Question about Digidesign Mbox External Sound System
Using Keyboard for Mbox 1
I am trying to connect my keyboard so that Pro Tools Le 6.4 picks it up. I am trying to record MIDI sounds but I do not know how to get the sounds to come from the keyboard on to the editor window.
  • 146 Answers
You have to select the port in Pro Tools, but the computer has to recognise the MIDI port first.Does P.T. see that you have a MIDI port installed? Did you select an instrument plug in and map the keyboard as the controller for the plug in? You may need to use a utility like MIDI Yoke or MIDIOX to map the port if you are using Windows. You also have to have the drivers installed so that Windows recognises it as a MIDI port. If it is on a Mac you may have to use the Audio/Midi setup up utility to add the midi port.
Best of luck, Let me know if I can help further.
Posted on Dec 27, 2008
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
Im having a digidesgin mbox 2 connect to my mac.. and am using a pro tools 8. But when i click records (as i had plug in the mic) there will be no signal detected tho my headphone have a sound there! And...
You need to make sure that your Protools 8 is routing the tracks to the headphone. Check that by seeing whether the M-Box is set up as your output system as well as input. Having MIDI thru has helped me with that problem before even though it has little to do with it.
May 02, 2011 | Digidesign Mbox 2 Pro FireWire Audio/MIDI...
I am using pro tools 8 LE. I have a blue bluebird condenser microphone. the cable going into the mic is a male 3 pronged end. and the end going into my avid mbox mini is a normal ending (the ones that look...
The mbox mini is usb powered, wont work without power so your mac or pc must be powered on and connected. The blue led will be on when powered. Assuming you have the the appropriate cables, you want to make sure the condenser is plugged into the Mic/Line input. (Input 1 on the back of the mbox mini). All condenser mics require phantom power, so engage the +48V switch. Also make sure the DI (direct input) switch is not engaged. The input gain control is located on the front of the mbox... There needs to be speakers connected to the 1/4 output jacks on the back of the mbox or headphones on the front for sound output. Use the large knob for monitor volume control.
In protools: Create a Stereo Master fader track
Create a mono audio track
Set the input of the mono audio track to Mic/Line 1 Arm the track for record (click & make sure the R is red)
You should getting levels and sound output from your condenser.
Apr 01, 2011 | Blue Microphones Blue Bluebird Condenser...
I want to use my sd card to put my own songs and when i change the song from an MP3 to MIDI file using the program WIDI 3.3 Pro. When i put the MIDI file which is the song, into the Sd card and then into...
You need to understand what the program is doing.
An MP3 file is a recorded music performance like a phonograph record. A MIDI file is a set of instructions for performing music, like sheet music. The converter program is an attempt to turn the record into sheet music. There is no perfect way to do that. You should have gotten something out of the program, though. It sounds more like a computer problem. Try a very simple sound file, convert it to MIDI, and see if you can get something out. If your keyboard can't read it, try putting any known good MIDI file on the card and read that. Possibly your keyboard will only read certain formats or sizes or speeds of cards. See if the manual tells you anything. It might read FAT16 regular speed cards under 1 GB, for instance, and balk at a SDHC 16 GB NTFS formatted card. So, do some detective work.
Apr 05, 2017 | Casio Lighted Keyboard LK90STADMC
MBox 1 Compatibility with new Macbook Pro Unibody and OSX 10.5.6?
unfortunately any pro tools application below version 7.4.2 is not compatible with leopard and I don't think you can use mbox 1 with the universal mac I may be wrong but I wanna say I tried a while back and even garageband wouldn't find it anymore but you can check for sure by going to the applications folder then open the utilities folder in there is an application called "Audio Midi Setup" and you can select the mbox in there if you see it but if not there is no patch or driver that I know of to get it working unless you upgrade pro tools which if you do upgrade I suggest getting mbox 2 and getting LE with it
Mar 12, 2009 | Digidesign Mbox External Sound System
Trouble with hooking mpc4k and korg triton pro to mbox
you will want your triton midi-in to go to your mpc midi-outB
then your mpc midi-inA to go to your mbox
your mpc midi-outA to go to your mbox
that should get you good for midi cables....
on the mpc, everytime you want to record a track using instruments from your mpc you will need to set a new track. on the main screen you would go to a new track (where Tr:01-Track-01 is) and change S:DRUM1 to S:MIDI, then to the right of that where it says OFF, turn that to 1A-Device01 ... you will have to make a new track for each instrument you use to help when bouncing tracks to mbox. for instance 1A-Device01 is the 1st track on your triton, 2A-Device02 is your second track and so on. make sure you also make a new track each time for where Tr:01-Track-01 is also for each instrument.
for the mbox i might be a little rusty on this so im going to post a quote from another site....
"in Pro Tools, go to setup - midi - midi studio. this is where you tell pro tools where your midi devices are connected. next, go to setup - midi - midi beat clock. you want to 'enable midi beat clock' and select the devices that are going to be receiving midi beat clock. all devices that you setup under midi studio should be showing. next, set pro tools' tempo for the session if you haven't already. This setup is based on Pro Tools being the MASTER device and the other device(s) SLAVE(S). Make sure that on your hardware/midi interface that the midi output is going to the midi input on the slave devices. On the mpc, press mode, then pad 9 and go to the sync tab. Choose "slave" under "sync in" and the port, 1 or 2, that your mpc will receive midi input. That's it!! When you start Pro Tools' sequencer, the mpc should start too at the same bar/beat location. I've tried slaving Pro Tools to the MPC1000 and Fantom Xa on diff. occasions but I could never get them in sync with Pro Tools. Tried diff. framerates and settings, but still, no luck. So I prefer using Pro Tools as the MASTER sending midi beat clock. Another thing, make sure that whatever you're tracking into Pro Tools doesn't change tempo during the song. If so, you'll have to edit tempo events in the tempo ruler. Hope this helps!!"
let me know if you need any more help.
Feb 16, 2009 | Akai MPC-4000 Plus Production Center (w/80...
Problems recording on acid pro 7 with edirol ua4-fx
point nr 1:
when you record midi, you are not recording sound but a key code and time info it was pressed.
point nr 2:
the midi keyboard may be seen as a remote controller.
check the midi configuration on your software host
Jan 22, 2009 | Edirol UA-4FX External Sound System
need to know if you use headphones while recording, if not it could be feedback from your monitors or even the phones.reasons phones too loud or mic gain too sensitive.
May 28, 2007 | Rode NT1A Professional Microphone
Open Questions:
Digidesign Mbox External Sound System Logo
541 people viewed this question
Top Digi Computers & Internet Experts
Level 1 Expert
Alun Cox
Don Hart
Are you a Digi Computer and Internet Expert? Answer questions, earn points and help others
