
Sep 11, 2012 | Refrigerators
WHY DOES MY WATER PUMP, ON MY BOSCH NEXXT 100 SERIES, RUN LITERALLY ALL THE TIME DURING SPIN. THE PUMP REMOVES WATER AS IT SHOULD, BUT JUST KEEPS CAVITATING AS IT KEEPS RUNNING. I CAN TELL IT KEEPS...
Welcome to FixYa.
Completely normal. The pump will indeed run through the entirety of the spin cycle, it is by design.
As the items spin, more and more water is extracted and if the pump should fail to operate during this time it would cause increased vibration and inadequate extraction to achieve it's superior spin cycles.
Hope that helps quell your concern. Let me know if I can assist you further.
Thanks for choosing FixYa. Please take a moment to rate the info provided here today.
Regards,
Macmarkus :)
Sep 11, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
My washer spins but doesnt spin on the final spin and leaves the clothes all soaked. it stops at 6 minutes on the final spin
is the machine draining correctly?
the machine will oftin stop if not doing so.
you can try cleaning out the coin trap/drain pump hose.
Jan 12, 2010 | Frigidaire Affinity ATF7000E Front Load...
I have the Balboa 500Z pump heater kit. Its hooked direct to a mighty iron ( 120v) recirclulating pump. Ever since it was new, I keep getting lack of water vflow errors ( dr, then dy ) I have plenty of...
I have a 6 month old Balboa 500Z. I have noticed that the filter system tis running all the time 24/7. I have reset the filter cycle to run for 2 hours { F2 }. It still is running all the time. It dose not seem to make a difference what I set the cycle for it just keeps running
Dec 06, 2009 | Balboa Instruments Duplex Digital Panel 2...
My washer wont drain but will spin in the spin cycle
That means that the water pump or the pump it self is going to go in it my washer did the same
thing we had to get a new pump or compressor. Dose it make a squeeky sound or a funny sound?
Mar 26, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will not drain after wash cycle or the spin cycle
check to see if your pump is slightly plugged with a sock or ?
Your top loader should pump out in about a minute and a half when totally full of water.
Aug 11, 2008 | Whirlpool GSC9455 Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
DOES NOT DRAIN WATER
If motor runs or sounds like it is trying to run, you have a sock caught in the pump. If no noise at all you have a bad lid switch
Jun 07, 2007 | Kenmore 94812 Top Load Stacked Washer /...
Frigidaire GLTF1670A Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
