Question about 3M Boating
FOLDING PORTA-BOAT My 12 foot polypropylene boat leaks at the bottom seal. It is at the bottom of the transom and center of the boat. This is where the boat folds. What is the best 3m product for this fix? Is scotch weld dp8010 better than 3m 5200? THANKS FOR ANY INFO
  • 159 Answers
SOURCE: Water Leakage Under Front Load Washer
most likley cause of your problem is the grey bellows has a tear in it. Inspect the bellows to check for tears. Or you can remove the lower panel and run the washer and look for the leak that way. Im sure it is a tear in the belows. Not a diffacult part to replace if you are mechanicly inclined. Good luck.
Posted on Jul 12, 2007
zeusfaber
  • 247 Answers
SOURCE: rubber door seal mouldy
Wouldn't normallyexpect a few mould spots to leave that bad a smell, so likely you've got two distinct issues.
Starting with the water trapped in the seal: Open the door and very carefully slip your fingers into the seal where the water is gathering (to stop your hand getting trapped between the drum and the outer casing, put your other hand inside the drum and push it up out of the way - just be careful not to let it spring back too fast).
At the very lowest point,of the space inside the seal, either at the very front or the very back (so tucked into the corner between the floor of the seal and it's front or back wall), you'll find a little drainage slot. Once you've cleared the inevitable blockage from this slot, your seal problems should vanish.
If the foul smell is coming from inside the machine, the problem is likely to be grey sludge inside the works of the machine. This is usually caused by modern detergents not being quite as good at working at 30 degrees as they claim to be. The answer is to run a cycle every now and then with no laundry, detergent, or conditioner in the machine, on the longest, hottest programme the machine will support. This should be sufficient to dissolve the rotting sludge and pump it away down the drain.
A.
Posted on Apr 06, 2008
  • 1779 Answers
SOURCE: Jeep is leaking into cab
Hey, I found your part, 'cowl seal weatherstrip' on the JC Whitney parts site, $42 plus shipping, check it out, good luck with the Jeep! Please rate this, thanks!
Posted on Apr 14, 2009
praky16
  • 744 Answers
SOURCE: Leaking from bottom of front door
hi..
Try checking the rubber boot from the door opening to the drum for signs of hole or cracking..
thank u
rate me!!!
Posted on Aug 19, 2009
SOURCE: Cant lock the end rails
Before you lock the bottom of the playard, you need to pull all the way up on the two side rails, they will form a slight arch, and the button will click into place. Then push down on the bottom rails.
Posted on Jun 17, 2011
Outboard johnson modele # J15R4SR serial number S 23030015 do he fit on princecraft springbok 2013 because the transom height is 20 inch.
Set the motor on the transom and make sure the cavitation plate is below the bottom of the boat.
Jun 02, 2017 | Johnson Boating
I thought I had oil leak from prop shaft but upon inspection shaft seals were not leaking but had bit of oil on bottom of casing is there another seal 20hp mercy
Three more seals. One on the shift shaft, another under the water pump and one more at the bottom of the engine on the main drive shaft. There is also a large o - ring on the carrier. Chances are the shift shaft seal is leaking.
Feb 05, 2017 | Light Outboard Motor Boat Bass Fishing...
Sears 1965 14ft v bottom instructions book boat
3 people and 10 hp motor unless 1 person is really large ,there should be a tag on the inside of transom telling you this info.
May 21, 2014 | Boating
Bilge pump on 1996 nitro bass boat inop
Check to make sure the fuse is good and you have power going to the switch and then to the wires (brown for positive and black for negative) in the bilge area using a 12 volt tester. If you have power to the brown wire while grounded to the black wire then the pump will need to be cleaned, have the impeller replaced or replace the pump. The pump is located in the rear compartment attached to a board mounted to the inside bottom of the boat at the center near the transom.
Feb 12, 2013 | Nitro Boating
Wheres my bilge pump
It's located in the rear compartment centered on the bottom of the boat in front of the transom.
Jun 22, 2012 | Nitro Collectable Fishing Boat...
