Question about Viking 31 in. DECU165 Electric Cooktop
Only 1 of 5 burners is working on my Viking electric cooktop
DECU165 - 36" wide cooktop. Only the top left burner is working. Its a Viking Cooktop. What could be the problem?
  • 59 Answers
By only 1 burner working, I take you mean only 1 ignites, then it sounds as though you have an issue with the spark module being defective. There is usually an access panel on the bottom of the unit, although not on all of them. Remember to disconnect from the electric.
Posted on Mar 05, 2009
A spark that causes a snapping noise when a burner is turned on.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 26, 2010 | Viking 31 in. VGSU101 Gas Cooktop
My Viking vgsu cooktop has the igniter go on continuously when I try to turn on 4 of the 6 burners
My Viking stove igniter won't stop clicking. Both igniters on one side are clicking over and over
May 21, 2010 | Cooktops
Viking cooktop gas unit ignition clicks on all burners when I use
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
Viking pro 6 burner cooktop igniter won't stop clicking after lighting on two of the burners
Do not attempt if your stovetop is hot, you will get burned!!
This is an easy fix, the problem is your burners aren't lined up properly. Remove the iron grates (what your pots rest on) and the burner cap (the round black top on the burner) and finally the burner base (the round golden colored piece resting on the stainless stovetop). If you flip the base over you will see that it is keyed, meaning there is a grove that fits the indentation on the stove top. When you replace the base make sure to line the grove up with the indentation. If it's not flush with the stove top, slowly twist the round burner base until it falls into place. That's it!
Jul 09, 2009 | Viking Cooktops
Spark module will not stop after lighting burner
The module might not sense the flame: check electrical connections: wire (and its contacts0 and conections by fryer chasis; to be sure please bond with 18AWG wire pilot burner with spark module green wire.
MarKor
Mar 09, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
NOT WORKING BURNER ON MY VIKING 6 BURNER COOKTOP VGSU 36IN
Is the little center post of the removable frame over your burners in the little notch where it is supposed to rest?
Aug 18, 2008 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Clogged burner on gas cooktop
lowly is it the left burners that won't lite? I only ask as depending on the model some of the Thermador cook tops had simmer control burners. This is a 3 part system on the burners. 1 a simmer control, 2 electric solenoid, 3 potentiors. When you turn on the burner the potentior tells the simmer control to send power to the gas solenoid. At the same time the unit will spark. If your unit has extra low on the left 2 burners then you have this system. The usual problem in the potentior. Hope this helps.
Aug 07, 2008 | Thermador SGS36GS Gas Cooktop
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Viking 31 in. DECU165 Electric Cooktop Logo
319 people viewed this question
Top Viking Cooktops Experts
Carmen Mikulic
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
