Question about Jenn-Air JGR8850 Gas Kitchen Range
What is an F9 error and how do I get my oven door open
It's a jenn air model #JER8850AAW
serial number 18425400WY
  • 3 Answers
We solved this by holding the light/door switch in, hit the clean button, then press stop/clear for 3 seconds.
Posted on Feb 27, 2009
Jennair oven 8114 p472-60 or p458-60 f9 error code
The F9 error code for this model number Jenn-air range indicates a door lock issue. The control sees it as locked, unlocked, or both at the same time.
The technical manual instructs us to check the wiring to and from the door lock mechanism and if no issues are found replace the motorized door lock.
Mar 24, 2014 | Kitchen Ranges
F9 ERROR ON TIME SCREEN
F9 Door lock safety circuit on the power relay board sensed Recommended to replace power relay board
Oct 01, 2012 | Jenn-Air JGW8130A Electric Single Oven
I get an F9 in the window on the oven what does this mean
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Jan 01, 2011 | Jenn-Air Expressions AR141 Electric...
I have a jenn air model jer8850aaw replaced the bottom element and now the element will not shut off what could be the problem?
If the element wont shut off sounds like the oven thermostat control made be faulty, if its a manual knob you use to turn the oven on you'll need to replace it, but if its electronically controlled you'll need to replace what the call the erc or clock.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Oct 31, 2010 | Jenn-Air JER8850 Electric Kitchen Range
Model JGR8855ADS is reading Code F9. what does
Hi There
I have this code for you. hope this helps you.
F9 Door latch Check door latch components.Thank you for writing to fix ya.
Best Regards Richard
Feb 18, 2010 | Jenn-Air JGR8750 Gas Kitchen Range
I get failure code F9-3
What a scam by service personnel.
-Simply press "Stop/Clear", then gently push the door handle until "Lock" appears on the screen. Press "Stop/Clear" again and the door unlocks itself!
J. Kalicak
Jan 22, 2009 | Jenn-Air JES9800A Electric Kitchen Range
I am getting a F9 on front of my oven
We solved this by holding in the door/light switch, hitting "clean", then pressing stop/clear for about 3 seconds.
Nov 27, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jennair 8855 F9 error
take a 24 inch peice of coat hanger make a small u in one end and insert it from the left side gentlw fish for the door latch hook and pull it over to un latch the door and let me know if the code goes away
Jul 12, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
Don't know if the oven part of range is gas or electric
open the door on the left side low down you will find the model and serial number .
Visit the jenn-air website @ www.jennair.com or click
https://www.jennair.com/customer_care/contact_us.jsp
to email them and they can tell from the serial number and mail you back...
Nov 15, 2007 | GE JBP68 CleanDesign Electric Kitchen...
Oven door locked, F9 indicator signal
Monster, F9 is the door locked error. Try turning off the breaker for 30 seconds and see if it resets. If not, you are going to have to get a coat hanger, make a U at one end and slip it between the door and latch from the left. Once you feel the latch, give it a tug and the door should open. Try resetting the board again with the door open and see if the lock mechanism homes. If not you will have to check the cam and switches for problems. Catriver..post back.
Oct 05, 2006 | Jenn-Air JER8855 Electric Kitchen Range
Jenn-Air JGR8850 Gas Kitchen Range Logo
264 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