Yamaha outboard 8 horse power tilt removel trouble
Trouble removing it from the transom? Is it C clamped into the transom? Or a bracket built of the transom?
Nov 07, 2011 | Light Outboard Motor Boat Bass Fishing...
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
https://www.minnkotamotors.com/
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
Repar water pump on 1996 35hp johnson
VERY EASY REPLACEMENT
REMOVE PHILIPS HEAD SCREWS THAT HOLDS THE PLASTIC WATER STRAINERS ON THE FOOTOF THE MOTOR,
NEXT LOOSEN THE HEX FITTINGS 7/16 OR 1/2 WRENCH SIZE THAT WERE COVERED BY THE STRAINERS
NEXT REMOVE THE 2 STAINLESS STEEL BOLTS THAT ATTACH THE FOOT TO THE LOWER UNIT.. BOLTS COME OUT FROM THE BOTTOM,, NEXT LOOSEN THE NUT ON THE FRONT OF THE FOOT FACING THE TRANSOM LEAVE A FEW THREADS TO HOLD THE FOOT SO IT DOSEN'T FALL. NEXT WIGGLE AND SHAKE THE FOOT
TO LOOSEN IT FROM THE LOWER UNIT . NEXT STEP REMOVE THE NUT WHILE HOLDING UP ON THE FOOT THEN SLOWLY REMOVE FOOT ASSEMBLY WITH DRIVE SHAFT.
NEXT REMOVE THE O RING FROM THE FITTING THEN REMOVE THE FITTING FROM THE SHIFT ROD THERE SHOULD BE A BIGGER O'RING ON THE SHIFT ROD NEXT TO THE WATER PUMP HOUSING . REMOVE BOLTS HOLDING WATER PUMP HOUSING ON THE FOOT ASSEMBLY LIFT OFF HOUSING LOOK FOR IMPELLER KEY TO FALL OUT . I RECOMMEND REPLACING IMPELLER AND HOUSING AS A KIT . INSTALL IN REVERSE ORDER .
IT'S A PIECE OF CAKE ...
Aug 06, 2010 | Boating
Need to change steering unit 1987 Bayliner cuddy
I have a 1988 Bayliner with Power Steering. If you are asking about removing the steering parts on the transom, they are just like a Rack and Pinion.
You want to turn the steering to shorten the rod and drive it back into the case. Then you will unbolt the case from the transom and the motor.
The hydraulic hoses are another challenge. You want to remove as much fluid from the steering pump as possible. Leave the fluid coolers alone and just uncouple the hoses at the steering case on the transom.
You want to BE PREPARED to cap the ends of the hoses and raise them as high upwards as you can keep them.
The steering case will then drop fluid. In an ideal situation you would have plugs to close the holes the hoses are removed from. A bucket to catch the fluid and plenty of rags to keep the fluid out of the bilge is about all you can do. You may get lucky and be able to wrap plastic wrap around the steering case to seal off the leaks.
You reinstall and then bleed the air out of the system by steering lock to lock a few times.
Mar 29, 2010 | Light Outboard Motor Boat Bass Fishing...
Bravo one water on tiller arm
Assuming "tiller arm" is the steering arm (connects to steering actuator and disappears into transom plate, lay on top of engine - not running - and have a friend turn steering wheel, black arm that is coming out of transom and moving is steering arm), problem is most likely the seal on the vertical steering shaft. This shaft connects the steering arm to the gimble ring. Problem can be confirmed by visually checking for water coming from just below the steering arm with boat in water, or residue starting in same area with boat out of water. If this is confirmed to be the problem, repair is quite extensive. Entire transom assembly needs to be taken apart - sometimes requires removal of engine - then the seal can be replaced and the transom assembly put back together. Other items to check in the area would be the wiring for trim sender and limit switch and through hull gear lube fitting (if boat is new enough).
Mar 18, 2009 | Boating
Boating Logo
342 people viewed this question
Top 3M Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a 3M Boating Expert? Answer questions, earn points and help others
